POV-Ray : Newsgroups : povray.binaries.images : Random Comic Sci-Fi Building Generator Server Time
14 Apr 2026 23:05:00 EDT (-0400)
  Random Comic Sci-Fi Building Generator (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Random Comic Sci-Fi Building Generator
Date: 19 Oct 2007 15:05:00
Message: <web.4718ffc0c27b9d44f941da60@news.povray.org>
"Kirk Andrews" <kir### [at] tektonartcom> wrote:
> Version 2.0
> Anybody have any suggestions?
nope. you havent described how you are doing it, have you?
looks good, want more
Date: 19 Oct 2007 15:15:01
Message: <web.471901dec27b9d47e1bc26d0@news.povray.org>
> > Version 2.0
Well, I guess I was hoping for suggestions for more details that I could add
(for example, I working on adding balconies and support structures).  But
since you asked, it's just a simple macro with a lathe object.  The points
on the spline are randomized.  The real trick is the texture--the macro
picks one of 5 images to use for a texture_map, which creates the various
patterns of windows.  If anybody wants it, I'll post the macro when I'm
finished with it.
Date: 19 Oct 2007 15:25:00
Message: <web.471903e5c27b9d4b06956ce0@news.povray.org>
> Version 2.0
Nice! How about giving a little depth to the windows? Of course differencing
them would probably kill speed. :-p
Message: <web.47190435c27b9d44f941da60@news.povray.org>
> finished with it.
'ell yes. scene-files are the best. if there were enough scene files, people
could easily with little experience create unique and different ideas.
Date: 19 Oct 2007 17:24:50
Message: <471920a2@news.povray.org>
Hi - it looks great!  The idea of adding balconies might look good.  How
about adding some random spires or antenna masts on the tops of the
buildings?
"Kirk Andrews" <kir### [at] tektonartcom> wrote in message
news:web.4718e438c27b9d47e1bc26d0@news.povray.org...
> Version 2.0
Date: 19 Oct 2007 20:00:00
Message: <web.47194476c27b9d47e1bc26d0@news.povray.org>
Version 3:  Balconies, Domed walking-paths, "Cocoons" and buttresses.
Still working on spires--that's a good idea, though.  I think I'm about done
with it, so I'll get the code cleaned up and post it to scene-files.
Download 'mkrc01.jpg' (119 KB)
Preview of image 'mkrc01.jpg'
Date: 19 Oct 2007 21:28:49
Message: <471959d1$1@news.povray.org>
Kirk Andrews nous apporta ses lumieres en ce 2007/10/19 19:57:
One thing that could be done to give more "deepth" to the windows: Instead of
using white for them, use transparent! Then, add an other instance of the tower
inside the first one, slightly scaled down around it's axis. Give that iner
element a high ambient. Using white of gray can be enough, but you can also use
any pattern you like or some image_map.
Now, if you do a night scene, you use radiosity, the windows will actualy shine
and illuminate the neigoring towers.
You know you have been raytracing for too long when the animation you
render will be finished after yourself.
Urs Holzer
Date: 19 Oct 2007 22:00:00
Message: <web.47196091c27b9d47e1bc26d0@news.povray.org>
> Alain
I understand what you're saying--but after thinking about it, I don't think
it will have any different result.  The windows are already using ambient.
Now, if I make the windows transparent, but put a layer behind it that is
fully ambient, no one could tell that it was any different than the way it
is now.  Am I thinking about this correctly?
Date: 19 Oct 2007 22:07:15
Message: <471962d3$1@news.povray.org>
Kirk Andrews nous apporta ses lumieres en ce 2007/10/19 21:57:
>> Alain
The difference, is that using patterns or iamge_map, two instances of the same
windows layout will look different depending on that inner pattern. This can
make things more interesting. 5 outer textures and 5 inner patterns randomly
rotated/translated could generate 1000000's of combinations. Think of the cells
pattern randomly translated and wraped around the axis.
The early bird may get the worm, but the second mouse gets the cheese in the trap.
Date: 20 Oct 2007 03:19:05
Message: <4719abe9@news.povray.org>
"Kirk Andrews" <kir### [at] tektonartcom> schreef in bericht
news:web.471901dec27b9d47e1bc26d0@news.povray.org...
> add
> finished with it.
I think that, when finished, this macro would be ideal for the POV-Ray
object collection!!
Good work!!
