POV-Ray : Newsgroups : povray.binaries.images : Niagara WIP - Capstan (83k) Server Time
16 Nov 2024 04:22:00 EST (-0500)
  Niagara WIP - Capstan (83k) (Message 1 to 8 of 8)
Subject: Niagara WIP - Capstan (83k)
Date: 14 Jul 2005 10:55:01
Message: <web.42d67cbd6e84ddc4acb32c570@news.povray.org>
I was recently searching for photos of the Niagara online when I discovered
that there was a star painted on the top of the capstan. I decided this was
the perfect excuse to rework the capstan. In the process I discovered that
by applying slope to my textures, I could show wear on the edges of the
parts. I rendered this image with poor radiosity settings, but was so
pleased with the results of my texture experiments, that I decided to share
them with you. the star is a prism that is set into the black wood. All of
the textures are procedural.
Now I need to finish reworking the bottom half of the capstan and
then....rework all the wood textures using slope....this project was
originally concieved as s short project I could use to learn POV-Ray....I
am learning, but it is not a short project!
As allways, I love criticism,
Tim
Download 'capstan 071405.jpg' (83 KB)
Preview of image 'capstan 071405.jpg'
Subject: Re: Niagara WIP - Capstan (83k)
Date: 15 Jul 2005 01:54:05
Message: <42d74f7c@news.povray.org>
Tim McMurdo spake:
> discovered that there was a star painted on the top of the capstan. I
> decided this was the perfect excuse to rework the capstan. In the process
> I discovered that by applying slope to my textures, I could show wear on
> the edges of the parts. I rendered this image with poor radiosity
So -that's- what slope maps are for... Looks nice, Tim. Maybe as you rework
the wood textures, make it the wood a wee bit rougher?
Stefan Viljoen
Polar Design Solutions
Date: 15 Jul 2005 04:01:08
Message: <42d76d44$1@news.povray.org>
I find the textures with the worn edges extremely impressive ! Do you
mind showing an example of your slope texture ?
Thibaut
Date: 16 Jul 2005 08:02:19
Message: <42d8f74b$1@news.povray.org>
You really freak me out with all this detailed ship building stuff. I just
watch it being put together, when you post updates, but figured I could stop
and say something for a change...
Did you realize the boards don't have a gap all the way through? The
greenish circular part, I mean, not the deck.
Yeah, I must find fault or I don't feel complete.  : )
BTW, any plans to animate a walk-through on and around the S.S. Niagara? Or
is this very slow to render?
Bob Hughes
Date: 16 Jul 2005 19:40:00
Message: <web.42d999b9dbe0e3d6b27d42f80@news.povray.org>
I hope being freaked out is a good thing!
The gap is there, but very small. These boards are supposed to be butted up
against each other. I am attaching an image close up showing the fine seem
between them.
:) I would like to get a little further ahead to create an animation. i
think I will also build a web page for the entire project.
thanks for you comments Bob.
> Bob Hughes
Download 'woodtexture.jpg' (35 KB)
Preview of image 'woodtexture.jpg'
Date: 16 Jul 2005 19:40:01
Message: <web.42d99a42dbe0e3d6b27d42f80@news.povray.org>
> Thibaut
Thank you for your comments. I appreciate it. Here is a sample of the
texture.
#macro WornWood(RGB,WearFlat,WearEdge,Norm,Rot,Tran)
        #declare Texture1 =
                            wood
                            turbulence <0.1, 0.5, 1>
                            octaves 5
                            lambda 3.25
                            scale <0.15, .5, 1>
                            rotate <5, 10, 5>
                            translate -x*2
                                color_map {
                                    [0.0 color RGB]
                                    [0.1 color RGB]
                                    [0.1 color 0.95*RGB]
                                    [0.9 color 0.95*RGB]
                                    [1.0 color RGB]
                        finish{
                                ambient 0
                                phong 0.35
                                phong_size 100
        #declare TWood1 =
                        texture{T_Wood7}
                                pigment{color rgbt <255, 155, 23,
0.999999*256>/256*0.25}
        #declare TWood2 =
                        texture{T_Wood7}
23,1.5*256>/256*0.45}
        #declare PaintedWood1 =
          texture{
            bozo
            texture_map{
              [0 TWood1]
              [WearFlat TWood2]
              [WearFlat+0.1 Green1]
              [1.0 Green1]
            warp{turbulence 0.2}
            scale <0.25,0.25,50>
        #declare PaintedWood2 =
        texture{
                bozo
                texture_map{
                        [0 TWood1]
                        [WearEdge TWood2]
                        [WearEdge+0.1 Texture1]
                        [1.0 Texture1]
         #declare DummyNum =0;
         texture{
                slope { <0,-1,0> }
                    texture_map{
                      [0 PaintedWood1]
                      //[0.1 PaintedWood1]
                      [0.1 PaintedWood2]
                      //[0.4 PaintedWood2]
                      [0.4 PaintedWood1]
                      [0.6 PaintedWood1]
                      [0.9 PaintedWood2]
                      //[0.9 PaintedWood2 ]
                      [1.0 PaintedWood1]
                                rotate Rot
                translate Tran
Hope this helps.
Tim
Date: 16 Jul 2005 20:59:38
Message: <42d9ad7a@news.povray.org>
"Tim McMurdo" <jod### [at] wohrrcom> wrote in message
news:web.42d999b9dbe0e3d6b27d42f80@news.povray.org...
> up
> between them.
That's some fantastic carpentry. I could use such skill IRL instead of the
haphazard way I go about it. I like how this view remains good even though
so close now.
Date: 17 Jul 2005 03:10:02
Message: <42da044a@news.povray.org>
"Bob Hughes" <bob### [at] charternet> schreef in bericht
news:42d9ad7a@news.povray.org...
> so close now.
This is really amazing indeed, Tim!! Very well done!!
