POV-Ray : Newsgroups : povray.binaries.images : Voronoi mosaiac - mosaiac.jpg (1/1) Server Time
13 Apr 2026 20:57:28 EDT (-0400)
  Voronoi mosaiac - mosaiac.jpg (1/1) (Message 1 to 5 of 5)
Subject: Voronoi mosaiac - mosaiac.jpg (1/1)
Date: 26 Dec 2003 17:55:27
Message: <cjameshuff-88F0A8.17552326122003@netplex.aussie.org>
This was actually fairly simple to do. I generated a bunch of points in
an array, and used an image_map pigment function to extract the colors
at each point and save them as colors in a color_map. Then, for the
voronoi pattern, I just used the points with their respective color_map
indices, basically using the color map as the palette of an indexed
color image.
Oh, and there's 5000 points in this image. With all 5000 entries in one
color_map. Some of you might notice something interesting about that...
I needed to store a lot of colors, but didn't want to go through the
trouble of building nested color_maps or trying to reduce the number of
colors used, so I patched POV to remove the size limits on blend maps.
Download 'mosaiac.jpg' (17 KB)
Preview of image 'mosaiac.jpg'
Subject: Re: Voronoi mosaiac - mosaiac.jpg (1/1)
Date: 28 Dec 2003 09:48:09
Message: <3feeed29$1@news.povray.org>
Nice work. I love the way you talk so casually about patching pov when it
doesn't do what you want from it :)
Ryan
Date: 28 Dec 2003 10:20:38
Message: <3feef4c6@news.povray.org>
I thought exactly the same :)
Florian
Date: 28 Dec 2003 10:49:25
Message: <cjameshuff-70E1D0.10492828122003@netplex.aussie.org>
In article <3feeed29$1@news.povray.org>,
Hey, all you need is the source code, a compiler, and a bit of C/C++
knowledge...the hard part's usually figuring out what to do. Like my
object pattern and transform patch...both really simple, adding a large
amount of functionality, but nobody had ever thought of adding them
before. My recent blend map extensions also fit in this category...they
involve modifying a few lines in one file and changing a function in
another, and should greatly speed up complex textures with big blend
maps. Should have been done a long time ago...but I only did it after I
noticed a big slowdown that I knew wasn't due to the pattern I was
testing.
http://tag.povray.org/
Date: 28 Dec 2003 13:38:15
Message: <3fef2317@news.povray.org>
Yeah, the only thing stopping me is that I have no idea where to begin looking
at the POV-Ray source code...
Ryan
