POV-Ray : Newsgroups : povray.binaries.images : Mesh2 shadow problem... Server Time
14 Apr 2026 13:16:38 EDT (-0400)
  Mesh2 shadow problem... (Message 1 to 10 of 13)
Subject: Mesh2 shadow problem...
Date: 21 Nov 2006 03:10:00
Message: <web.4562b32dcbcd599df50fb4000@news.povray.org>
There is a problem at the mesh2 object. shadow of the surface is flat. it
must be smooth. isn't it? (Sphere is made wings3d.) Source:
Regards.
Hasan
// Exported from Wings 3D 0.98.35
global_settings {
  ambient_light <0.000000, 0.000000, 0.000000>
// radiosity (global illumination) settings
  radiosity {
    pretrace_start 0.08           // start pretrace at this size
    pretrace_end   0.04           // end pretrace at this size
    count 35                      // higher -> higher quality (1..1600) [35]
    nearest_count 5               // higher -> higher quality (1..10) [5]
    error_bound 1.8               // higher -> smoother, less accurate [1.8]
    recursion_limit 3             // how much interreflections are
calculated (1..5+) [3]
    low_error_factor .5           // reduce error_bound during last pretrace
step
    gray_threshold 0.0            // increase for weakening colors (0..1)
[0]
    minimum_reuse 0.015           // reuse of old radiosity samples [0.015]
    brightness 1                  // brightness of radiosity effects (0..1)
[1]
    adc_bailout 0.01/2
    //normal on                   // take surface normals into account [off]
    //media on                    // take media into account [off]
    //save_file "file_name"       // save radiosity data
    //load_file "file_name"       // load saved radiosity data
    //always_sample off           // turn sampling in final trace off [on]
    //max_sample 1.0              // maximum brightness of samples
  perspective
  location <5.1268510564, 3.3809460939, 5.1268510564>
  right < -1.33333, 0, 0>
  look_at <0.0000000000, 0.0000000000, 0.0000000000>
  angle 45.0000
light_source {
  <-5.23685, 3.38095 6.12085>
  rgb <0.700000, 0.700000, 0.700000>
  parallel
  point_at <0.00000e+0, 0.00000e+0, 0.00000e+0>
  media_interaction
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
#declare default_WingsMat =
  texture{
      pigment{ rgbf <1.00000, 1.00000, 1.00000, 0.00000e+0>}
      finish{
        ambient rgb <1.00000, 1.00000, 1.00000>
        diffuse 0.600000
        brilliance 1.00000
        specular 0.500000 roughness 0.100000
#declare sphere1 = mesh2 {
vertex_vectors
