POV-Ray : Newsgroups : povray.binaries.images : Apparent bounding bug in sphere_sweep Server Time
28 Sep 2024 22:15:12 EDT (-0400)
  Apparent bounding bug in sphere_sweep (Message 1 to 10 of 16)
Subject: Apparent bounding bug in sphere_sweep
Date: 28 Apr 2013 18:04:49
Message: <op.wv9ua5h36b35ac@linux-dc58.site>
The cubic spline sphere sweep in the scene below is clipped.  Adding a
manual bounded_by statement has no effect.  The problem is reminiscent of
FS#243, except that I have not scaled the object.
The object's shadow is also clipped in the 3.7 scene, although not to the
same extent as the object itself.  The shadow is not clipped in earlier
versions of POV-Ray.  (Has any work been done on FS#81 that could account
for this difference?)
The transparent blue spheres were added to show the control points.
____________________________________________________________
camera
{ location <0.0, 1.5, -8.5>
   look_at <0.0, 1.5, 0.0>
   angle 29
light_source { <-4.562, 10.625, -7.902>, rgb 1 }
box { <-10, 0, -10>, <10, 12, 10> hollow pigment { rgb 1 } }
text
{ ttf "cyrvetic.ttf" str(version,0,2) 0.001, 0
   scale 0.3 translate <-0.25, 1.4, 0>
   pigment { rgb 0 }
   no_shadow
#declare Marker = sphere
{ 0, 0.12
   pigment { rgbt <0, 0, 1, 0.7> }
   no_shadow
#declare R = 0.07;
union
{ sphere_sweep
   { cubic_spline 6,
     <1, -1>, R,
     <-1, -1>, R,
     <-1, 1>, R,
     <1, 1>, R,
     <1, -1>, R,
     <-1, -1>, R
     bounded_by { box { -<1.5, 1.5, R>, <1.5, 1.5, R> } }
     pigment { red 1 }
   object { Marker translate <1, 1> }
   object { Marker translate <1, -1> }
   object { Marker translate <-1, -1> }
   object { Marker translate <-1, 1> }
   translate 1.5 * y
POV-Ray versions: 3.5, 3.6.1, and 3.7.RC7
Operating System: openSUSE 12.2 Linux
CPU: Dell Inspiron 17R, Intel Core i7
<Insert witty .sig here>
Download 'cubic_sweep_bound_bug.3.5.jpg' (8 KB) Download 'cubic_sweep_bound_bug.3.6.jpg' (8 KB) Download 'cubic_sweep_bound_bug.jpg' (9 KB)
Preview of image 'cubic_sweep_bound_bug.3.5.jpg'
Preview of image 'cubic_sweep_bound_bug.3.6.jpg'
Preview of image 'cubic_sweep_bound_bug.jpg'
Subject: Re: Apparent bounding bug in sphere_sweep
Date: 29 Apr 2013 03:10:01
Message: <web.517e1c4bee7a6958c2d977c20@news.povray.org>
Strange thing here (in v3.62): Just changing your R variable to be larger
results in the entire sphere_sweep showing up successfully. (R of somewhere
around 0.19 to 0.20.) Likewise making it smaller than your 0.07 causes more of
the sweep to be clipped (except at the very corners.) And as you say, the
bounding_box (whether used or not) has no effect, nor does your translation.
Date: 29 Apr 2013 03:25:51
Message: <517e207f@news.povray.org>
Strange. I cannot confirm the problem if I copy the sphere_sweep code
into my own scene. I shows with /your/ scene code.
#version 3.7;
global_settings {
   assumed_gamma 1.0
   location  <0.0, 1.5, -4.0>
   direction 1.5*z
   look_at   <0.0, 0.0,  0.0>
sky_sphere {
     gradient y
     color_map {
       [0.0 rgb <0.6,0.7,1.0>]
       [0.7 rgb <0.0,0.1,0.8>]
light_source {
   <0, 0, 0>            // light's position (translated below)
   color rgb <1, 1, 1>  // light's color
   translate <-30, 30, -30>
#declare R = 0.07;
sphere_sweep
   { cubic_spline 6,
     <1, -1>, R,
     <-1, -1>, R,
     <-1, 1>, R,
     <1, 1>, R,
     <1, -1>, R,
     <-1, -1>, R
     pigment { red 1 }
Download 'spheresweep_test.png' (55 KB)
Preview of image 'spheresweep_test.png'
Date: 29 Apr 2013 03:30:00
Message: <web.517e2059ee7a6958c2d977c20@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> And as you say, the
Sorry, what I meant was that making the bounding box *larger* (or not using it
at all) has no effect on the problem.
Thomas's results are indeed strange.
But I just discovered something: Turning Bounding=off (or making
Bounding_Threshold some large value) makes the entire sphere_sweep appear, no
problem. So it seems to be some kind of weird bounding problem.
Date: 29 Apr 2013 03:55:01
Message: <web.517e263dee7a6958c2d977c20@news.povray.org>
....in v3.62, that is.
Date: 29 Apr 2013 05:00:01
Message: <web.517e3579ee7a6958bbd3eafb0@news.povray.org>
Ok, this is weird.. I simply move the translate up inside the sphere_sweep
object and added a second union around the markers and got the image below in
3.7...
I was previously seeing the same result as you with the bounding issue.
union
{ sphere_sweep
   { cubic_spline 6,
     <1, -1>, R,
     <-1, -1>, R,
     <-1, 1>, R,
     <1, 1>, R,
     <1, -1>, R,
     <-1, -1>, R
     pigment { red 1 }
   translate 1.5 * y
   union
   translate 1.5*y
Sean
Download 'sd.png' (27 KB)
Preview of image 'sd.png'
Date: 29 Apr 2013 07:19:32
Message: <517e5744$1@news.povray.org>
> 3.7...
> union
> { sphere_sweep
>     { cubic_spline 6,
>       <1, -1>, R,
>       <-1, -1>, R,
>       <-1, 1>, R,
>       <1, 1>, R,
>       <1, -1>, R,
>       <-1, -1>, R
>       pigment { red 1 }
>     translate 1.5 * y
>     union
>     translate 1.5*y
> Sean
but if you comment bounded_by out, the problem reappears...
Date: 29 Apr 2013 07:24:50
Message: <517e5882$1@news.povray.org>
...in other words, why is bounded_by essential here? I myself never use
this with sphere_sweeps and never had a problem.
Date: 29 Apr 2013 07:29:13
Message: <517e5989$1@news.povray.org>
Am 29.04.2013 13:24, schrieb Thomas de Groot:
> ....in other words, why is bounded_by essential here? I myself never use
The obvious answer is, "because sphere_sweep automatic bounding is
unreliable" :-)
Date: 29 Apr 2013 07:41:44
Message: <517e5c78$1@news.povray.org>
> unreliable" :-)
Right. I could have expected that answer  ;-)
