POV-Ray : Newsgroups : povray.binaries.images : Ping Pong: Glory Challenge Server Time
18 Feb 2025 18:07:49 EST (-0500)
  Ping Pong: Glory Challenge (Message 1 to 10 of 13)
Subject: Ping Pong: Glory Challenge
Date: 19 May 2008 14:20:01
Message: <web.4831c3ec665cb59488f191100@news.povray.org>
I'd bet money it can be done, tho I cannot make it at this time.
http://news.povray.org/*/attachment/%3C48202ea0%40news.povray.org%3E/glory.jpg
Glory is your shadow encircled in a rainbow.
Radiosity would not change the colors
"refraction on" was tried.
Need to use a prism shape?
Here's my glider if anyone wants to try this:
Download 'glory3.jpg' (40 KB)
Preview of image 'glory3.jpg'
Subject: Re: Ping Pong: Glory Challenge
Date: 19 May 2008 14:25:00
Message: <web.4831c5d7d2ad962988f191100@news.povray.org>
, and the code for that image
Download 'glory3.pov.txt' (101 KB)
Date: 19 May 2008 14:50:00
Message: <web.4831cb92d2ad962985de7b680@news.povray.org>
Have you tried dispersion? (Since that is what a rainbow is.)
Date: 19 May 2008 19:30:00
Message: <web.48320d0ad2ad962988f191100@news.povray.org>
tried:
  interior { ior 1.33 caustics 1 dispersion 1.01 dispersion_samples 9 }
  interior { ior 1.33 caustics 1 dispersion 1.1 dispersion_samples 100 }
  (just more render time)
still nothing
obviously this is where knowing what you're doing comes in handy.
something about the layer, I havent a clue.
I dont really care, but for the group at least. Something they might use one
day.
Date: 19 May 2008 21:35:00
Message: <web.48322a86d2ad962988f191100@news.povray.org>
If your'e interested in this and want answers, they might be found here.
Only had the time to grab and render:
galilean_view_eyepiece.pov
http://www.arachnoid.com/raytracing/telescope1.html
Sweet info page from what I've seen so far, I'll need to spend more time on it
Download 'galilean_view_eyepiece.png' (28 KB)
Preview of image 'galilean_view_eyepiece.png'
Date: 19 May 2008 23:36:30
Message: <4832473e@news.povray.org>
alphaQuad nous illumina en ce 2008-05-19 19:28 -->
> tried:
> still nothing
> day.
You don't need to use caustics here.
"We returned the General to El Salvador, or maybe Guatemala, it's difficult to
tell from 10,000 feet."           -- Anon.
Date: 20 May 2008 11:20:00
Message: <web.4832eb72d2ad962985de7b680@news.povray.org>
Here's a proof-of-concept:
#ifndef (Disp) #declare Disp = 0; #end
#ifndef (Reps) #declare Reps = 20; #end
#declare Spacing = <sqrt(3), 0, 1>;
global_settings { assumed_gamma 1 max_trace_level 60 }
camera
{  location Reps * Spacing.x * 2 * y
   look_at 0
   angle 30
   right image_width * x
   up image_height * y
light_source { Reps * 1000 *y, rgb 1 }
sky_sphere
{  pigment { gradient y color_map { [0 rgb 0.85][1 rgb 0.50] } }
plane { y, -1 pigment { rgb 1 } }
#declare t_Drop = texture
{  pigment { rgbt 1 }
   finish
   {  reflection { 0 1 fresnel } conserve_energy
      specular 1 roughness 0.001
#declare i_Drop = interior
{  ior 1.333
   #if (Disp) dispersion 1 + Disp * 0.007 dispersion_samples 10 #end
#declare m_Drop = material { texture { t_Drop } interior { i_Drop } }
#declare Half_sheet = union
{  #declare I = 0;
   #while (I < Reps)
      #declare J = 0;
      #while (J < Reps)
         sphere { <J, 0, I> * Spacing, 0.4999 }
         #declare J = J + 1;
      #declare I = I + 1;
   translate (1 - Reps) / 2 * Spacing
#declare Sheet = union
{  object { Half_sheet translate Spacing/4 }
   object { Half_sheet translate -Spacing/4 }
object
{  Sheet
   material { m_Drop }
This first image has no dispersion, and was run with declare=Reps=3 on the
command line.
Download 'glory-poc-ed.jpg' (6 KB)
Preview of image 'glory-poc-ed.jpg'
Date: 20 May 2008 11:25:01
Message: <web.4832ece6d2ad962985de7b680@news.povray.org>
This second image has 10 times the dispersion of water (according to some number
i once saw somewhere in the POV-Ray material).  It was run with declare=Reps=3
declare=Disp=10 on the command line.
Download 'glory-poc-10.jpg' (13 KB)
Preview of image 'glory-poc-10.jpg'
Date: 20 May 2008 16:25:01
Message: <web.48333228d2ad9629f0ad1f150@news.povray.org>
Glider was a scripted output, a script written before I understood much about
pov that has become clear.
output was:
union {
mesh {
today I'd change union to object, (or put matrix inside mesh and declare the
mesh) being that there is no union of triangles which are inside mesh{}. It
could be said the glider code is wrong (doh) even tho it works.
Before I am corrected, all apologies for producing ugly code. I'll do better in
the future.
Date: 21 May 2008 13:00:01
Message: <web.4834542dd2ad9629705d13a50@news.povray.org>
I am finding this whole thread pretty interesting and it is something which i
have looked into before. Having played around with these features and building
a setup which has the technicalities of a rainbow taken into account I created
the following image a while back.
Notably this is not quite what you are looking for, the light source comes
through the plane (by means of the blue hole) and the rainbow emerges due to
bending the light back (This may seem a strange idea however if you imagine
that the screen is the observer then by looking at the screen we see the light
that would be seen by the observer).
The set up is similar to what you are trying. This thread has prompted me to
play around with the set up and I have found that oddly enough the setup does
require that caustics be on, this doesnt make sense but appears to be the case.
I will be continuing to play around so will let everyone know what I find with
further investigation.
Malcolm
Download 'caustic rainbow4.jpg' (155 KB)
Preview of image 'caustic rainbow4.jpg'
