POV-Ray : Newsgroups : povray.binaries.images : When things turn odd - 52Kb Server Time
22 Mar 2026 23:16:53 EDT (-0400)
  When things turn odd - 52Kb (Message 1 to 2 of 2)
Subject: When things turn odd - 52Kb
Date: 30 Apr 2004 09:21:10
Message: <opr69tzvzkp4ukzs@news.povray.org>
While working on my next scene something wasn't behaving in the way I
expected, big suprise.
So as I try and do, I isolated out in a separate file those components I
wanted to test and started fiddling. Things started to look odd, damn
followed by ooo!
Then looking at the code I thought: "There's not much there I wonder if I
can make this shorter". So the result is as attached.
Now can anyone guess how I did this with 252 characters and no textures,
non-default finishes or normals just pigments, objects and lights :)
To be honest I'm still working out why it does this, I just thought it
looked funky. On the plus side I've found out in better detail how some
objects work
Phil Cook
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
Download 'mytest.jpg' (52 KB)
Preview of image 'mytest.jpg'
Subject: Re: When things turn odd
Date: 6 May 2004 06:59:40
Message: <opr7krf3ukp4ukzs@news.povray.org>
On Fri, 30 Apr 2004 14:20:09 +0100, Phil Cook
<phi### [at] nospamdeckingdealscouk> wrote:
#macro S(P,T)light_source{y*0.99 rgb 0.2}sphere{0,2 pigment{P filter 1
transmit 0.6}translate y*0.1*T no_image}#end#declare
U=union{S(rgb<1,1,0>,4)S(blue 1,3)S(green 1,2)S(red 1,1)translate
z*10}object{U}object{U scale y*-1}plane{-z,-17 pigment{rgb 1}}
So can anyone shorten this? And does anyone know exactly why it does this
Changing the position of the light_source y is fun as is using merge
instead of union. As I've no_image(d) the sphere; difference makes them
show up although for some reason I get a "Warning: Camera is inside a
non-hollow object..." which as the radius 2 spheres are translated z*10
and the camera is at 0 and I'm not inside the plane object, I find odd.
Phil Cook