{114,<0.382683,0.923880,0.00000e+0>,<0.353553,0.923880,0.146447>,<0.270598,0.923880,0.270598>,<0.146447,0.923880,0.3535
53>,<2.34318e-17,0.923880,0.382683>,<-0.146447,0.923880,0.353553>,<-0.270598,0.923880,0.270598>,<-0.353553,0.923880,0.1
46447>,<-0.382683,0.923880,4.68637e-17>,<-0.353553,0.923880,-0.146447>,<-0.270598,0.923880,-0.270598>,<-0.146447,0.9238
80,-0.353553>,<-7.02955e-17,0.923880,-0.382683>,<0.146447,0.923880,-0.353553>,<0.270598,0.923880,-0.270598>,<0.353553,0
.923880,-0.146447>,<0.707107,0.707107,0.00000e+0>,<0.653281,0.707107,0.270598>,<0.500000,0.707107,0.500000>,<0.270598,0
.707107,0.653281>,<4.32964e-17,0.707107,0.707107>,<-0.270598,0.707107,0.653281>,<-0.500000,0.707107,0.500000>,<-0.65328
1,0.707107,0.270598>,<-0.707107,0.707107,8.65927e-17>,<-0.653281,0.707107,-0.270598>,<-0.500000,0.707107,-0.500000>,<-0
.270598,0.707107,-0.653281>,<-1.29889e-16,0.707107,-0.707107>,<0.270598,0.707107,-0.653281>,<0.500000,0.707107,-0.50000
0>,<0.653281,0.707107,-0.270598>,<0.923880,0.382683,0.00000e+0>,<0.853553,0.382683,0.353553>,<0.653281,0.382683,0.65328
1>,<0.353553,0.382683,0.853553>,<5.65694e-17,0.382683,0.923880>,<-0.353553,0.382683,0.853553>,<-0.653281,0.382683,0.653
281>,<-0.853553,0.382683,0.353553>,<-0.923880,0.382683,1.13139e-16>,<-0.853553,0.382683,-0.353553>,<-0.653281,0.382683,
-0.653281>,<-0.353553,0.382683,-0.853553>,<-1.69708e-16,0.382683,-0.923880>,<0.353553,0.382683,-0.853553>,<0.653281,0.3
82683,-0.653281>,<0.853553,0.382683,-0.353553>,<1.00000,6.12303e-17,0.00000e+0>,<0.923880,6.12303e-17,0.382683>,<0.7071
07,6.12303e-17,0.707107>,<0.382683,6.12303e-17,0.923880>,<6.12303e-17,6.12303e-17,1.00000>,<-0.382683,6.12303e-17,0.923
880>,<-0.707107,6.12303e-17,0.707107>,<-0.923880,6.12303e-17,0.382683>,<-1.00000,6.12303e-17,1.22461e-16>,<-0.923880,6.
12303e-17,-0.382683>,<-0.707107,6.12303e-17,-0.707107>,<-0.382683,6.12303e-17,-0.923880>,<-1.83691e-16,6.12303e-17,-1.0
0000>,<0.382683,6.12303e-17,-0.923880>,<0.707107,6.12303e-17,-0.707107>,<0.923880,6.12303e-17,-0.382683>,<0.923880,-0.3
82683,0.00000e+0>,<0.853553,-0.382683,0.353553>,<0.653281,-0.382683,0.653281>,<0.353553,-0.382683,0.853553>,<5.65694e-1
7,-0.382683,0.923880>,<-0.353553,-0.382683,0.853553>,<-0.653281,-0.382683,0.653281>,<-0.853553,-0.382683,0.353553>,<-0.
923880,-0.382683,1.13139e-16>,<-0.853553,-0.382683,-0.353553>,<-0.653281,-0.382683,-0.653281>,<-0.353553,-0.382683,-0.8
53553>,<-1.69708e-16,-0.382683,-0.923880>,<0.353553,-0.382683,-0.853553>,<0.653281,-0.382683,-0.653281>,<0.853553,-0.38
