POV-Ray : Newsgroups : povray.binaries.images : Tracing an object through a soft-edged mask; or objects as airbrush 'spray' Server Time
13 Mar 2026 13:16:11 EDT (-0400)
  Tracing an object through a soft-edged mask; or objects as airbrush 'spray' (Message 11 to 20 of 33)
Subject: Re: Tracing an object through a soft-edged mask; or objects as airbrush 'sp=
Date: 13 May 2008 05:15:25
Message: <48295c2d$1@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> wrote in message
news:web.48293172dace545278dcad930@news.povray.org...
> > > BTW, in working with this technique (and running some other
experiments),
> > I've found that rand() doesn't actually HIT zero or one.
> > A pseudo random generator should in practice not hit *any* given number,
not
> > just 0 and 1, unless you cover its period at least a few times. Further,
in
> > practice again, some (or many) numbers in range will simply be
"unhittable".
> Not sure I understand what you mean by *period*.  Would that be *all* the
> possible numbers between 0 and 1 that can conceivably be found in Pov_Ray?
Correction, I was mixing two things. With a pseudo-rng, you need to only
cover the period once (after that, it starts repeating). With a
physical/hardware rng, you can of course never be sure, but in practice, if
you cover the domain of possible values a few times over, you can develop
enough confidence. I don't know what POV uses for rng.
> As to some values being unhittable--can't say I understand why, unless it
has
> something to do with underlying computational processes that I don't
understand
> (and I don't understand plenty, when it comes to such things! :-)
That happens if the period of a rng is smaller than the domain of generated
numbers (ie a rng with period 2^30 returning 32 bits won't hit 75% of the
numbers in the domain).
Subject: Re: Tracing an object through a soft-edged mask; or objects as airbrush 'spray'
Date: 13 May 2008 06:13:35
Message: <482969cf$1@news.povray.org>
Cool, but you don't need the height_field, just use eval_pigment.  That way,
you can use any pigment as a mask
something like this:
--- begin code ---
#include "functions.inc"
#local TraceObject=plane {y,0}
#local Mask=pigment {granite poly_wave 2}
#local Number=100000;
#local Seed=seed(123);
union {
    #while (Number>0)
        //trace from a random value ranging from <-2,..,-2> to <2,..,2>
        #local
TracePosition=<rand(Seed)-rand(Seed),500,rand(Seed)-rand(Seed)>*<2,1,2>;
        #local Position=trace(TraceObject,TracePosition,-y);
        //Two ways: use the mask as a 2D mask, using only the X and Y values
        #local
Probability=eval_pigment(Mask,<Position.x,Position.z,0>).gray;
        //or... use it as a 3D mask
        #local Probability=eval_pigment(Mask,Position).gray;
        #if (rand(Seed)<=Probability)
            sphere {
                Position,.01
        #local Number=Number-1;
    pigment {red 1}
object {TraceObject pigment {rgb 1}}
//camera and light_source
    location <-3,5,-10>
    look_at 0
light_source {
    <500,500,-500>
    rgb 1
--- end code ---
cu!
Date: 13 May 2008 07:27:39
Message: <48297b2b$1@news.povray.org>
You had the same idea as me :-)
I changed Kenneth's code to use eval_pigment instead of a height_field, I
noticed that parsing was much longer, and also that POV was faster 'out of
memory' with a large number of objects. I don't know if this is a
significant difference due to the different methods, but there it is.
Date: 13 May 2008 10:45:00
Message: <web.4829a8e4dace5452a8d0b25a0@news.povray.org>
Hmmm, interesting little technique there.  I'm trying to think of ways to
exploit it for filmmaking purposes.  Need to do some research...
Dan
GoofyGraffix.com
Date: 13 May 2008 11:40:01
Message: <web.4829b56bdace545278dcad930@news.povray.org>
> you can use any pigment as a mask..
Aha, I knew *someone* out there would find a way to improve it (in this case,
both you and Thomas.) I'll have to try this--I've never used eval before.
Thanks for the code example.
Ken W.
Date: 13 May 2008 11:50:00
Message: <web.4829b7aadace545278dcad930@news.povray.org>
> Just a very rapid example, taking a random photograph I had, without
> particular blurring I must say, but still a nice result.
> Thanks again, Kenneth!!
> Thomas
Wow, I like that--especially when the number of objects is increased. I actually
hadn't thought of using a *photograph* as the mask; yet it's such a natural
extension. The idea floods my mind with possible uses!  Thanks.
Ken W.
Date: 13 May 2008 12:05:02
Message: <web.4829bb09dace545278dcad930@news.povray.org>
> you can use any pigment as a mask...
....and using it as a 3-D mask, which you outline in the code example, sounds
REALLY intriguing! I'm guessing that such a technique will work because the
pigment pattern is 3-D rather than 2-D (as in my original image_map example)?
Wow. If so, then my limited little masking trick just took on a whole new
dimension--literally!! Thanks for opening my eyes.
KW
Date: 14 May 2008 04:09:52
Message: <482a9e50$1@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> schreef in bericht
news:web.4829b56bdace545278dcad930@news.povray.org...
>> way,
> case,
In Zeger's example, I would replace .gray by .red (or .green or .blue).
Parsing will be much faster, for the same result.
Date: 14 May 2008 04:17:19
Message: <482aa00f@news.povray.org>
news:web.4829bb09dace545278dcad930@news.povray.org...
>> way,
> sounds
> the
> example)?
He he!! Yes, I suppose that might be an interesting development. I keep a
bit worried though about the 'out of memory' that I got with the
eval_pigment variation. Maybe it was just chance (I shall have to
investigate further). The slower parsing can be compensated in the end by
writing the found positions to a file and read them back later for
rendering.
I must say, Kenneth, that your little elegant height_field technique appeals
to me a lot and I shall use it a lot where it can easily substitute
eval_pigment.
Date: 14 May 2008 04:38:10
Message: <482aa4f2@news.povray.org>
> This is traced in the usual way, but the y-values that are found are not
> used
> to place objects anywhere; rather, they are used to statistically(?)
> determine
> whether an object is made or not made at any particular x/z location...a
> sort
> of 'chance' determination, with a HF height of 0 being a zero% chance that
> an
> object is made, up to 1 being a 100% chance.
I use this method currently too, in a game to place trees and things around
the level.  *But*, when you have large areas of low-density, and you want to
plant thousands of items, it starts to get slow (because there are so many
"misses").  I am wondering if there is a faster way to do it?
