POV-Ray : Newsgroups : povray.binaries.images : Re: blurring bump map image in pov ? Server Time
18 Nov 2024 00:26:16 EST (-0500)
  Re: blurring bump map image in pov ? (Message 1 to 2 of 2)
Subject: Re: blurring bump map image in pov ?
Date: 1 Aug 2004 03:25:00
Message: <web.410c9978880ae268c3fdd4de0@news.povray.org>
Alain <aze### [at] qwertygov> wrote:
> It looks like the encaved parts are instead coming out of the surface.
> With the light coming from the top right, the left side should be
> brighter and the right dark. Maybe using a negative of your bump_map
> could give beter results.
yes, i probably need to flip the function, but it still produces
3 patters instead of one.
the height of the normals is also not the problem, because making
the function smaller makes the patters more faint but does not move
the 3 patterns closer together.
i dit some testing with making the function a normalised vector and
change the direction of the vector depending on the function, but that
did not do the trick either.
jaap.
Download 'neg.jpg' (29 KB)
Preview of image 'neg.jpg'
Date: 1 Aug 2004 03:35:00
Message: <web.410c9c88880ae268c3fdd4de0@news.povray.org>
sory for starting a new thread on this, but i just posted a replay to
an older thread using the web interface (witch does say: "(BETA TESTING)"..)
i dit use the "edit message" option after the preview. that probably
resulted
in a new thread.
jaap.