2683,-0.353553>,<0.707107,-0.707107,0.00000e+0>,<0.653281,-0.707107,0.270598>,<0.500000,-0.707107,0.500000>,<0.270598,-
0.707107,0.653281>,<4.32964e-17,-0.707107,0.707107>,<-0.270598,-0.707107,0.653281>,<-0.500000,-0.707107,0.500000>,<-0.6
53281,-0.707107,0.270598>,<-0.707107,-0.707107,8.65927e-17>,<-0.653281,-0.707107,-0.270598>,<-0.500000,-0.707107,-0.500
000>,<-0.270598,-0.707107,-0.653281>,<-1.29889e-16,-0.707107,-0.707107>,<0.270598,-0.707107,-0.653281>,<0.500000,-0.707
107,-0.500000>,<0.653281,-0.707107,-0.270598>,<0.382683,-0.923880,0.00000e+0>,<0.353553,-0.923880,0.146447>,<0.270598,-
0.923880,0.270598>,<0.146447,-0.923880,0.353553>,<2.34318e-17,-0.923880,0.382683>,<-0.146447,-0.923880,0.353553>,<-0.27
0598,-0.923880,0.270598>,<-0.353553,-0.923880,0.146447>,<-0.382683,-0.923880,4.68637e-17>,<-0.353553,-0.923880,-0.14644
7>,<-0.270598,-0.923880,-0.270598>,<-0.146447,-0.923880,-0.353553>,<-7.02955e-17,-0.923880,-0.382683>,<0.146447,-0.9238
80,-0.353553>,<0.270598,-0.923880,-0.270598>,<0.353553,-0.923880,-0.146447>,<0.00000e+0,1.00000,0.00000e+0>,<0.00000e+0
,-1.00000,0.00000e+0>}
normal_vectors
{114,<0.382195,0.924082,2.83959e-16>,<0.395277,0.907921,0.139414>,<0.312929,0.896745,0.312929>,<0.139414,0.907921,0.395
277>,<-7.09898e-18,0.924082,0.382195>,<-0.139414,0.907921,0.395277>,<-0.312929,0.896745,0.312929>,<-0.395277,0.907921,0
.139414>,<-0.382195,0.924082,2.02321e-16>,<-0.395277,0.907921,-0.139414>,<-0.312929,0.896745,-0.312929>,<-0.139414,0.90
7921,-0.395277>,<2.24640e-2,0.907921,-0.418540>,<0.146260,0.924082,-0.353102>,<0.312929,0.896745,-0.312929>,<0.395277,0
.907921,-0.139414>,<0.686014,0.727193,2.39708e-2>,<0.617517,0.734948,0.280222>,<0.531679,0.659268,0.531679>,<0.261932,0
.707599,0.656274>,<9.49274e-18,0.752769,0.658285>,<-0.261932,0.707599,0.656274>,<-0.531679,0.659268,0.531679>,<-0.65627
4,0.707599,0.261932>,<-0.658285,0.752769,4.50905e-16>,<-0.656274,0.707599,-0.261932>,<-0.531679,0.659268,-0.531679>,<-0
.261932,0.707599,-0.656274>,<9.15141e-3,0.707599,-0.706555>,<0.251915,0.752769,-0.608176>,<0.531679,0.659268,-0.531679>
,<0.656274,0.707599,-0.261932>,<0.907213,0.419315,-3.37492e-2>,<0.853371,0.383160,0.353478>,<0.634851,0.345848,0.690908
>,<0.348957,0.383155,0.855231>,<9.55649e-18,0.443376,0.896335>,<-0.379704,0.356654,0.853594>,<-0.690908,0.345848,0.6348
51>,<-0.825240,0.419315,0.378356>,<-0.912065,0.409068,2.83087e-2>,<-0.853594,0.356654,-0.379704>,<-0.653142,0.383160,-0
