Stephen <mca### [at] aolDOT com> wrote:
> thicker as the drop moves downwards.
> Best Regards,
> Stephen
Yes, currently my trails are all one thickness but they should get thicker as
they get nearer the droplet, I need to put some more thought into how I create
these.
Thanks,
Sean
>> Best Regards,
>> Stephen
> these.
Best Regards,
"s.day" <s.d### [at] uel ac uk> schreef in bericht
news:web.4b19aac6edcf7d1efdd3b49e0@news.povray.org...
> I have tried scaling (not put that much effort in so far though) and the
> blobs
> seem to just disappear when I make them thinner. I will find the thinnest
> setting I can get away with and keep them visible. Of course it could be
> because
> I am scaling each component rather than the whole blob which would
> probably make
> a difference...
I think scaling the whole blob will do the trick. What you also can do I
guess, is cut off the part of the blob lying against the pane, in a
difference or intersection. Your blob becomes thinner too that way and you
simulate the *stickyness* of the water drop on the glass surface.
