POV-Ray : Newsgroups : povray.binaries.images : Funky Granules Server Time
8 Apr 2026 08:56:57 EDT (-0400)
  Funky Granules (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Funky Granules
Date: 15 Apr 2006 07:46:15
Message: <4440dd07@news.povray.org>
> Haven't tested it with meshes but I don't expect it would work in all
cases
> as it requires the use of an inside(obj,vect) test.  I think the POV docs
> state that meshes can have an inside if they form a closed shape and you
> specify the inside_vector, but I rarely use meshes where I can get away
> with SDL, CSG or macros so haven't tried it out.
Just a note for those interested in using this on meshes:
If you've got a well-defined mesh, with which I mean it has no coincident
surfaces and no holes (which is also known as waterproof), you'd just need a
macro which'll shoot a ray in some random direction. When it hits a surface
of the mesh, continue from there and count how many times you hit a surface
on a mesh whilst travelling along the ray to the outside of the mesh. If the
resulting number is uneven, the original starting point is inside the mesh,
otherwise it's outside.
This even works for multiple mesh objects that intersect, but like I said,
no coincident surfaces and the meshes all have to be completely closed for
the counting to work properly.
I've done this for various things, especially my Liquid Surface Simulation
Macros to get the water to properly interact with meshes.
Tim
aka "Tim Nikias v2.0"
Date: 15 Apr 2006 09:32:11
Message: <4440f5db@news.povray.org>
Ah yes, LEGO blocks. Makes perfect sense to be used like that.
BTW, if anyone else is wondering, be sure to #include "shapes.inc" for
Extents() to work in that macro. Another thanks to Loki for sharing this.
And here's the logo put into the logo.
Download 'povlogospovlogo.jpg' (32 KB)
Preview of image 'povlogospovlogo.jpg'
Date: 15 Apr 2006 15:42:12
Message: <44414c94$1@news.povray.org>
Thanks for posting the macro. Nice render! What kind of light setup did you
use? GI, HDRI, or area light?
Date: 16 Apr 2006 04:20:01
Message: <web.4441fd94a9f0c18547cd66460@news.povray.org>
Were you referreing to my original pic?  It's radiosity-only lighting.  I
rarely use light_sources any more.
L
Date: 16 Apr 2006 08:10:01
Message: <web.444232f3a9f0c18547cd66460@news.povray.org>
Just another pic along the same lines, this one heading closer to what I
actually wanted the macro for.  This is a granularized version of an
isosurface of a granite pigment, again lit with radiosity only.  It looks a
bit 'busy' on the eye, but a bit of focal blur would no doubt clam that
down.  Was just a quick render though.
L
Download 'granule landscape.jpg' (163 KB)
Preview of image 'granule landscape.jpg'
Subject: Re: Funky Granules - granulesHF.jpg (1/1)
Date: 16 Apr 2006 10:59:06
Message: <kurtzlepirate-F0AB93.16590116042006@news.povray.org>
Download 'granules.jpg' (1 KB) Download 'granuleshf.jpg' (55 KB)
Preview of image 'granuleshf.jpg'
Date: 16 Apr 2006 18:45:46
Message: <4442c91a$1@news.povray.org>
Yes, the csg sphere on the checkered floor. I've been trying to do the same
thing with a python script, blender, and yafray. I haven't used POV in a
while. Is "radiosity-only lighting" some sort of Ambient Occlusion? In other
words, a very large sky-dome surrounds the entire scene and the object is
lit based on how much each point on the surface can see the sky?
Date: 16 Apr 2006 18:49:06
Message: <4442c9e2$1@news.povray.org>
> a
Radiosity only? I can see a very slight reddish hue on the left side of the
cubes. Is this from a gradient-colored sky?
Date: 17 Apr 2006 07:10:01
Message: <web.444376c1a9f0c185d79451f00@news.povray.org>
Yes, I light things like this quite a lot.  It can be time consuming to
render, and takes a lot of tweaking sometimes, but tends to give some nice
results.
A couple of tips.  Sometimes images lit like this can look very washed out.
Try increasing the brightness of your sky_sphere way above rgb 1,
particularly in the primary light direction, and then reduce the overall
light level using the brighness keyword in the radiosity block.  This will
tend to increase the tonal range of the lighting, but at the expense of
making any reflections look weird - you'll need to tweak things like the
'exponent' of the reflective surfaces to make them look right again.
For example, the sky_sphere I used for the iso-granite-granules image was:
    gradient x
    color_map {
      [0 rgb <5,1,0>]
      [0.2 rgb 1]
      [0.8 rgb 2]
      [1 rgb <7,7,8>]
    scale 2
    translate -x
(rotated as appropriate of course) which required a radiosity brightness of
0.6.
Also you won't get any specular highlights on surfaces as you would do with
direct lighting, but this can be countered by placing a very dim light
(i.e. rgb 0.001 or something) where the primary light would be coming from,
and then using specular values of the order of 1000.  This will give you
specular highlights as a result of the light source even though the diffuse
component is negligible.  Use light groups to make sure no other lights
affect the surface in ways you don't want.
I'm not saying this stuff is 100% brilliant, but I've used it before to get
some reasonable results.  It can be more trouble than its worth.
L
Date: 26 Feb 2014 18:30:00
Message: <web.530e7899a9f0c185ddb0c31e0@news.povray.org>
DJ Wiza <Kil### [at] sohcahtoanet> wrote:
> Awhile ago, I made a macro similar to this one, but it was based on a
> function.  It was more similar to an isosurface that approximated it
> with cubes.
> I wonder what kind of result I could get if I used a blob with spheres...
I was thinking the same thing, but in reverse.
Two copies of an object, scaled a little, intersection, then macro.
So, should get a surface coating on whatever your normal object is. Maybe tool
around a bit so it coats in a directional manner.
Thinking of trying this as an alternative engine to my surface coating
algorithm, maybe it'll use less memory or something.
Sweet macro though, and I'll certainly be tooling around with uses for it.
Ian
