POV-Ray : Newsgroups : povray.binaries.images : vororock Server Time
13 Jul 2025 08:20:28 EDT (-0400)
  vororock (Message 1 to 10 of 11)
Subject: vororock
Date: 13 Feb 2019 07:43:13
Message: <XnsA9F58B9255DFEseed7@news.povray.org>
"Cipped" away about half of 9000 cells. Increasing chance on a "grain"
along y axis, so the lower ones will be bigger.
#version 3.7;
global_settings{assumed_gamma 1.0}
#default{finish{ambient 0.1 diffuse 0.9}}
#include "math.inc"
#include "transforms.inc"
#include "rand.inc"
// run: scene
// run: voro++pov.py -c "%i %q %w %p %s %t %l" -o -v -1 40 -1 40 -1 40
vorobox.txt
// run: scene
camera{
  perspective angle 50
  location  <0,30,-100>
  look_at   <0,-5,0>
light_source{< -500,300,-500> rgb <0.3,0.3,0.6>}
light_source{<1500,3000,-30> rgb 1}
#macro VoroPolygons(Normals, FaceIndex, Vertices)
  Creates a single voronoi cell from data generated by Voro++ by
constructing
  a polygon per face.
  Normals   (arr, vec) : an array of normals
  FaceIndex (arr, int) : an array with indices that points to vertices
  Vertices  (arr, vec) : an array with vertices of the cell faces
  #local Length = dimension_size(FaceIndex,1);
  #local Voro = union{
    #for(Face,0,Length-1,1)
      #local VertexIndices = FaceIndex[Face];
      #local Normal = Normals[Face];
      #local Distance = vdot(Normal,Vertices[VertexIndices[0]]);
      #local Transform = transform{translate Normal*Distance};//*scale
      #local VILength = dimension_size(VertexIndices,1);
      polygon{
        VILength+1,
        #for(VertexIndex,0,VILength-1,1)
          #local Index = VertexIndices[VertexIndex];
          #local Vertex = Vertices[Index];
          #local Vertex = VProject_Plane(Vertex, Normal);
          #local Vertex = vtransform(Vertex, Transform);
          #if (VertexIndex = 0)
            #local P0 = Vertex;
          Vertex
        P0
  object{Voro}
#macro Id2Coord(Id, Xn, Yn)
  #local Zi = floor(Id/(Xn*Yn));
  #local Yi = floor((Id-Zi*Xn*Yn)/Xn);
  #local Xi = Id-(Zi*Xn*Yn)-(Yi*Xn);
  (<Xi,Yi,Zi>)
#macro Coord2Id(Coord, Xn, Yn)
  (Coord.x+Xn*Coord.y+Xn*Yn*Coord.z)
#declare OutFile = "vorobox.txt";
#declare IncFile = "vorobox.inc";
#declare Stream = seed(7);
#declare N = 40;
#declare N3 = pow(N,3);
#declare arrGrid = array[N3];
// first run
#if(!file_exists(OutFile))
  #fopen Voro OutFile write
  #for(I,0,N3,1)
    #declare Coord = Id2Coord(I,N,N);
    #declare Probability = pow(10, 3*(Coord.y+1)/N)/1000;
    #if(Prob(Probability, Stream))
      #declare Point = VRand(Stream) + Coord;
      #write(Voro,I," ",Point.x," ",Point.y," ",Point.z,"\n")
// second run
#if(file_exists(IncFile))
  #include IncFile
  #debug concat(IncFile,"\n")
  #declare Length = dimension_size(Labels,1);
  union{
    #for(I,0,Length-1,1)
      #declare Label = Labels[I];
      #declare Coord = Id2Coord(Label, N, N);
      #if(Coord.y<Coord.x+5)
        #declare Point = Points[I];
        #declare Normals = FaceNormal[I];
        #declare FaceIndex = FaceVerticesIndex[I];
        #declare Vertices = RelVertices[I];
        object{VoroPolygons(Normals, FaceIndex, Vertices) scale 0.9
translate Point pigment{rgb 1}}
    translate <-N/2,-N/2,-N/2>
    rotate <0,-45,0>
Download 'vororocks.jpg' (151 KB)
Preview of image 'vororocks.jpg'
Subject: Re: vororock
Date: 13 Feb 2019 09:00:00
Message: <web.5c6422682b722427765e06870@news.povray.org>
This is looking really impressive!  :)
This would be even better if we had a [user-controlled] internal voronoi
generator in POV-Ray.  :)
Date: 13 Feb 2019 09:33:28
Message: <XnsA9F59E437D7Dseed7@news.povray.org>
If I could, I would stick the voro++ into POV-Ray,
ingo
Date: 14 Feb 2019 02:28:04
Message: <5c651884$1@news.povray.org>
Indeed, indeed.
Very nice karstic slope by the way.
Date: 14 Feb 2019 03:00:25
Message: <XnsA9F65BA0521B2seed7@news.povray.org>
in news:5c651884$1@news.povray.org Thomas de Groot wrote:
> karstic
Had to look that up. Interesting stuff.
ingo
Date: 14 Feb 2019 06:50:49
Message: <5c655619$1@news.povray.org>
>> karstic
Well, it is not /truly/ karstic in a RL sense, but it could be used for
one in our POV-Ray world. :-)
Date: 14 Feb 2019 08:13:49
Message: <XnsA9F690C2037FFseed7@news.povray.org>
in news:5c655619$1@news.povray.org Thomas de Groot wrote:
> not /truly/ karstic
but it gave inspiration, or at least made me think back many moons when
trying to create erosion in a df3. The animation of that is gone from the
server sadly and I don't have it anymore.
I was thinking, let a gradient pigment with some turbulence define the
chance of a grain placement (yes/no). This creates lager and smaler rocks
depending on the gray value. Use a somehowe derived pigment to determine
the hardness of the stone. Remove voronoi cells from the grid depending on
the hardness. Can be done with some trickery in assigning the labels to
the cells I think. May need an awfull big grid for that to get something
coherent. Will investigate.
ingo
Date: 15 Feb 2019 02:30:00
Message: <5c666a78$1@news.povray.org>
>> not /truly/ karstic
Interesting. I m curious to see the results of that cogitation.
Fascinating to see how inspiration works...
Date: 15 Feb 2019 18:30:00
Message: <web.5c674aef2b722427264be49d0@news.povray.org>
Fascinating image. Well done !
Did you post your Python code somewhere ?
Tor Olav
http://subcube.com
Date: 16 Feb 2019 02:57:36
Message: <XnsA9F85B2532CE2seed7@news.povray.org>
in news:web.5c674aef2b722427264be49d0@news.povray.org Tor Olav Kristensen
in binaries.utilities
<XnsA9F1C5330417Dseed7@news.povray.org>
ingo
