POV-Ray : Newsgroups : povray.binaries.images : HRDI, Radiosity and Jewelled Box Server Time
14 Apr 2026 19:01:24 EDT (-0400)
  HRDI, Radiosity and Jewelled Box (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: HRDI, Radiosity and Jewelled Box
Date: 19 Sep 2006 09:20:00
Message: <web.450fedd46712a6763f8b2b040@news.povray.org>
"Janet" <par### [at] attnet> wrote:
> I tried HDRI and I love it! I am wondering how it really works. This
> probably sounds dumb, but I'm assuming radiosity is required for HDRI, can
> someone confirm this??
> I did use radiosity, no lights, for this image. The box was modelled in
> Blender. I put a bump_map on the box top surface.
> I found a bunch of free HDRI maps at these links:
> http://www.deviantart.com/deviation/10152791/
> http://www.deviantart.com/deviation/10036562/
> http://www.deviantart.com/deviation/9597501/
Nice image, I find a combination of HDR and a light source still help for
getting good specular highlights.
Thanks for the links, that's a nice selection of HDR image samples.
Sean
Date: 19 Sep 2006 15:39:02
Message: <45104756@news.povray.org>
"Janet" <par### [at] attnet> wrote in message
news:web.450f7678bbaad40792c96d80@news.povray.org...
   As far as I know, HDRI works with, and without.  :)
    The gems look like a cabochon cut (smooth on the upper surface instead
of faceted). Maybe a little more ior would make them stand out more? They
look a little 'ghostly' at the moment?
    Nice work. You'd make a good jewellery designer.
     ~Steve~
Date: 19 Sep 2006 20:50:00
Message: <web.45108ef86712a6761851e3680@news.povray.org>
> A very nice piece of work. The blue jewels are especially attractive. I just
> read ( in news@nature) about the liquid phase of oxygen, formed under high
> pressure: a pale blue, magnetic substance. This reminds me of that.
> I have been playing a bit with HDRI, but not enough to know much about it.
> Thomas
Thanks, HDRI is interesting. You can get really different results with
different hdr files. Hmmm, what's the ior of liquid oxygen? :)
Date: 19 Sep 2006 21:40:01
Message: <web.45109bd96712a6761851e3680@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote:
> Nice.
> Have a look at this site, it has some good explainations of HDRI.
> http://www.highpoly3d.com/writer/tutorials/hdri/hdri.htm
> HDRI is useful for radiosity, but is not limited to it.  It is also useful
> for plain environment mapping where it's reflections and other effects (eg,
> motion blur) are much more effective than standard low dynamic range images.
> Some more freebies (these are actually ones that I made):
> http://www.deviantart.com/deviation/27943328/
> http://www.deviantart.com/deviation/28753146/
> http://www.deviantart.com/deviation/36091025
> -tgq
Thanks Trevor. It seeems like either radiosity or a light source help a LOT
with HDRI, at least with POV-Ray. I like your HDRI maps, and they're made a
lot better too. The living room - nice - lots of toys. :)
Date: 19 Sep 2006 21:45:01
Message: <web.45109ca26712a6761851e3680@news.povray.org>
> Sean
Thanks Sean. I like your idea. I guess the best thing to do is whatever
looks the best.
Date: 19 Sep 2006 21:55:00
Message: <web.45109f0e6712a6761851e3680@news.povray.org>
Well, if you don't have any other light sources, and use non-reflective
objects in your scene, it seems like you have to use radiosity.
I should try with ior, I was thinking that, but I got lazy. Plus, the
polygon count on this model is HUGE. It takes forever just to try stuff
out.
Anyway, I'm glad I posted this image, I am getting some good ideas from all
you nice guys.
Sean, aka s day, says "I find a combination of HDR and a light source still
help for getting good specular highlights."
So, yes, I should try these ideas.
Thanks!
Date: 19 Sep 2006 22:18:15
Message: <4510a4e7$1@news.povray.org>
Janet,
beautiful...
liquid oxygen IOR=1.221
see http://www.webelements.com/webelements/elements/text/O/phys.html
for phyical properties.
DLM
Date: 19 Sep 2006 22:25:00
Message: <web.4510a6406712a6761851e3680@news.povray.org>
"dlm" <me### [at] addressinvalid> wrote:
> Janet,
> beautiful...
> DLM
That cracked me up! Thanks DLM. I'll give it a go then.
Date: 20 Sep 2006 13:40:00
Message: <web.45117c366712a676c150d4c10@news.povray.org>
> > -tgq
Thanks.  They were assembled from several exposures at 2 views to get a good
dynamic range and sampling for the full 360deg.
An HDRI on it's own won't illuminate a scene, so for this you do need
radiosity (or other methods, one of which I have been working on for quite
some time).
However, they also make good environment maps simply for background and
reflective purposes, using your own scene lighting.  For this radiosity is
not necessary.
-tgq
Date: 26 Sep 2006 13:42:23
Message: <4519667f$1@news.povray.org>
news:web.45109f0e6712a6761851e3680@news.povray.org...
    Looking forward to the next generation, Janet!  :o)
     ~Steve~
> Thanks!
