POV-Ray : Newsgroups : povray.binaries.images : Few code, many objects contest Server Time
20 Feb 2025 13:59:08 EST (-0500)
  Few code, many objects contest (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Few code, many objects contest
Date: 6 Feb 2007 12:00:01
Message: <web.45c8b38fc270a2dddd5364bf0@news.povray.org>
Wow... you did this with ... *boxes* ... Impressive!
Date: 6 Feb 2007 13:32:59
Message: <45c8c9db$1@news.povray.org>
Wait - there's a contest for "few code, many objects"?
Man, imagine if you could describe POV-Ray scenes in Haskell... >:-D
Date: 6 Feb 2007 14:05:00
Message: <web.45c8d0e3c270a2dddd5364bf0@news.povray.org>
Actually, SDL is powerful enough to implement Ackermann's function,
which means that with *very* little code you can create so many
objects that it will quickly overwhelm all CPU power and memory in
the world combined. (Ah, the joys of recursion...!)
Of course, the *usefulness* of such a thing is questionable, so I've
chosen to interpret the contest as "with as little code as possible,
create as many objects as possible that would result in a
_meaningful scene_".
Date: 6 Feb 2007 15:20:00
Message: <web.45c8e26bc270a2dd802da7170@news.povray.org>
"Agustin Britait Molina" <agu### [at] hotmailcom> wrote:
> //Hello my friends
> //I posted my first image in newsgroup...
> //Components: Two planes, some lights, and hundreds of boxs
> #declare i=-700;#while (i<=-100)
>   light_source { <0, i, 0>, 60 fade_distance 1 fade_power 1.25 shadowless }
> #declare i=i+200;#end
>   light_source { <0, 100, 0>, 120 fade_distance 1 fade_power 1.25 shadowless
Beatiful picture, IMO. It never ever dawned on me to put light sources
inside a routine, thanks for the idea.
Date: 7 Feb 2007 20:19:00
Message: <45ca7a84@news.povray.org>
I've done it before, but it tends to overwhelm the scene if you're not
careful.
Here, it came out great :)
...Chambers
Date: 8 Feb 2007 06:45:39
Message: <45cb0d63@news.povray.org>
Agustin Britait Molina wrote:
> //Hello my friends
Very very nice - I actually got vertigo looking down that tunnel...
Stefan
Date: 9 Feb 2007 07:10:01
Message: <web.45cc636ec270a2ddd42597a60@news.povray.org>
Great effect, the image would look even better with a bit of focal blur but
I guess with that many light sources and objects you would need all the
computers in the world to render it... How long did the render take?
Date: 11 Feb 2007 10:00:01
Message: <web.45cf2f40c270a2ddda0e3250@news.povray.org>
About one and half minute, few time... I haven't enought pacience to wait a
slow render (more than 5 minutes)
My computer is a AMD Athon 2000 with 384 RAM and w2000 SP4 server
I will try render with focal blur
Render Statistics
Image Resolution 800 x 600
Pixels:           480605   Samples:          480605   Smpls/Pxl: 1.00
Rays:            1298034   Saved:                 0   Max Level: 5/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                            5213875         2836905     54.41
Plane                          2595998         1303580     50.21
Bounding Box                  67389996        21921815     32.53
Vista Buffer                  27031790        16349486     60.48
Calls to Noise:                   0   Calls to DNoise:              10
Reflected Rays:               17634
Radiosity samples calculated:            24149 (1.89 %)
Radiosity samples reused:              1255828
Smallest Alloc:                  18 bytes
Largest  Alloc:               75016 bytes
Peak memory used:          16025694 bytes
Total Scene Processing Times
  Parse Time:    0 hours  0 minutes  2 seconds (2 seconds)
  Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Render Time:   0 hours  1 minutes 28 seconds (88 seconds)
  Total Time:    0 hours  1 minutes 30 seconds (90 seconds)
CPU time used: kernel 0.48 seconds, user 86.86 seconds, total 87.34 seconds
Render averaged 5495.53 PPS over 480000 pixels
POV-Ray finished
Date: 11 Feb 2007 18:40:01
Message: <web.45cfa917c270a2ddda0e3250@news.povray.org>
Focal blur version, time render 495 secs ~ 8 mins 15 segs
Download '0008b.png' (508 KB)
Preview of image '0008b.png'
Date: 15 Feb 2007 18:05:01
Message: <web.45d4e64dc270a2dd498d62b30@news.povray.org>
Here's mine. I could've bumped it up and squeezed more cubes into each ring,
but I'm not a CPU sadist. 2 minutes 30 seconds at 800x600 with 0.1
antialiasing
//Lots of objects in little code
#macro circ (a)
  #declare i = 25;
  object {
    union {
      #while (i>0)
      box {-.07,.07
        pigment { color rgb .5 }
        translate 1*z
        rotate i*(360/25)*y
      #declare i = i-1;
      #if (mod(a,10)=0)
      light_source {<0,0,2>
        color rgb <.2,.2,.6>
      light_source {<0,0,0>
        color rgb <.2,.6,.2>
    translate (a/8)*x + 2*z
    rotate (360/40)*a*x
#declare j = 140;
#while (j>=-140)
  circ(j)
  #declare j = j-1;
  location 6
  look_at  0
Here's all the render stats (minus the configuration information at the
beginning):
Scene Statistics
  Finite objects:         7025
  Infinite objects:          0
  Light sources:            58
  Total:                  7083
Render Statistics
Pixels:           480800   Samples:         1944040   Smpls/Pxl: 4.04
Rays:            1944040   Saved:                 0   Max Level: 1/5
Box                           75278235        34041790     45.22
Bounding Box                  74833731        40966070     54.74
Light Buffer                1434219443       383715398     26.75
Vista Buffer                  77198516        42158149     54.61
Shadow Ray Tests:          58571546   Succeeded:              32576089
Largest  Alloc:               56216 bytes
Peak memory used:          35698021 bytes
  Parse Time:    0 hours  0 minutes  5 seconds (5 seconds)
  Cloth Time:    0 hours  0 minutes  0 seconds (0 seconds)
  Mechsim Time:  0 hours  0 minutes  0 seconds (0 seconds)
  Render Time:   0 hours  2 minutes 25 seconds (145 seconds)
  Postpr. Time:  0 hours  0 minutes  0 seconds (0 seconds)
  Total Time:    0 hours  2 minutes 30 seconds (150 seconds)
CPU time used: kernel 0.50 seconds, user 138.52 seconds, total 139.02
seconds
Render averaged 3452.85 PPS over 480000 pixels
POV-Ray finished
(yes I use MegaPOV, I never bother switching back and forth since MegaPOV is
fully back-compatible)
I think this is an elementary example of how powerful lightsources are. As
you can see, there are only 58 lightsources in a scene full of thousands of
boxes and it looks fully lit.
Download 'lotsofobjects.png' (505 KB)
Preview of image 'lotsofobjects.png'
