Florian Brucker <tor### [at] torfbold com> wrote:
> > Florian Brucker wrote:
> >> Looks like smooth triangle artifacts:
> > No, that's not it. The correct url is:
> > http://tag.povray.org/povQandT/TheShadowLineArtifact/index.html
> Ah, OK. Thanks for pointing that out.
> Regards,
> Florian
Florian, thanks for explanation. I have read this article :
"Firstly, don't think that it is a bug in POV-Ray. It isn't a bug, but a
real problem caused be the lighting model used in the renderer engine that
is quite difficult to surpass. It's not a problem in POV-Ray in particular,
but a problem in raytracing in general. Every raytracer will have this same
problem when using perturbed surface normals (unless there's some fix coded
into it)."
I rendered this object with other engines, for example Yafray :
I think, this is a deficiency for Povray..
Hasan
Download 'sphere2.jpg' (21 KB)
Preview of image 'sphere2.jpg'
> into it)."
Clearly, the other engines have a fix for this coded in. But it is a problem
with the raytracing algorithm and modified normals, rather than a defect in
the way POV implements the algorithm (a bug).
I think there is at least one unofficial version of POV with a fix for this.
I think Slime-POV had one (but IIRC it's based on POV 3.5). There may be
others.
Tom
