POV-Ray : Newsgroups : povray.binaries.images : Re: home made hdri Server Time
31 Dec 2025 11:52:53 EST (-0500)
  Re: home made hdri (Message 1 to 7 of 7)
Subject: Re: home made hdri
Date: 31 Jul 2003 02:41:19
Message: <grdhivsmk967vqvcvq5vu8p5umoo17dc52@4ax.com>
On Wed, 30 Jul 2003 22:30:13 -0500, "Micheal \(Mike\) Williams"
<mic### [at] quixnetnet> wrote:
> This is a 360 image I grabbed off the net. The sun is 32 times brighter than
> anyother white.
I did not viewed it but was this _available_ in the net as hdr file and
accesible? Then Why you wasted about 1 MB of space in this server rather then
post a link to original image ? Have you permission from author to repost ? Is
it http://www.debevec.org/Probes/campus_probe.hdr ?
ABX
Date: 31 Jul 2003 04:31:32
Message: <3f28d3e4$1@news.povray.org>
Hm, what program did you use to view it?
Flo
DigitalTwilight
#homepage: http://www.digitaltwilight.de
#email: kin### [at] gmxnet
Version: 6.0.502 / Virus Database: 300 - Release Date: 18.07.2003
Date: 31 Jul 2003 07:16:51
Message: <3F28FAA2.33656AF6@gmx.de>
> anyother white.
That's not really what i would call an hdr light probe, the same effect
can be achieved much easier by using a normal image map and placing a
bright sphere at the position of the sun.  Usual light probes have a
dynamic range of several 1000-10000 and the high dynamic range is not
limited to the immediate vicinity of the sun.
Last updated 17 Jun. 2003 _____./\/^>_*_<^\/\.______
Date: 31 Jul 2003 08:27:25
Message: <Xns93C9560BA28A8None@204.213.191.226>
"Micheal \(Mike\) Williams" <mic### [at] quixnetnet> wrote in
news:3f288ca6@news.povray.org:
> brighter than anyother white.
Looks like an ok 360 image, but have you used it in a Povray image?
Date: 31 Jul 2003 08:29:43
Message: <3f290bb7$1@news.povray.org>
I think he is referring to his post in povray.general
about homemade HDR images. But haven't checked
either image.
Tim Nikias v2.0
than
> > anyother white.
then
? Is
> ABX
Date: 31 Jul 2003 08:32:34
Message: <Xns93C956EB5ED88None@204.213.191.226>
"DT - The Renaissance" <kin### [at] gmxnet> wrote in news:3f28d3e4$1
@news.povray.org:
Needs HDRView from http://www.debevec.org/FiatLux/hdrview/
But don't bother for a single image.  Get it if you intend to use Mael's
mlpov.
Date: 31 Jul 2003 17:52:24
Message: <3f298f98@news.povray.org>
The weekness of the light probs I have seen is that the light source is the
same level as all other white surfaces in the scene. The light sources
should be much brighter than any other white in the image. To make a high
color image all it takes is converting it to 16 bit and either bluring it or
shrinking it. It is the same tools for makes smooth 16bit heightfields. With
the light sources in the image scaled 10 or more times the image provides
real light. Any high res image can be used.
"None" <Non### [at] onca> wrote in message
Download 'dice3d.jpg' (85 KB)
Preview of image 'dice3d.jpg'
