POV-Ray : Newsgroups : povray.binaries.images : The lock door... Server Time
12 Apr 2026 10:38:53 EDT (-0400)
  The lock door... (Message 1 to 7 of 7)
Subject: The lock door...
Date: 12 Jan 2006 18:50:00
Message: <web.43c6eae28c8d5fb365d5d9720@news.povray.org>
Hi everybody, I'm trying with textures. This is the end test:)
Hasan
Download 'kilit2.jpg' (433 KB)
Preview of image 'kilit2.jpg'
Subject: Re: The lock door...
Date: 13 Jan 2006 01:09:43
Message: <43c74426@news.povray.org>
Hasan3 spake:
> Hasan
Love the knotholes... - warps?
Stefan Viljoen
Polar Design Solutions
Date: 13 Jan 2006 03:45:00
Message: <web.43c7681d6ad6f60f575afc100@news.povray.org>
Stefan Viljoen <spamnot@<removethis>polard.com> wrote:
> Hasan3 spake:
> > Hasan
> Stefan Viljoen
> Software Support Technician / Programmer
No warps, its nor procedural, image maps with bumps.
Only Lock's texture is procedural.
Date: 13 Jan 2006 15:18:40
Message: <43c80b20$1@news.povray.org>
Very impressive, in my opinion. Not quite perfect, but I can't put my
finger on why...
Date: 13 Jan 2006 16:26:59
Message: <43c81b23$1@news.povray.org>
> finger on why...
Looks great, the textures are just lovely.
But while we have our fingers out, there's a couple of compositions
things I'll put my finger on:
1. The two doors should come a lot closer to meeting as should the
    vertical timbers
2. There's (possibly deliberate) evenly-spaced filleting down the
    vertical timbers
3. The lock isn't held to the door in any way that will stop intrusion
	3a. The RHS needs to have bolts or hotrivet through the timber
	    - round heads on the outside (and inside if they're
	    hotrivets and the long part of the hinge normally sits over
	    the top of that part making it even harder to unbolt.
	3b. If you don't fold it over then the hinge-pin in the door
	    needs to be away from the gap between the doors so that all
	    that is exposed to the other side is flat iron
4. The doors need diagonal cross-bracing .. this holds the door up and
    will stop it sagging
(If you're going for the look of low-tech (despite the padlock) then
you'll need to make the doors sag a fair bit and increase the size of
screws and bolt to the point where they could be hand-forged)
If you don't hate me right now, care to share that timber texture?
Cheers!
Rick Measham
Date: 15 Jan 2006 11:40:00
Message: <web.43ca7a8e6ad6f60ffe4670100@news.povray.org>
Rick Measham <rickm*at%isite.net.au> wrote:
> > finger on why...
>     vertical timbers
>     vertical timbers
> Cheers!
> Rick Measham
Rick ,
You will almost write the door story.  I'm very hating you:)
this is a joke.
I have not thought to make a architectural door.
 I have wanted to realistic overlay to the timbers.
This wood texture :
http://www.monitorstudios.com/bcloward/textures/wood_boards.jpg
Regards.
Hasan
Date: 26 Feb 2006 10:15:00
Message: <web.4401c5c96ad6f60fd00d55970@news.povray.org>
The problem with the image is that the shadows/light on the stone image-map
is from the wrong side... inverse the stone image so that the light is
coming from the right instead of the left and it should look more
realistic.