.653142>,<-0.409293,0.382443,-0.828382>,<-2.41449e-2,0.356654,-0.933924>,<0.343013,0.443376,-0.828106>,<0.669649,0.3211
55,-0.669649>,<0.855231,0.383155,-0.348957>,<0.997809,6.61589e-2,-1.19874e-16>,<0.921855,-6.61589e-2,0.381845>,<0.73407
6,3.97197e-2,0.677904>,<0.408607,-2.83931e-2,0.912269>,<-2.83931e-2,2.83931e-2,0.999194>,<-0.382683,1.44164e-17,0.92388
0>,<-0.658776,0.00000e+0,0.752339>,<-0.912269,2.83931e-2,0.408607>,<-0.999194,-2.83931e-2,-2.83931e-2>,<-0.907221,-3.97
197e-2,-0.418775>,<-0.686460,2.83931e-2,-0.726613>,<-0.320722,-1.43848e-17,-0.947173>,<3.97197e-2,-3.97197e-2,-0.998421
>,<0.381845,6.61589e-2,-0.921855>,<0.705558,-6.61589e-2,-0.705558>,<0.923880,-3.84438e-17,-0.382683>,<0.933924,-0.35665
4,-2.41449e-2>,<0.828106,-0.443376,0.343013>,<0.669649,-0.321155,0.669649>,<0.378356,-0.419315,0.825240>,<2.83087e-2,-0
.409068,0.912065>,<-0.379704,-0.356654,0.853594>,<-0.690908,-0.345848,0.634851>,<-0.855231,-0.383155,0.348957>,<-0.8963
35,-0.443376,2.00686e-16>,<-0.855231,-0.383155,-0.348957>,<-0.690908,-0.345848,-0.634851>,<-0.409293,-0.382443,-0.82838
2>,<-6.11294e-2,-0.382443,-0.921955>,<0.353478,-0.383160,-0.853371>,<0.653142,-0.383160,-0.653142>,<0.828382,-0.382443,
-0.409293>,<0.706555,-0.707599,9.15141e-3>,<0.608176,-0.752769,0.251915>,<0.531679,-0.659268,0.531679>,<0.261932,-0.707
599,0.656274>,<1.18659e-17,-0.752769,0.658285>,<-0.261932,-0.707599,0.656274>,<-0.531679,-0.659268,0.531679>,<-0.656274
,-0.707599,0.261932>,<-0.658285,-0.752769,-1.82735e-16>,<-0.656274,-0.707599,-0.261932>,<-0.531679,-0.659268,-0.531679>
,<-0.261932,-0.707599,-0.656274>,<9.15141e-3,-0.707599,-0.706555>,<0.251915,-0.752769,-0.608176>,<0.531679,-0.659268,-0
.531679>,<0.656274,-0.707599,-0.261932>,<0.418540,-0.907921,2.24640e-2>,<0.353102,-0.924082,0.146260>,<0.312929,-0.8967
45,0.312929>,<0.139414,-0.907921,0.395277>,<7.09898e-18,-0.924082,0.382195>,<-0.139414,-0.907921,0.395277>,<-0.312929,-
0.896745,0.312929>,<-0.395277,-0.907921,0.139414>,<-0.382195,-0.924082,-4.33038e-16>,<-0.395277,-0.907921,-0.139414>,<-
0.312929,-0.896745,-0.312929>,<-0.139414,-0.907921,-0.395277>,<2.24640e-2,-0.907921,-0.418540>,<0.146260,-0.924082,-0.3
53102>,<0.312929,-0.896745,-0.312929>,<0.395277,-0.907921,-0.139414>,<-7.08016e-18,1.00000,-4.33660e-17>,<-8.85020e-18,
-1.00000,-6.23939e-17>}
texture_list { 1,
 texture { default_WingsMat }
face_indices
{224,<0,16,15>,0,<0,112,1>,0,<1,17,16>,0,<1,112,2>,0,<2,3,19>,0,<2,18,17>,0,<2,112,3>,0,<3,4,20>,0,<3,112,4>,0,<4,112,5
