POV-Ray : Newsgroups : povray.binaries.images : Sponza WIP's Server Time
14 Feb 2026 22:49:27 EST (-0500)
  Sponza WIP's (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Sponza WIP's
Date: 9 Nov 2004 12:58:46
Message: <41910556@news.povray.org>
: I was playing with sponza atrium recently.
Beautiful! What is "Sponza Atrium"? Google to the rescue!
http://www.rna.hr/home.htm
=Bob=
Date: 9 Nov 2004 17:10:54
Message: <41914030.2080600@hotmail.com>
Przemek Loesch wrote:
> By the way - has anybody tried to make an post-processed DOF with MegaPov
> new features? I mean to create depth map first and then to use it for
> blurring original image?
Przemek,
The attached image was made using POV-Ray 3.6 and the Gimp (image
editor). Three files were used to make it: one to make a depth_map of
the geometry, one to render the sharp image, and one to put the first
two images together to make the fake depth-of-field effect.
The effect is far from perfect. I had to blur the depth map with the
Gimp so that the edges wouldn't remain sharp.
I can post the files with basic instructions if you are interested.
-Sam
Download 'fake_dof.jpg' (42 KB)
Preview of image 'fake_dof.jpg'
Date: 9 Nov 2004 18:53:25
Message: <Xns959D95D2BDraf256com@203.29.75.35>
jer### [at] voilafr news:web.4190e7c07ef86eab5d3520950@news.povray.org
> http://site.voila.fr/jcolin/galerie/SponzaCamera2.jpg
> http://site.voila.fr/jcolin/galerie/SponzaCamera3.jpg
> http://site.voila.fr/jcolin/galerie/SponzaCamera4.jpg
Beautiful!
Btw, how about (all of us) posting own images with a small banner
containing
1) PovRAY 3.6 bleh,bleh..
2) (C) 2004 by...
3) WWW page
this way we can promote PovRAY, and also ourselfs :)
http://www.raf256.com/3d/
Computer Graphics
Date: 10 Nov 2004 04:08:17
Message: <bfm3p0lc9qared8rpek8l7ui5c5tm2jdei@4ax.com>
On 9 Nov 2004 18:53:25 -0500, "Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
Cool, but why to promote it with wrong shape of the name?
   POV-Ray
ABX
Date: 10 Nov 2004 09:37:20
Message: <Xns959D9F2F9F8D7raf256com@203.29.75.35>
abx### [at] abxartpl news:bfm3p0lc9qared8rpek8l7ui5c5tm2jdei@4ax.com
>    POV-Ray
Whell... even the WWW should be change btw ;)
Oh, I see it is (redirection to povray).
Computer Graphics
Date: 10 Nov 2004 13:00:00
Message: <web.419256b01d492024b0aac12c0@news.povray.org>
> -Sam
Hi Sam!
Yes, this is what I was asking for. I've managed to make a similliar effect
with the Gimp. Upper two are the original images rendered with MegaPov,
lower left is the final image with faked DOF, and lower right is depth-map
corrected by making difference with gray, to shift focal point to the
middle.
My only question to you is about applying blur: Is there any way to apply an
effect selectively relative to gray map? In my image I've made layer mask
and then converted it to selection - Is it the right way?
Still I am investigating possibility of making this effect directly in
MegaPov in a similar way like "convolution_matrix" macro works, but with
creating new matrix for each point. It will be probably very slow, but
maybe faster then original DOF procedure.
Greetings!
Przemek
Download 'bud.jpg' (55 KB)
Preview of image 'bud.jpg'
Date: 14 Nov 2004 22:43:51
Message: <419825C8.6060504@hotmail.com>
> Hi Sam!
Przemek,
I'm sorry my reply is late. I didn't see yours until today :)
<clip>
> middle.
Interesting trick.
Yes, there is.
With my technique, I blurred only the depth map with the Gimp. With POV,
I used the blurred depth_map as a 'container' for the real image. You
can blur an image in POV by using the average pattern and a #while loop.
The blurred pattern is placed in another pigment_map which is inside the
depth_map.
It's a bit hard for me to explain, so here's a prototype:
#declare depth_map =
pigment{
  image_map{
   tga"depth_map.tga" interpolate 2 once
#declare actual_image =
pigment{
  image_map{
   tga"actual_image.tga" interpolate 2 once
#declare R = seed(0001);
#declare DOF=
  // our 'container'
  pigment_pattern{depth_map}
   pigment_map{
    #local V=0;
    #while(V<=1)
     [V
      // this blurs the image
      average
      pigment_map{
       #local vv=0;
       #while(vv<=V*255)
        [1
         actual_image
         // the 'V/20' at the end of the line below is how
         // we adaptively blur the image according to our
         // depth_map
         translate<rand(R)-rand(R),rand(R)-rand(R),0>*V/20
        #local vv=vv+1;
     #local V=V+1/255;
I hope this helps.
Good luck~
-Sam
Date: 16 Nov 2004 03:55:00
Message: <web.4199bf6e1d492024b0aac12c0@news.povray.org>
Thank you Sam,
I see your technique is completely different than I thought. It may be very
useful  if we try to make all things with POVRay. I still try to make it
purely in MegaPOV with matrixes defined for each point.
Przemek
Date: 16 Nov 2004 18:43:08
Message: <419A905E.9030207@hotmail.com>
> Thank you Sam,
Yes, it would be nice. Since I have to pre-blur the depth_map, it would
be very difficult to do the whole effect with POV alone.
> Przemek
What does that do? Does it involve the matrix keyword?
-Sam
Date: 17 Nov 2004 12:55:01
Message: <web.419b8fe41d492024deb6c0fb0@news.povray.org>
Not at all. I have never used "matrix" keyword but if I am not mistaken it
describes transformation of an object in 3D space. Actually I want to use
array[n][n], but technically it can be called matrix.
My idea is to create matrixes like this:
#declare array_for_single_point = array[5][5];
And then to fill this array with values based on depth map. The values are
scales for neighbours' colors.
For example - array for point which is exactly in focal distance looks like
this:
|0  0  0  0  0|
|0  0  0  0  0|
|0  0  25 0  0|
|0  0  0  0  0|
|0  0  0  0  0|
and for point which is completelly out of focus:
|1  1  1  1  1|
|1  1  1  1  1|
|1  1  1  1  1|
|1  1  1  1  1|
|1  1  1  1  1|
For all other points which are in between the values are in range 0-25.
The final value of color for the given point is averaged based on matrix
content.
I don't have any working code yet and even I'am not sure if it works like
this. If you are interested in please study "convolution_matrix.pov" and
"pprocess.inc" from MegaPov samples.
Przemek
