POV-Ray : Newsgroups : povray.binaries.images : Eat my dust Godel, Escher, Bach Server Time
15 Nov 2024 00:20:13 EST (-0500)
  Eat my dust Godel, Escher, Bach (Message 1 to 10 of 24)
Subject: Eat my dust Godel, Escher, Bach
Date: 12 Nov 2008 13:35:01
Message: <web.491b2157c289ccfa7bacdf90@news.povray.org>
Comments? Suggestions? Constructive Criticisms? Apprehensions? Coagualtions?
Download 'namesake.a.png' (572 KB)
Preview of image 'namesake.a.png'
Subject: Re: Eat my dust Godel, Escher, Bach
Date: 12 Nov 2008 13:46:08
Message: <491b2470@news.povray.org>
Cool. I tried to do this once using CSG to cut the letters out of a
block and gave up before I could get it working. Looks like your method
works better.
Date: 12 Nov 2008 15:32:14
Message: <491b3d4e$1@news.povray.org>
haha, very nice!
Date: 12 Nov 2008 19:32:12
Message: <491b758c$1@news.povray.org>
  Why aren't the objects illuminated by the same lights that are
illuminating the surrounding walls?
Date: 12 Nov 2008 21:05:00
Message: <web.491b8a3a625722e11940c01c0@news.povray.org>
If you could upload a macro to the Object Collection I'd be thankful.
-Mike
Date: 13 Nov 2008 11:40:33
Message: <491c5881$1@news.povray.org>
> works better.
I'll have to play with this at home, but I think it should be feasable
with intersection ... I'll see if I can get my initials in a block like
that.
~Mike
Date: 13 Nov 2008 17:00:01
Message: <web.491ca2aa625722e149b4acd50@news.povray.org>
> > works better.
> that.
> ~Mike
I will try to get the source up as soon as I get home on Friday, to show you the
technical method.
Until then I can just say that each "letter" outline is not random. It's alot
easier to do it with only two letters, but when there are three its a lot less
controllable.
Originally the vertical bar for the J was in the center, but this messed up the
G. I also had the J and W, E and O, F and O, F and D in the same cubes, that is
only 4 with no solid squares. This also produced some funky shapes.
Date: 13 Nov 2008 19:30:01
Message: <web.491cc582625722e1791522d50@news.povray.org>
Ah, so it can't be done with arbitrary strings or fonts? That's too bad.
-Mike
Date: 13 Nov 2008 20:55:50
Message: <491cdaa6@news.povray.org>
>> method works better.
> that.
I decided to try with my initials (LEH) and came up with this _VERY_
simplified test image.  Just a single block with the three initials.
Fortunately, my initials were very easy to implement as simple unions of
boxes.  These were then differenced from a cube.  Note, difference not
intersection.
I don't know if this shape is physically possible, there might be
'floating' chunks in the middle someplaces.  But it works as a POV image.
I did end up using rounded boxes instead of regular boxes, and I
probably should change to spotlights as well.  But as I said, this was
just a simple initial test.
      -=- Larry -=-
Download 'leh.png' (24 KB)
Preview of image 'leh.png'
Date: 13 Nov 2008 23:25:00
Message: <web.491cfc4f625722e185de7b680@news.povray.org>
Surname in two parts, with high-ambient object and radiosity.
The third dimension looks to be a challenge; the differing widths of the letters
don't make for a straightfoward vertical cut.
Download 'call_wood.jpg' (44 KB)
Preview of image 'call_wood.jpg'
