POV-Ray : Newsgroups : povray.binaries.images : voronoi forrest Server Time
21 Mar 2026 23:49:28 EDT (-0400)
  voronoi forrest (Message 1 to 8 of 8)
Subject: voronoi forrest
Date: 4 Feb 2019 07:59:52
Message: <XnsA9EC8E6578D7Bseed7@news.povray.org>
Proof of concept, voronoi forrest with about a 100 trees and saplings
with non intersecting foliage.
Generate a bunch of random points. Put them in Voro++ or as I did Tess
https://github.com/wackywendell/tess a python binding to Voro++ (on
windows you need the MS compiler tool thingy). The output I used is a
list of neighbours per point. From that I calculated the nearest
neighbour per point. Devided the distance by two and used that as
radius for a sphere.
There are other options, one could use the centroid of a voroni cell
and calculate the biggest cell fitting sphere based on that position.
The Voro++ commandline program can output vertices and normals relative
to a points position. This can easily be used to create a foliage by
using the vertices to construct a union of polygons. Scale the union
down a bit and move it to the right position. The normals could be used
for intersecting multiple planes to create a solid foliage.
attached are forrest.pov for the first step, the creation of random
points and it writes a python file vorodat.py. That is needed by
vorotess.py, the second step, that does the voro++ thing and writes
POV-Ray arrays to forrest.inc Finally Forrest_spheres.pov uses the
include to make the trees.
I won't persue this any more for the moment eventhough there are many
possibilties. Also for clouds etc.
https://www.youtube.com/watch?v=J4-x_sBX9tk
ingo
Download 'forrest_spheres.jpg' (251 KB) Download 'forrest.pov.txt' (3 KB) Download 'forrest_spheres.pov.txt' (1 KB) Download 'vorotess.py.txt' (1 KB)
Preview of image 'forrest_spheres.jpg'
Subject: Re: voronoi forrest
Date: 4 Feb 2019 08:02:31
Message: <XnsA9EC8ED92EA29seed7@news.povray.org>
the files, i hope,
ingo
Date: 4 Feb 2019 14:10:01
Message: <web.5c588d50f4d98fc6765e06870@news.povray.org>
Nice, although I might be tempted to loosely correlate the size of the bole with
the height of the tree and diameter of the trunk.
Tall narrow trees might be done with scaled spheres to give a tall but narrow
ellipsoid.
Good work  :)
Date: 4 Feb 2019 15:49:45
Message: <XnsA9ECDE0F8AF2Dseed7@news.povray.org>
in news:web.5c588d50f4d98fc6765e06870@news.povray.org Bald Eagle wrote:
> Good work  :)
thanks,
ingo
Date: 5 Feb 2019 02:51:30
Message: <5c594082$1@news.povray.org>
> ellipsoid.
> Good work  :)
I agree. Incidentally, in one of the latest Nature journals (vol.265, 17
January 2019, p.280) there was a photograph heading the article "The
Forest Question", that shows the canopy of a trees species - I think
from Madagascar - that do not touch mutually. The branches just stop
growing before reaching the canopy of a neighbouring tree. From below,
it gives the impression of a crackle pattern.
This is an exception. most other trees have more or less
interpenetrating canopies.
Date: 6 Feb 2019 00:35:01
Message: <web.5c5a71daf4d98fc670c84ee0@news.povray.org>
> ingo
This is good. But for a realistic tree, should write further codes for stems and
leaves grow on your sphere positions. If you are willing, I can introduce what
the algorithm I saw from the arbaro.
Date: 6 Feb 2019 00:40:01
Message: <web.5c5a72b4f4d98fc670c84ee0@news.povray.org>
Another question is: Is it efficient for about 10000~ 100000 trees?
Date: 6 Feb 2019 04:22:00
Message: <XnsA9EE69758344Eseed7@news.povray.org>
The pre processing time is fast, but I currently run into memory
allocation problems with Tess. With Voro++ no problem. once everything
works parsing the 'trees' by POV-Ray will take the most time,
ingo
