POV-Ray : Newsgroups : povray.binaries.images : Mesh2 shadow problem... Server Time
14 Apr 2026 09:12:15 EDT (-0400)
  Mesh2 shadow problem... (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Mesh2 shadow problem...
Date: 21 Nov 2006 04:15:21
Message: <4562c3a9@news.povray.org>
Looks like smooth triangle artifacts:
	http://tag.povray.org/povQandT/SmoothTriangleArtifact/index.html
HTH,
Florian
Date: 21 Nov 2006 04:45:01
Message: <web.4562c9e1aedcdc51f50fb4000@news.povray.org>
> Hasan,
> Looking at your image, I think that the sphere needs a couple of
> subdivisions more. Have you tried that, by applying smooth a couple of
> times?
> Thomas
Thomas, right, more subdivision solve this problem, but it creates extra
unnecessery vertex points. is there another way?
Date: 21 Nov 2006 08:14:10
Message: <4562fba2$1@news.povray.org>
"Hasan3" <PRO### [at] Yahoocom> schreef in bericht
news:web.4562c9e1aedcdc51f50fb4000@news.povray.org...
Well, in addition, there might be the problem mentioned by zorglub and
Florian. Have a look at the mentioned documentation.
Date: 21 Nov 2006 08:31:41
Message: <4562ffbd$1@news.povray.org>
  No, that's not it. The correct url is:
http://tag.povray.org/povQandT/TheShadowLineArtifact/index.html
Date: 21 Nov 2006 08:37:06
Message: <45630102$1@news.povray.org>
Ah, OK. Thanks for pointing that out.
Florian
Date: 21 Nov 2006 11:27:46
Message: <45632902$1@news.povray.org>
How about replacing the mesh with
    sphere{0, 1}
In all seriousness, POVRay SDL is extremely powerful and renders MUCH faster
than meshes!
Rarius
"Hasan3" <PRO### [at] Yahoocom> wrote in message
> "Thomas de Groot" <t.d### [at] internlDOTnet> wrote:
>> Hasan,
>> times?
>> Thomas
Date: 21 Nov 2006 15:40:00
Message: <web.45636351aedcdc5124db0b270@news.povray.org>
Warp, thanks, I will read this article...
Regards.
Hasan
Date: 21 Nov 2006 16:10:01
Message: <web.456369f2aedcdc5124db0b270@news.povray.org>
> Regards,
> Florian
Florian, thanks for explanation. I have read this article :
"Firstly, don't think that it is a bug in POV-Ray. It isn't a bug, but a
real problem caused be the lighting model used in the renderer engine that
is quite difficult to surpass. It's not a problem in POV-Ray in particular,
but a problem in raytracing in general. Every raytracer will have this same
problem when using perturbed surface normals (unless there's some fix coded
into it)."
I rendered this object with other engines, for example Yafray :
I think, this is a deficiency for Povray..
Hasan
Download 'sphere2.jpg' (21 KB)
Preview of image 'sphere2.jpg'
Date: 28 Nov 2006 16:00:00
Message: <web.456ca28aaedcdc517d55e4a40@news.povray.org>
> into it)."
Clearly, the other engines have a fix for this coded in. But it is a problem
with the raytracing algorithm and modified normals, rather than a defect in
the way POV implements the algorithm (a bug).
I think there is at least one unofficial version of POV with a fix for this.
I think Slime-POV had one (but IIRC it's based on POV 3.5). There may be
others.
Tom
Date: 28 Nov 2006 16:10:01
Message: <web.456ca53baedcdc517d55e4a40@news.povray.org>
POV-Sub, a modification of 3.6, might be able to fix this via run-time
subdivision:
http://www.cise.ufl.edu/~xwu/Pov-Sub/
It's still subdivision but your modelling software won't be generating the
extra faces.
