POV-Ray : Newsgroups : povray.binaries.images : Skip-a-ray SDL raytracer Server Time
30 Sep 2024 11:16:34 EDT (-0400)
  Skip-a-ray SDL raytracer (Message 1 to 10 of 12)
Subject: Skip-a-ray SDL raytracer
Date: 24 Oct 2007 15:25:01
Message: <web.471f9b31e04cdb41654d6f060@news.povray.org>
I used the SDL raytracer found in the help file
(http://www.povray.org/documentation/view/3.6.1/123/) to refine an idea
more or less suggested by Bruno Cabasson.
Top picture skips a ray if (square of) distance in colour-space is smaller
than an user supplied threshold.
Middle pic is the result of the unadulterated SDL raytracer.
Bottom pic is the difference of the two.
The supplied Skip-a-ray pic requires about 65-70% of the time to render.
Download 'compositepic.png' (386 KB)
Preview of image 'compositepic.png'
Subject: Re: Skip-a-ray SDL raytracer
Date: 24 Oct 2007 22:25:01
Message: <web.471ffd6e72fb445f88727a860@news.povray.org>
Wow.  Not sure how it would work in a busier example or compiled in, but
sure saves time here.
 - Ricky
Date: 25 Oct 2007 04:59:28
Message: <47205af0$1@news.povray.org>
"Grassblade" <nomail@nomail> wrote in message
news:web.471f9b31e04cdb41654d6f060@news.povray.org...
Neat.
I would be hard-pressed to tell the difference.
So the slight differences all show up at the edges.
Presumably these are glancing rays?
So this is effectively like shifting gear on AA, with jaggies showing up at
some edges.
DLM
Date: 25 Oct 2007 10:15:02
Message: <web.4720a3bf72fb445fe8ba46670@news.povray.org>
The fact is  that, basically and in principle, you can't predict whether or
not an object happens to occlude another at the next pixel or next ray. My
suggestion was about the fact that in ALREADY RENDERED images, entire areas
It appears now that the answer is no.
But I am still wondering if a first 'geometrical' pass at render-time could
help collect data (like direction-object correspondance) that could be used
FOR SUBSEQUENT RENDERS and save ray-object intersection tests and
assumptions about ray-object intersectons. This is not very applicable for
anims, of course.
Bruno.
Date: 25 Oct 2007 15:20:01
Message: <web.4720ec1b72fb445f45deea430@news.povray.org>
>  - Ricky
Yeah, I wish I knew how to code in C so I could find out for myself. :-(
Date: 25 Oct 2007 15:30:01
Message: <web.4720edc572fb445f45deea430@news.povray.org>
> Neat.
> some edges.
> DLM
That's a good question, jaggies shouldn't show up in principle, because of
the threshold. Yet the difference picture shows the outline of at least the
two bottom spheres. I'm not entirely sure where it comes from. Maybe if I
rendered with no AA it would go away. Or maybe I need a lower threshold,
but then render-time might go up.
And, yes, the algorithm acts like a sort of AA, but with different weights
from what we are used to.
Date: 25 Oct 2007 15:50:00
Message: <web.4720f10772fb445f45deea430@news.povray.org>
Well, actually making predictions based on past history is the job of
statistics. In general you can't have a 100% accurate predictor, though;
which I believe is what you wanted. So, yes, it is possible to get an
imperfect predictor on the first pass. But the math involved can get really
ugly.
 My
> anims, of course.
> Bruno.
Ah, OK, I misunderstood your idea, then. The logical conclusion is: Cool,
the idea I posted here is mine!!! ^_^
Regarding your idea, it was mentioned in the off-topic forum
(http://news.povray.org/povray.off-topic/thread/%3Cweb.471cbb5fa19b477d27eef15b0%40news.povray.org%3E/)
that in a raytracer by the name of Maxwell you can change lighting set-up
after rendering. This sounds very much like what you are suggesting, since
it requires storing somewhere previous render information. So it is
possible, but not in POV just yet. It's definitely the way to go for future
versions of POV-ray, IMHO. I may give it a go in the SDL raytracer,
actually, assuming I can figure out how it works exactly and if I can find
the time.
Date: 25 Oct 2007 17:04:17
Message: <472104d1@news.povray.org>
is this a similar technique as used here:
http://www.cip.physik.uni-muenchen.de/~wwieser/render/povray/patches/prt-patch/ ?
cu!
Date: 25 Oct 2007 18:05:00
Message: <web.472112e672fb445f45deea430@news.povray.org>
> cu!
> #macro G(b,e)b+(e-b)*C/50#end#macro _(b,e,k,l)#local C=0;#while(C<50)
> sphere{G(b,e)+3*z.1pigment{rgb G(k,l)}finish{ambient 1}}#local C=C+1;
> #end#end _(y-x,y,x,x+y)_(y,-x-y,x+y,y)_(-x-y,-y,y,y+z)_(-y,y,y+z,x+y)
> _(0x+y.5+y/2x)_(0x-y.5+y/2x)            // ZK http://www.povplace.com
Yes! Well, not the page you linked to, but this other one is very similar:
http://www.cip.physik.uni-muenchen.de/~wwieser/render/povray/patches-35/ipt-patch/
Except it's needlessly complicated, and potentially introduces big artifacts
as the pics show. I'm disappointed to see the patch is only available on
Unix systems, though. One more reason to download Linux. Someday.
Date: 27 Oct 2007 18:20:00
Message: <web.4723b8f272fb445f88727a860@news.povray.org>
Hey, today is someday!
 - Ricky