>,0,<5,20,4>,0,<5,21,20>,0,<5,112,6>,0,<6,7,23>,0,<6,21,5>,0,<6,22,21>,0,<6,112,7>,0,<7,8,24>,0,<7,112,8>,0,<8,112,9>,0
,<9,24,8>,0,<9,25,24>,0,<9,112,10>,0,<10,25,9>,0,<10,26,25>,0,<10,112,11>,0,<11,27,10>,0,<11,112,12>,0,<12,28,11>,0,<12
,112,13>,0,<13,29,12>,0,<13,112,14>,0,<14,30,29>,0,<14,112,15>,0,<15,31,14>,0,<15,112,0>,0,<16,0,1>,0,<16,31,15>,0,<16,
32,31>,0,<17,1,2>,0,<17,33,16>,0,<18,19,35>,0,<18,34,33>,0,<19,18,2>,0,<19,20,36>,0,<20,19,3>,0,<21,36,20>,0,<21,37,36>
,0,<22,23,39>,0,<22,37,21>,0,<22,38,37>,0,<23,22,6>,0,<23,24,40>,0,<24,23,7>,0,<25,40,24>,0,<25,41,40>,0,<26,41,25>,0,<
26,42,41>,0,<27,26,10>,0,<27,43,26>,0,<28,27,11>,0,<28,44,27>,0,<29,13,14>,0,<29,28,12>,0,<29,45,28>,0,<30,46,45>,0,<31
,30,14>,0,<31,47,30>,0,<32,47,31>,0,<33,17,18>,0,<33,32,16>,0,<33,34,50>,0,<33,49,48>,0,<34,35,51>,0,<35,34,18>,0,<35,3
6,52>,0,<36,35,19>,0,<37,38,54>,0,<37,52,36>,0,<37,53,52>,0,<38,39,55>,0,<39,38,22>,0,<40,39,23>,0,<40,55,39>,0,<40,56,
55>,0,<41,42,58>,0,<41,56,40>,0,<41,57,56>,0,<43,42,26>,0,<43,59,58>,0,<44,43,27>,0,<44,60,59>,0,<45,29,30>,0,<45,44,28
>,0,<45,61,44>,0,<46,47,63>,0,<46,62,61>,0,<47,32,48>,0,<47,46,30>,0,<48,32,33>,0,<48,63,47>,0,<49,50,66>,0,<49,65,64>,
0,<50,49,33>,0,<51,50,34>,0,<51,52,68>,0,<51,67,66>,0,<52,51,35>,0,<52,53,69>,0,<54,53,37>,0,<54,70,69>,0,<55,54,38>,0,
<55,71,70>,0,<56,57,73>,0,<56,71,55>,0,<56,72,71>,0,<57,58,74>,0,<58,42,43>,0,<58,57,41>,0,<58,59,75>,0,<59,43,44>,0,<5
9,60,76>,0,<60,61,77>,0,<61,45,46>,0,<61,60,44>,0,<62,63,79>,0,<62,78,77>,0,<63,48,64>,0,<63,62,46>,0,<64,48,49>,0,<64,
79,63>,0,<64,80,95>,0,<65,81,80>,0,<66,50,51>,0,<66,65,49>,0,<66,82,65>,0,<67,82,66>,0,<67,83,82>,0,<68,67,51>,0,<68,69
,85>,0,<68,83,67>,0,<68,84,83>,0,<69,53,54>,0,<69,68,52>,0,<69,70,86>,0,<70,54,55>,0,<71,86,70>,0,<71,87,86>,0,<72,73,8
9>,0,<72,87,71>,0,<72,88,87>,0,<73,72,56>,0,<73,74,90>,0,<74,73,57>,0,<75,74,58>,0,<75,91,90>,0,<76,75,59>,0,<76,92,91>
,0,<77,61,62>,0,<77,76,60>,0,<77,93,92>,0,<78,94,77>,0,<79,78,62>,0,<79,95,94>,0,<80,64,65>,0,<80,96,111>,0,<81,97,96>,
0,<82,81,65>,0,<82,98,81>,0,<83,98,82>,0,<83,99,98>,0,<84,85,101>,0,<84,99,83>,0,<84,100,99>,0,<85,84,68>,0,<85,86,102>
,0,<86,85,69>,0,<87,102,86>,0,<87,103,102>,0,<88,89,105>,0,<88,103,87>,0,<88,104,103>,0,<89,88,72>,0,<89,90,106>,0,<90,
74,75>,0,<90,89,73>,0,<91,75,76>,0,<91,107,106>,0,<92,76,77>,0,<92,108,107>,0,<93,109,108>,0,<94,78,79>,0,<94,93,77>,0,
<94,110,93>,0,<95,79,64>,0,<95,111,110>,0,<96,80,81>,0,<96,113,111>,0,<97,113,96>,0,<98,97,81>,0,<98,113,97>,0,<99,113,
