//Hello my friends
//I posted my first image in newsgroup...
//Components: Two planes, some lights, and hundreds of boxs
#declare DEG=180/pi;
global_settings { assumed_gamma 1.2 radiosity {} }
camera { location <5, 100, 0> look_at 0 angle 45 }
#declare i=-700;#while (i<=-100)
light_source { <0, i, 0>, 60 fade_distance 1 fade_power 1.25 shadowless }
#declare i=i+200;#end
light_source { <0, 100, 0>, 120 fade_distance 1 fade_power 1.25 shadowless
union {
plane { y, 101 }
plane { y, -600 rotate (z+x)*1 }
pigment { rgb 0 } finish { reflection 1 }
union {
#declare g=-600;#while (g<150)
#local S=sin(g*DEG);
#local C=cos(g*DEG);
#local R=cos(g*DEG)/2;
#local G=cos((g+1.20)*DEG)/2;
#local B=cos((g+2.40)*DEG)/2;
box {
-1, 1
pigment { rgb <R,G,B>+.65 }
finish { ambient 0 }
scale <1, 8, 1>
rotate y*10*g*DEG
translate <20*S, g, 10+20*C>
#declare g = g + 0.08;
Download '0008.png' (437 KB)
Preview of image '0008.png'
Uhh, pretty! Nice blur-like effect.
Florian
Wow... you did this with ... *boxes* ... Impressive!
Wait - there's a contest for "few code, many objects"?
Man, imagine if you could describe POV-Ray scenes in Haskell... >:-D
Actually, SDL is powerful enough to implement Ackermann's function,
which means that with *very* little code you can create so many
objects that it will quickly overwhelm all CPU power and memory in
the world combined. (Ah, the joys of recursion...!)
Of course, the *usefulness* of such a thing is questionable, so I've
chosen to interpret the contest as "with as little code as possible,
create as many objects as possible that would result in a
_meaningful scene_".
"Agustin Britait Molina" <agu### [at] hotmail com> wrote:
> //Hello my friends
Beatiful picture, IMO. It never ever dawned on me to put light sources
inside a routine, thanks for the idea.
I've done it before, but it tends to overwhelm the scene if you're not
careful.
Here, it came out great :)
...Chambers
> //Hello my friends
Very very nice - I actually got vertigo looking down that tunnel...
Stefan
Great effect, the image would look even better with a bit of focal blur but
I guess with that many light sources and objects you would need all the
computers in the world to render it... How long did the render take?
About one and half minute, few time... I haven't enought pacience to wait a
slow render (more than 5 minutes)
My computer is a AMD Athon 2000 with 384 RAM and w2000 SP4 server
I will try render with focal blur
Render Statistics
Image Resolution 800 x 600
Pixels: 480605 Samples: 480605 Smpls/Pxl: 1.00
Rays: 1298034 Saved: 0 Max Level: 5/5
Ray->Shape Intersection Tests Succeeded Percentage
Box 5213875 2836905 54.41
Plane 2595998 1303580 50.21
Bounding Box 67389996 21921815 32.53
Vista Buffer 27031790 16349486 60.48
Calls to Noise: 0 Calls to DNoise: 10
Reflected Rays: 17634
Radiosity samples calculated: 24149 (1.89 %)
Radiosity samples reused: 1255828
Smallest Alloc: 18 bytes
Largest Alloc: 75016 bytes
Peak memory used: 16025694 bytes
Total Scene Processing Times
Parse Time: 0 hours 0 minutes 2 seconds (2 seconds)
Photon Time: 0 hours 0 minutes 0 seconds (0 seconds)
Render Time: 0 hours 1 minutes 28 seconds (88 seconds)
Total Time: 0 hours 1 minutes 30 seconds (90 seconds)
CPU time used: kernel 0.48 seconds, user 86.86 seconds, total 87.34 seconds
Render averaged 5495.53 PPS over 480000 pixels
POV-Ray finished
