"Stefan Persson" <azy### [at] hotmail com> wrote:
> You are coming along well, I think.
> Just some C&C
> Negative:
> * I think the light source looks missplaced. Wouldn't the
> lightsource be above the counter?
> * GI? I don't know.. try to soften the shadows first.
> * Turn down the reflection in the Stainless steel. I think
> it looks a bit unrealistic high.
> *Try adding more light sources, dimmed and with
> shadows off to help illuminate the scene. This is mucho
> faster than GI (Radiosity).
> Positive:
> I love the texture of the counter. :)
> In fact, I think except for the reflection mentioned above,
> the textures looks very good.
> Looking forward to the next version.
> Stefan
Stefan, I was changed lights. ok.
Alain <ele### [at] netscape net> wrote:
> Using area_light will increase the realistic aspect by bluring the shadows. Using
adaptive is a
> must, it realy does improve rendering speed. Optimum aray size are 5, 9, 17, 33, 65,
129,... Start
> with adaptive 0 and increase if you get artefacts: light where there sould be none,
shadow where
> there should be light.
> Using more than one light may also help.
> You can try radiosity, just add radiosity{} in the #glabal_settings block to enable
radiosity with
> all default values. You can then try different tweaks, look at the documentation.
> Alain
> I used to have an open mind but my brains kept falling out.
Alain, I used in the new version, one area light and two point light without
shadow. I increased resolution (640x480, Antialias_Threshold=0.1) This
render quality better then previous. I dont use Radiosity, becouse it will
be slowness. This render time : 3h 37 m. I will post two images : The firt
is natural . The second is applied sharpen (image editor). Can we make with
the povray render like second..
Hasan...
Download 'kitchen3.jpg' (218 KB)
Preview of image 'kitchen3.jpg'
Download 'kitchen4.jpg' (262 KB)
Preview of image 'kitchen4.jpg'
Well, if you turned down (or off) antialiasing that would do it, but I am
not sure why you would want it to look like that. I like the first one much
better.
-s
5TF!
Absolutely much better :)
Stefan
"Hasan3" <PRO### [at] Yahoo com> skrev i meddelandet
news:web.434a3891a20724d4b550aba90@news.povray.org...
>> Just some C&C
>> Negative:
>> Positive:
>> Stefan
>> shadows. Using adaptive is a
>> 17, 33, 65, 129,... Start
>> sould be none, shadow where
>> to enable radiosity with
>> documentation.
>> Alain
> without
> with
> Hasan...
