POV-Ray : Newsgroups : povray.binaries.images : Static Warp Shields Server Time
24 Mar 2026 22:32:50 EDT (-0400)
  Static Warp Shields (Message 12 to 21 of 21)
Subject: Re: Static Warp Shields
Date: 16 Jun 2008 14:15:00
Message: <web.4856ad02e7b65d9072c2cb80@news.povray.org>
"alphaQuad" <alp### [at] earthlinknet> wrote:
> Can anyone show how to get distance to an egg shape given a vector of any
> direction?
> (center to shield impact point)
"distance to egg shape" and "center to shield impact point" isn't quite the same
thing. i guess you want to get the point where a beam hits the shield, right?
for that i'd rather use trace() than struggling with the math.
Regards Roman
Date: 17 Jun 2008 01:15:01
Message: <web.485747fce7b65d90d361a0c10@news.povray.org>
> > direction?
> Regards Roman
thanks for the tip
aQ
Heres about half the models I found. There are no thumbs so this might help.
http://st102.startlogic.com/~blenderw/cms/index.php?option=com_remository&Itemid=26&func=select&id=3
DeepSpaceNine
Warbird DeltaFlyer
Voyager 1701_E 1701_C 1701_B 1701_A
Warbird
BirdOfPrey Grissom Vorcha Hideki DominionBattleship
DeltaFlyer
  Reliant Goddard Maquis JemHadar AkiraClass
end model display
Download 'fleet05.png' (581 KB)
Preview of image 'fleet05.png'
Date: 17 Jun 2008 12:15:00
Message: <web.4857e208e7b65d9083467760@news.povray.org>
Yah, me too. I expected something like this existed and was the ticket.
I often wonder if I am doing something unecessary because I am unaware of the
alternate.
2 statements did it. THANK YOU! Just needed the guidance.
Download 'shieldhit05.png' (107 KB)
Preview of image 'shieldhit05.png'
Date: 17 Jun 2008 13:20:01
Message: <web.4857f11de7b65d9083467760@news.povray.org>
works on models also, this one at least. cool
Download 'flyerhit0.png' (55 KB)
Preview of image 'flyerhit0.png'
Date: 18 Jun 2008 09:35:00
Message: <web.48590e83e7b65d9085de7b680@news.povray.org>
Do disruptor beams cast shadows?
Date: 18 Jun 2008 11:49:53
Message: <48592ea1$1@news.povray.org>
Cousin Ricky nous illumina en ce 2008-06-18 09:32 -->
They should cast light, not shadows. Use a transparent container filled with
emissive media, no absorbtion, and turn on radiosity with media on.
Rebellion against tyrants is obedience to God.
Benjamin Franklin
Date: 18 Jun 2008 13:10:00
Message: <web.48594017e7b65d90ac387bfe0@news.povray.org>
Did all that.
I've tried this before, and noticed that my example only works with spheres.
Any genius out there who can fill a cylinder?
Could use a good LASER macro here, I'll start:
This is NOT visible:
// ************************* WarBird *******************************
#macro laser(A,B,rad,C)
   #local p_id = 0.1;
   #local glow_state = 0.001;  // fader
   #local glow_colorturb = <0.3,0.3,0.3>; //magnitude Randomness to color
   #local ColorJitter =
(<Hash2(p_id,1),Hash2(p_id,2),Hash2(p_id,3)>-<0.5,0.5,0.5>)*glow_colorturb;
   #local Color =
         C
         *(1+ColorJitter) // Randomness to color
         *(1.001-glow_state)    // fader
   #local ColorM = max(Color.x,max(Color.y,Color.z));   // highest RGB
   #local Color = Color/2;
    cylinder { A,B,rad hollow no_shadow
      pigment {rgbf 1}
      finish {ambient 1 diffuse 0}
      interior {
         media {
            emission Color            // color
            intervals 10              // default 10
            ratio 0.9
            samples 4,8       // default 1,1
            variance 1.0/128
            confidence 0.9
            method 2                  //1,2,3adaptive
            density {
               spherical
               density_map {
                  [0.0, rgb 0       ]
                  [0.6, rgb Color   ]
                  [1.0, rgb 2*ColorM]
/////////////////////hash.inc\\\\\\\\\\\\\\\\\\
#macro Hash1(t1)
   #local p1=sin(t1);
   #local pf=cos(1e7*(p1));
   abs(1e4*pf-int(1e4*pf))
#macro Hash2(t1,t2)
   #local p1=sin(t1);
   #local p2=cos(t2*2.2361);
   #local pf=cos(1e7*(p1+p2));
#macro Hash3(t1,t2,t3)
   #local p1=sin(t1);
   #local p3=sin(t3*1.8708+1);
   #local pf=cos(1e7*(p1+p2+p3));
Date: 18 Jun 2008 13:15:00
Message: <web.485941dde7b65d90ac387bfe0@news.povray.org>
I dont mean to be rude so,
credit for much of that was: Rune's Particle System
Date: 18 Jun 2008 13:33:23
Message: <485946e3$1@news.povray.org>
alphaQuad nous illumina en ce 2008-06-18 13:04 -->
> Did all that.
>    #local p_id = 0.1;
>    #local Color =
>          C
>       pigment {rgbf 1}
>       interior {
>          media {
>             ratio 0.9
>             variance 1.0/128
>             confidence 0.9
>             density {
>                spherical
>                density_map {
>                   [0.0, rgb 0       ]
>                   [0.6, rgb Color   ]
>                   [1.0, rgb 2*ColorM]
> #end
> #macro Hash1(t1)
>    #local p1=sin(t1);
> #end
> #macro Hash2(t1,t2)
>    #local p1=sin(t1);
> #end
>    #local p1=sin(t1);
> #end
Replace the sphere by a unit radius cylinder with one end at the origin along
the Y axis. Fill it with media using the cylindrical pattern in place of the
spherical one. Scale it to the desired length and diameter, rotate it as needed
and translate it to the correct location.
EVERYTHING HAS A GENDER
You may not know this but many nonliving things have a gender...
A Web Page is Female, because it's always getting hit on.
Date: 18 Jun 2008 19:45:01
Message: <web.48599cc7e7b65d90ac387bfe0@news.povray.org>
I was just noticing that.
Mapping must happen at 0, I tend to overlook. Went thru the spherical and was
noticing everything you said, now cylindrical works, I'm just a little slow at
catching on. One day I remember mapping happens a ZERO, DOH.
These were done done with spherical density pattern which seems to be faster
than cylindrical.
Scaling a sphere would get you lenticular or lens shape:
Download 'mediabeams2.jpg' (203 KB)
Preview of image 'mediabeams2.jpg'
