POV-Ray : Newsgroups : povray.binaries.images : modern building - wip 1 Server Time
10 Apr 2026 23:46:10 EDT (-0400)
  modern building - wip 1 (Message 1 to 6 of 6)
Subject: modern building - wip 1
Date: 31 May 2007 16:45:01
Message: <web.465f3326deed9c74773c9a3e0@news.povray.org>
Not inspired by any building in particular.  I intend to improve it,
eventually.  As it is, it began very simply.
source:
// sky
sphere { 0, 1
 pigment { gradient -y color_map {[0 rgb z*.7][1 rgb <.8,.9,1>]} }
 finish { ambient 1 diffuse .01 }
 scale 2.1
 translate -y/2
 pigment { bozo turbulence .6 omega .6 lambda 3
     color_map {[0 rgbt 1][.56 rgbt 1][.6 rgb 1][1 rgb 1]} scale .5
 finish { ambient 1 diffuse .002 }
 scale 2.1
 translate -y/2
 no_shadow
 scale 1000
#local p_concrete = pigment {
    checker rgb .9 rgb .86 turbulence .1 omega .56 scale 10
// scene
union {
 light_source { 300*(1-2*z) <1,1,.8>*1.2 }
 plane { y, 0 pigment { rgb 1 } finish { ambient .2 diffuse .5 } }
 #local building_s = <36,90,18>;
 #local building =
 union {
     box { -1,1 scale building_s/2
         pigment { rgb .1*y }
         normal { average
             normal_map {
                 [1 quilted .07 control0 .06 control1 .06 scale 2]
                 [.5 cells scale 2 slope_map {[0 .1][.7 .1][.7 0][1 0]}]
         finish { diffuse .007 ambient .01 brilliance 1.4
             specular .9 roughness .01 metallic .2
             reflection { .02,3.96 metallic .2
                 fresnel on exponent 3 falloff 20
             conserve_energy
         hollow
         interior { ior 1.5 fade_power 2 fade_distance 3 }
     box { -1,1 scale <7,building_s.y+5,building_s.z+4>/2
         pigment { p_concrete }
         translate y*5/2 -x*8
         translate y*5/2 +x*8
     finish { ambient .01 diffuse .5 }
     translate y*building_s/2
 union {
     object { building rotate y*90 translate -x*(building_s.z/2+10) }
     object { building rotate y*90 translate x*(building_s.z/2+10) }
     //rotate y*70
 //box { -1,1 scale 20 pigment { rgb .8 } translate -z*60-x*20 }
 rotate -y*30
#local cam1 =
 location -z*80*2+y*1.6
 look_at y*50
 angle 50
#local cam2 =
 location -z*60 + y*1.6
 look_at y*60
 angle 50
camera { cam2 }
global_settings {
    radiosity { brightness .7 count 80 error_bound .5 normal on }
Download 'predio-wip1.jpg' (38 KB)
Preview of image 'predio-wip1.jpg'
Subject: Re: modern building - wip 1
Date: 1 Jun 2007 08:28:18
Message: <466010e2$1@news.povray.org>
Nice effect!
Paolo
> source:
> // sky
> sphere { 0, 1
>  texture {
>  scale 2.1
>  translate -y/2
>  texture {
>  scale 2.1
>  translate -y/2
>  no_shadow
>  scale 1000
> // scene
> union {
>  #local building =
>  union {
>          normal { average
>              normal_map {
>              conserve_energy
>          hollow
>  union {
>      //rotate y*70
>  rotate -y*30
> #local cam1 =
> camera {
>  look_at y*50
>  angle 50
> #local cam2 =
> camera {
>  look_at y*60
>  angle 50
> camera { cam2 }
> global_settings {
Date: 1 Jun 2007 16:51:07
Message: <466086bb$1@news.povray.org>
Nice one - I like it...
Date: 1 Jun 2007 19:48:25
Message: <4660b049$1@news.povray.org>
The reflection of the clouds on the left building is awesome! I am less
convinced by the right building, where each window seems to use a
different material. Is that the case, or is it just the normal effect of
clouds / landscape reflection?
Date: 1 Jun 2007 22:40:01
Message: <web.4660d807bbfc19b89fe13f7a0@news.povray.org>
hmm, to tell the truth I've been experimenting with a lot of different
reflection schemes, with fresnel.  Apparently, I misunderstood the exponent
usage from the manual:  it should be 1 or lower and even so, it's just
artistic license.
I thought in this one the reflection was a tad off but I liked the image
anyway.  This is why I'm going for a radically different direction in the
next WIP. :)
> I am less
The texture is just this:
          normal { average
              normal_map {
and reflections of a cloudy sunny sky.
It's because of the cells pattern in the normal.  I intended to simulate
slightly, just slightly offset mirrored windows, but the effect came as to
much.  I should have used a lower (default there) bump_size or tweaked the
slope_map a lot more.
Anyway, next WIP coming soon with improved geometry and texturing. :)
Date: 3 Jun 2007 04:00:02
Message: <web.46627459bbfc19b8fec187f50@news.povray.org>
> eventually.
I like where this is going. I've been working on some buildings of my own,
but I do like your glass effect better than my own, even in this  WIP.
Didn't think of using cells; thanks for the idea.
Ken W.
