POV-Ray : Newsgroups : povray.binaries.images : A Man in a Strange World Server Time
12 Sep 2025 09:01:11 EDT (-0400)
  A Man in a Strange World (Message 1 to 10 of 10)
Subject: A Man in a Strange World
Date: 1 Nov 2005 13:50:01
Message: <web.4367b7a4781b568d530fb7fc0@news.povray.org>
It's been ages since I posted my last image. Here is my latest work, based
on an illustration by Tim White.
The scene has a huge number of objects. In order to fit into a reasonable
amount of memory the majority of them are meshes, mostly free 3ds and obj
converted to mesh2{} with PoseRay. Exceptions are the potatoe shaped things
which are isosurfaces with some "tentacles" which are blobs. The cone
shaped things on the hill are isosurfaces too. Bushes made with POVTree.
Character from Poser.
Please excuse the filesize, all the details would have been lost at smaller
sizes or higher jpg compression rates.
Regards, Christoph
Download 'strange.jpg' (370 KB)
Preview of image 'strange.jpg'
Subject: Re: A Man in a Strange World
Date: 1 Nov 2005 13:56:22
Message: <4367ba56$1@news.povray.org>
Hey, that's really neat!
I bet the render time was huge tho...
Date: 1 Nov 2005 14:55:01
Message: <web.4367c7f9eaacc993e249c31f0@news.povray.org>
Render time was about 5.5 h at 2000x1500 pixels on a 3.6 GHz P4 running
under Win XP. No radiosity and no area_lights though, just the sun and one
shadowless fill light. The slowest thing was the sky (media clouds).
Date: 1 Nov 2005 16:45:49
Message: <4367e20d$1@news.povray.org>
Hey, that's actually not a bad render time.
I'm supposed that the sky was the slow part - I would have expected all
that "grassy stuff" to take longer...
Date: 1 Nov 2005 18:44:58
Message: <4367fdfa@news.povray.org>
"gerberc" <ni.### [at] bluewinch> wrote in message
news:web.4367c7f9eaacc993e249c31f0@news.povray.org...
running
one
Hmmm, strange, the clouds aren't the most impressive part of the image
(although that's because the rest is *very* impressive).
Maybe my fastclouds might help here.  They're not really 3D, so they're
not 100% accurate, but they look good enough and render fast (see image,
rendered at 640*480 on an Athlon XP 2500+ under Windows XP, while typing
this message, in 8 seconds)
--- code: ---
#macro fastclouds(LS,Cast,Fluffyness,Translate,Scale,Scale2,MinT)
 #ifndef (CloudForm)
  #declare CloudForm=
   bumps
   warp {turbulence .75 lambda 3}
   scale 10
   warp {turbulence .5 lambda 3}
   scale 1/10
   scale 100
   warp {turbulence 1 lambda 2}
   scale 1/100
   rotate 45
 #declare Clouds=
  pigment_pattern{CloudForm}
  color_map {
   [(1-Cast) rgb 0]
   [(1-Cast)+Fluffyness rgb 1]
  translate Translate
  scale Scale2
 #declare Clouds3=
  color_map {
   [(1-Cast)-Fluffyness/5 rgb 0]
   [(1-Cast)+Fluffyness*1.5 rgb 1]
  translate Translate
  scale Scale2
 #local Clouds2=
  color_map {
   [(1-Cast)/1 rgb 0]
   [1+Fluffyness rgb 1]
  translate Translate
  translate -vnormalize(LS)*.25*Cast
  scale Scale2
 #declare Cloudsphere=
 sphere {
  0,1
   pigment_pattern {Clouds}
   pigment_map {
    [0
     pigment_pattern {Clouds2}
     color_map {
      [0 rgb 1 transmit 1]
      [1 rgb .5 transmit 1]
    [1
     pigment_map {
      [0 rgb (1*MinT)+LColor*(1-MinT) transmit .5+MinT/2]
      [1 rgb MinT filter 1]
  finish {ambient 1 diffuse 0}
  scale 500
  translate -y*450
  scale Scale
  hollow
 object {Cloudsphere}
--- end code ---
--- usage: ---
// usage for this demo-image
#declare CloudForm= // the shapes of the clouds
 bumps
 scale 10
 scale 1/10
 scale 100
 scale 1/100
 rotate 45
#declare LS=<-50000,35000,50000>*1000; //Sun light_source location
#declare Cast=.4; // 0: no clouds, 1: fully overcast, can be higher
than 1
#declare Fluffyness=.3; // 0: very hard-edged clouds, 1: very soft
clouds
#declare Translate=15; // translation of the cloud-pattern
#declare Scale = 100; // scale of the cloud-pattern
#declare Scale2=.045; //uhm, I forgot :)
#declare MinT=.025; // minimum transparency of the clouds (can be seen
as the inverse of the "thickness" of the cloud-layer)
--- end usage ---
cu!
Download 'fastclouds-macro.jpg' (76 KB)
Preview of image 'fastclouds-macro.jpg'
Date: 1 Nov 2005 18:58:48
Message: <43680138$1@news.povray.org>
forgot a variable:
#declare LColor=<1.25,1.125,1>;
and of course you need to add a background, probably best with some
ground_fog (so the moon will still look ok), something like this:
fog {
  fog_type 2
  distance 1575
  color rgb <88,120,179>/128/1
  fog_offset -1
  fog_alt 580
(although it doesn't look as good with fog as with a sky_sphere :( )
cu!
Date: 1 Nov 2005 20:03:32
Message: <43681064@news.povray.org>
Me like :)
And I've started to use the fill light method alot too.
It's really fast, and with a bit of experience and work
it's almost as good as GI.
Very nice image..
news:web.4367b7a4781b568d530fb7fc0@news.povray.org...
> things
> smaller
> Regards, Christoph
Date: 2 Nov 2005 17:25:00
Message: <web.43693bf6eaacc9936f4b568f0@news.povray.org>
Hi Zeger
Thanks a lot for this code and the demo image! I'll try this out as soon as
I find some free time!
Best regards, Christoph
Date: 2 Nov 2005 19:12:20
Message: <436955e4$1@news.povray.org>
news:web.43693bf6eaacc9936f4b568f0@news.povray.org...
> Hi Zeger
soon as
np, but after trying it myself, I noticed some limitations in my
technique.  Even with minimum transparency of 0 the clouds are still a
bit transparent in an unrealistic way.  It looks good with a plain
background, but not with something like a moon behind the clouds :(
But still, it might be an interesting starting point for you :)
cu!
Date: 3 Nov 2005 03:09:05
Message: <4369c5a1@news.povray.org>
"gerberc" <ni.### [at] bluewinch> schreef in bericht
things
smaller
> Regards, Christoph
Impressive image! Really good!