98>,0,<100,113,99>,0,<101,100,84>,0,<101,113,100>,0,<102,101,85>,0,<102,113,101>,0,<103,113,102>,0,<104,113,103>,0,<105
,104,88>,0,<105,113,104>,0,<106,90,91>,0,<106,105,89>,0,<106,113,105>,0,<107,91,92>,0,<107,113,106>,0,<108,92,93>,0,<10
8,113,107>,0,<109,113,108>,0,<110,94,95>,0,<110,109,93>,0,<110,113,109>,0,<111,95,80>,0,<111,113,110>,0}
normal_indices
{224,<0,16,15>,<0,112,1>,<1,17,16>,<1,112,2>,<2,3,19>,<2,18,17>,<2,112,3>,<3,4,20>,<3,112,4>,<4,112,5>,<5,20,4>,<5,21,2
0>,<5,112,6>,<6,7,23>,<6,21,5>,<6,22,21>,<6,112,7>,<7,8,24>,<7,112,8>,<8,112,9>,<9,24,8>,<9,25,24>,<9,112,10>,<10,25,9>
,<10,26,25>,<10,112,11>,<11,27,10>,<11,112,12>,<12,28,11>,<12,112,13>,<13,29,12>,<13,112,14>,<14,30,29>,<14,112,15>,<15
,31,14>,<15,112,0>,<16,0,1>,<16,31,15>,<16,32,31>,<17,1,2>,<17,33,16>,<18,19,35>,<18,34,33>,<19,18,2>,<19,20,36>,<20,19
,3>,<21,36,20>,<21,37,36>,<22,23,39>,<22,37,21>,<22,38,37>,<23,22,6>,<23,24,40>,<24,23,7>,<25,40,24>,<25,41,40>,<26,41,
25>,<26,42,41>,<27,26,10>,<27,43,26>,<28,27,11>,<28,44,27>,<29,13,14>,<29,28,12>,<29,45,28>,<30,46,45>,<31,30,14>,<31,4
7,30>,<32,47,31>,<33,17,18>,<33,32,16>,<33,34,50>,<33,49,48>,<34,35,51>,<35,34,18>,<35,36,52>,<36,35,19>,<37,38,54>,<37
,52,36>,<37,53,52>,<38,39,55>,<39,38,22>,<40,39,23>,<40,55,39>,<40,56,55>,<41,42,58>,<41,56,40>,<41,57,56>,<43,42,26>,<
43,59,58>,<44,43,27>,<44,60,59>,<45,29,30>,<45,44,28>,<45,61,44>,<46,47,63>,<46,62,61>,<47,32,48>,<47,46,30>,<48,32,33>
,<48,63,47>,<49,50,66>,<49,65,64>,<50,49,33>,<51,50,34>,<51,52,68>,<51,67,66>,<52,51,35>,<52,53,69>,<54,53,37>,<54,70,6
9>,<55,54,38>,<55,71,70>,<56,57,73>,<56,71,55>,<56,72,71>,<57,58,74>,<58,42,43>,<58,57,41>,<58,59,75>,<59,43,44>,<59,60
,76>,<60,61,77>,<61,45,46>,<61,60,44>,<62,63,79>,<62,78,77>,<63,48,64>,<63,62,46>,<64,48,49>,<64,79,63>,<64,80,95>,<65,
81,80>,<66,50,51>,<66,65,49>,<66,82,65>,<67,82,66>,<67,83,82>,<68,67,51>,<68,69,85>,<68,83,67>,<68,84,83>,<69,53,54>,<6
9,68,52>,<69,70,86>,<70,54,55>,<71,86,70>,<71,87,86>,<72,73,89>,<72,87,71>,<72,88,87>,<73,72,56>,<73,74,90>,<74,73,57>,
<75,74,58>,<75,91,90>,<76,75,59>,<76,92,91>,<77,61,62>,<77,76,60>,<77,93,92>,<78,94,77>,<79,78,62>,<79,95,94>,<80,64,65
>,<80,96,111>,<81,97,96>,<82,81,65>,<82,98,81>,<83,98,82>,<83,99,98>,<84,85,101>,<84,99,83>,<84,100,99>,<85,84,68>,<85,
86,102>,<86,85,69>,<87,102,86>,<87,103,102>,<88,89,105>,<88,103,87>,<88,104,103>,<89,88,72>,<89,90,106>,<90,74,75>,<90,
89,73>,<91,75,76>,<91,107,106>,<92,76,77>,<92,108,107>,<93,109,108>,<94,78,79>,<94,93,77>,<94,110,93>,<95,79,64>,<95,11
