POV-Ray : Newsgroups : povray.binaries.images : Artists - 3d painting (WIP) Server Time
7 May 2026 00:30:42 EDT (-0400)
  Artists - 3d painting (WIP) (Message 31 to 40 of 55)
Subject: Re: Artists - 3d painting (WIP)
Date: 15 May 2013 12:27:36
Message: <op.ww4vz9zcufxv4h@xena>
On Wed, 15 May 2013 11:05:17 +0200, Sean Day <s.d### [at] uelacuk> wrote:
> Nekar Xenos wrote:
>> On Mon, 13 May 2013 09:40:23 +0200, s.day <s.d### [at] uelacuk> wrote:
>>> Great idea, have you tried making the blobs thinner in the x scale or
>>> longer in
>>> the y to make it look more like a brush stroke?
>> Yes, I am busy with something like that. I keep tracing more blobs in
>> the specified direction plus a bit of randomness, but at the moment it
>> tends to look like a scene from The Thing
>> =8'S
>>> This has given me a good idea for my moss placement, the shape of each
>>> clump of
>>> moss was a bit square for my liking (as I just used trace over a
>>> rectangular
>>> area), didn't think about using an image to place the moss. I will
>>> give that a
>>> go.
>> How about an L-system with random branches?
>> I've never had much success with L-Systems though.
> I think an L-system would work well for growing the moss plants
> themselves not so sure about using it for positioning them on the rocks
> though. Still could be worth investigating.
If you declare the points of the L-System branches, then you could use
those points as a starting position for trace() and use a direction vector
in the direction of the rock (related to the L-System).
-Nekar Xenos-
Date: 15 May 2013 17:52:49
Message: <519403b1@news.povray.org>
> Christian Froeschlin wrote:
>> you could try using a bozo / noise pattern for the probability
>> (instead of fixed probability over rectangle)
> I like that idea, not sure how to do it though ;-)
#function F_Bumps=pigment{bumps}#end
#if(rand(R)< F_Bumps(x,y,z).x)
Date: 15 May 2013 18:37:10
Message: <51940e16@news.povray.org>
I mean something like the code below. It places objects
in random positions in a square from (-1,-1) to (1,1) but
also uses a "die roll" for each placement. The function
used should yield values from 0 to 1 based on position.
In the sample I use an f_boxed (to taper out at the edge),
multiplied by f_bozo (to give some structured variation),
and a power just to increase "contrast".
#include "rand.inc"
#include "functions.inc"
global_settings
   assumed_gamma 1.0
camera
   location  <0.0, 1.5,  0.0>
   look_at   <0.0, 0.0,  0.0>
   angle 90
#declare NUM = 20000;
#declare f_distribution = function
   pow(f_boxed(x,y,z)*f_bozo(x*5, y*5, z*5),2)
#declare R = seed(42);
#declare I = 0;
// Just to visualize the probability in the background
plane
   y,0
   pigment
     function {f_distribution(x,y,z)}
   finish {ambient 1}
// Actual placement
union
#for (I,0,NUM,1)
   #declare X = 2*rand(R)-1;
   #declare Y = 2*rand(R)-1;
   #if (rand(R) < f_distribution(X,0,Y))
     sphere {<X,0,Y>, 0.005}
   pigment {color rgb <1,0,0>}
   finish  {ambient 1}
Download 'testplacement.png' (60 KB)
Preview of image 'testplacement.png'
Date: 16 May 2013 01:38:16
Message: <op.ww5wjwcgufxv4h@xena>
On Wed, 15 May 2013 11:54:59 +0200, Shay <non### [at] nonecom> wrote:
>  I'd like to see a high-quality render to get a better idea of the
> potential.
I am still experimenting and adjusting the macro, so I don't have a copy
to re-render at the same settings. Here is a render with a few large paint
blobs.
-Nekar Xenos-
Download 'artists - copy (9).png' (1083 KB)
Preview of image 'artists - copy (9).png'
Date: 16 May 2013 01:51:51
Message: <519473f7$1@news.povray.org>
Thanks a lot Chrisian, this is a great example, have been playing with
it a bit using different functions and I prefer using f_spherical to
f_boxed but also it is interesting with some of the more complex
shapes/functions like f_comma etc.
Sean
Date: 16 May 2013 12:27:38
Message: <op.ww6qmj2dufxv4h@xena>
> potential.  -Shay
This is at a higher resolution, but the paint was too sparse. Now it looks
a lot like a 3d version of Pollock ;)
-Nekar Xenos-
Download 'artists - copy (10).jpg' (981 KB)
Preview of image 'artists - copy (10).jpg'
Date: 17 May 2013 08:20:00
Message: <web.51961f3c544d69f8c2d977c20@news.povray.org>
Those paint-stroke drips look *amazing*, especially in close-up. Your technique
just keeps getting better and better!
The poor jazz men--they've been turned into a complete abstraction ;-)
BTW, did you see the recent news about the sale of a Jackson Pollock painting?
One of his drip paintings sold at auction for something like $47 million
dollars!! It set a new record for his work, I believe.  So keep improving your
technique--there's lots of money to be made!  :-P
Date: 17 May 2013 13:31:41
Message: <op.ww8oa2gyufxv4h@xena>
;D
> painting?
> improving your
Yes I heard about that. I like Pollock's idea, but I prefer Dali's works.
Maybe if I were to see a Pollock close-up I would change my mind...?
-Nekar Xenos-
Date: 17 May 2013 13:59:16
Message: <51966ff4$1@news.povray.org>
I have and it drove me the other way. :-(
Regards
Date: 17 May 2013 16:05:01
Message: <web.51968c41544d69f84aef9a7a0@news.povray.org>
Hmmm. This need something, IMO.
I've heard it said many times that "all art is abstract" because no painting is
an exact copy of its subject. This, of course, isn't true of artists like
Pollock or Motherwell who painted paint. Thier works are, in fact, the *most*
literal.
Your digital art could use a literal (meta, if you prefer) aspect. Perhaps a
shift in perspective with paint-scene lighting drastically different from
source-scene lighting?
 -Shay
