POV-Ray : Newsgroups : povray.binaries.images : toon-shading using attenuation Server Time
14 Nov 2024 00:20:57 EST (-0500)
  toon-shading using attenuation (Message 1 to 2 of 2)
Subject: toon-shading using attenuation
Date: 22 Mar 2007 05:30:42
Message: <pan.2007.03.22.10.30.36.351543@removeit.geloescht.net>
In povray.general there is a discussion about toon-shading and I'd like to
contribute my solution. The trick is to put a slightly larger copy around
each object with a clear texture but with dense black attenuation and
no_shadow. This has the advantage that black lines only appear at
positions where the object really ends and that it works with non-curved
surfaces (although the line could be a bit brighter). However, finding
a copy that really fits well so that the line has the same thickness
everywhere is often difficult. For blobs or isosurfaces lowering the
threshold is not always enough. It works quite well for basic objects and
CSG. Meshs shouldn't be a problem if you can expand it by moving every
vertex along its normal but I have never tried that.
Here's the code for a sphere:
#default { finish { ambient .2 diffuse 1 }}
//higher diffuse because black attenuation darkens the texture
union
	sphere
	  0, 1
	  pigment
	    color <1, 0, .05>
	  finish
	    brilliance 0
	    specular 10000 //can increase render times with anti-aliasing
	    roughness .0015
	sphere
	  0, 1.03
	  hollow
	  pigment
	    Clear
	  interior
	    fade_power 1111
	    fade_color <0, 0, 0>
	    fade_distance .01
	  no_shadow
And here's a render of a small demo scene:
http://geloescht.net/allerlei/comic_small.png
Subject: Re: toon-shading using attenuation
Date: 22 Mar 2007 06:20:01
Message: <web.4602661722cba179731f01d10@news.povray.org>
> no_shadow.
You could also use absorbing/emitting media.
> However, finding
This is basically the same technique that I used to generate the ghostly
edge-glow effect in my last IRTC entry, 'Ghost Light' - still on the IRTC
homepage due to the hiatus. I can vouch for expanding a mesh along its
normals (actually I shrunk mine but it amounts to the same thing), it
worked a treat. I don't know about other modellers, but there's a suitable
tool in Blender that does this.
Nice demo, by the way.
Bill