1,110>,<96,80,81>,<96,113,111>,<97,113,96>,<98,97,81>,<98,113,97>,<99,113,98>,<100,113,99>,<101,100,84>,<101,113,100>,<
102,101,85>,<102,113,101>,<103,113,102>,<104,113,103>,<105,104,88>,<105,113,104>,<106,90,91>,<106,105,89>,<106,113,105>
,<107,91,92>,<107,113,106>,<108,92,93>,<108,113,107>,<109,113,108>,<110,94,95>,<110,109,93>,<110,113,109>,<111,95,80>,<
111,113,110>}
sphere1
Download 'sphere.jpg' (18 KB)
Preview of image 'sphere.jpg'
Subject: Re: Mesh2 shadow problem...
Date: 21 Nov 2006 03:48:52
Message: <4562bd74$1@news.povray.org>
"Hasan3" <PRO### [at] Yahoocom> schreef in bericht
news:web.4562b32dcbcd599df50fb4000@news.povray.org...
> Hi,
> Regards.
> Hasan
Hasan,
Looking at your image, I think that the sphere needs a couple of
subdivisions more. Have you tried that, by applying smooth a couple of
times?
Date: 21 Nov 2006 04:13:18
Message: <4562c32e$1@news.povray.org>
> Hi,
> Regards.
> Hasan
This problem is describe in the official documentation at :
"2.4.8  The shadow line artifact"
Date: 21 Nov 2006 04:15:21
Message: <4562c3a9@news.povray.org>
Looks like smooth triangle artifacts:
	http://tag.povray.org/povQandT/SmoothTriangleArtifact/index.html
HTH,
Florian
Date: 21 Nov 2006 04:45:01
Message: <web.4562c9e1aedcdc51f50fb4000@news.povray.org>
> Hasan,
> times?
> Thomas
Thomas, right, more subdivision solve this problem, but it creates extra
unnecessery vertex points. is there another way?
Date: 21 Nov 2006 08:14:10
Message: <4562fba2$1@news.povray.org>
news:web.4562c9e1aedcdc51f50fb4000@news.povray.org...
Well, in addition, there might be the problem mentioned by zorglub and
Florian. Have a look at the mentioned documentation.
Date: 21 Nov 2006 08:31:41
Message: <4562ffbd$1@news.povray.org>
  No, that's not it. The correct url is:
http://tag.povray.org/povQandT/TheShadowLineArtifact/index.html
Date: 21 Nov 2006 08:37:06
Message: <45630102$1@news.povray.org>
Ah, OK. Thanks for pointing that out.
Florian
Date: 21 Nov 2006 11:27:46
Message: <45632902$1@news.povray.org>
How about replacing the mesh with
    sphere{0, 1}
In all seriousness, POVRay SDL is extremely powerful and renders MUCH faster
than meshes!
Rarius
"Hasan3" <PRO### [at] Yahoocom> wrote in message
> "Thomas de Groot" <t.d### [at] internlDOTnet> wrote:
>> Hasan,
>> times?
>> Thomas
Date: 21 Nov 2006 15:40:00
Message: <web.45636351aedcdc5124db0b270@news.povray.org>
Warp, thanks, I will read this article...
Regards.
Hasan
