"Bill Pragnell" <bil### [at] hotmail com> wrote:
> I too would be grateful for a peek at the source!
> Bill
Ask and you shall receive. I upload it on one condition though: I want to
see what you do with it!
The main parameter is the size of the tiling. A setting of 4 is fine for
renders from a distance.
#include "rand.inc"
#include "rad_def.inc"
#include "functions.inc"
#declare num_phi1=8;
// number of points along 90 degrees of the
// major torus axis
#declare ninetydeginrads=3.14159265358/2;
#declare mytexture= texture {
pigment { color rgb <1, 1, 1> }
finish {
ambient color rgb <0, 0, 0>
diffuse 1
// The functions defining the transformation of the 3D Trouchet tiling
#declare point_trans_x=function(x,y,z) {
x/max(1e-8,x*x+y*y+z*z)
#declare point_trans_y=function(x,y,z) {
y/max(1e-8,x*x+y*y+z*z)
#declare point_trans_z=function(x,y,z) {
z/max(1e-8,x*x+y*y+z*z)
// This generates points of one quarter torus
// trans, rot is used for positioning the torus whithin the origin tile
// trans2, rot2 is used for translating/rotating the final tile
#macro _quarter_torus_tris(trans,rot,trans2,rot2)
#declare _phi1 = -ninetydeginrads/num_phi1;
#while (_phi1<=ninetydeginrads+ninetydeginrads/num_phi1)
#declare p1 =
vrotate(vrotate(<sin(_phi1),-cos(_phi1)+1,0>,rot)+trans,rot2)+trans2;
#declare p1 =
<point_trans_x(p1.x,p1.y,p1.z),point_trans_y(p1.x,p1.y,p1.z),point_trans_z(p1.x,p1.y,p1.z)>;
p1,0.2*max(1e-8,pow(p1.x,2)+pow(p1.y,2)+pow(p1.z,2))
#declare _phi1 = _phi1 + ninetydeginrads/num_phi1;
// This generates the sphere sweeps for one complete
// tile with 3 quarter tori
#macro Trouchet_Tile(trans,rot)
union {
sphere_sweep {
cubic_spline
num_phi1+3,
_quarter_torus_tris(<-1,0,0>,0,trans,rot)
tolerance 0.01
texture{ mytexture}
sphere_sweep {
cubic_spline
num_phi1+3,
_quarter_torus_tris(<1,0,-0>,<90,180,0>,trans,rot)
tolerance 0.01
texture{ mytexture}
sphere_sweep {
cubic_spline
num_phi1+3,
_quarter_torus_tris(<0,0,1>,<0,90,180>,trans,rot)
tolerance 0.01
texture{ mytexture}
scale 30
// The seed for the 3D tiling
#declare rotseed=seed(2345143);
// This is the size of the tiling in cubes along
// each axis. Should be a multiple of 2.
#declare _size=4;
union{
#declare _x=-_size/2;
#while (_x<=_size/2)
#declare _y=-_size/2;
#while (_y<=_size/2)
#declare _z=-_size/2;
#while (_z<=_size/2)
#declare rx=int(RRand(0,3,rotseed))-1;
#declare ry=int(RRand(0,3,rotseed))-1;
#declare rz=int(RRand(0,3,rotseed))-1;
// Here I remove the central tile before the
// inversion operation for aesthetic reasons
#if (_x=0)
#if (_y=0)
#if(_z=0)
#else
Trouchet_Tile( <_x,_y,_z>*2 , <rx,ry,rz>*90 )
#else
#else
#declare _z=_z+1;
#declare _y=_y+1;
#declare _x=_x+1;
location vnormalize(< 6, 2, -14>)*90
look_at <0, 0, 0>
sky_sphere {
gradient y
color_map {
[ 0.0 color rgb <1.1, 1.1, 2.> ]
[ 0.5 color rgb <0,0,0> ]
[ 1.0 color rgb <1.1, 1.1, 2.> ]
scale <1, 2, 1>
translate y
// Basic lighting
light_source { <6, 2, -14>*90 color White }
// Or for radiosity comment out the above
// light source, and use the following:
/* light_source {
<3, -5, -2>*20
color rgb <0.95, 0.78, 0.42>
area_light
10*x, 10*z,
4, 4
jitter
orient
light_source {
<0, 0, 0>
color Red
shadowless
fade_distance 10
fade_power 2
global_settings { radiosity { Rad_Settings(Radiosity_Normal, off, off) } }
