POV-Ray : Newsgroups : povray.binaries.images : Metal Flares - 1 attachment Server Time
11 Sep 2025 14:40:24 EDT (-0400)
  Metal Flares - 1 attachment (Message 1 to 8 of 8)
Subject: Metal Flares - 1 attachment
Date: 16 Aug 2003 06:33:50
Message: <Xns93D97FCF73E75raf256com@204.213.191.226>
Just a test of my specular-flare add on
Raf256
Download 'metal_flare_1.jpg' (120 KB)
Preview of image 'metal_flare_1.jpg'
Subject: Re: Metal Flares - 1 attachment
Date: 16 Aug 2003 07:22:56
Message: <3f3e1410$1@news.povray.org>
pretty :))
Kitty5 NewMedia http://Kitty5.com
TEL : +44 (01270) 501101 - ICQ : 15776037
PGP Public Key
Date: 16 Aug 2003 13:00:03
Message: <3f3e6313$1@news.povray.org>
I guess you are storing the light_source location in a variable, and
calculate the flare point from that in relation to the object.
The idea has potential. I'd like to see, for example, the ocean light up in
pretty flares on a sunny day. In real life, THAT is so beautiful!
Will you calculate the ior values as well? And I expect it's restricted to
light_sources; no global illumination.
A kind of postprocessing would be great, too.
Hugo
Subject: Re: Metal Flares - 1 attachment - 1 attachment
Date: 16 Aug 2003 13:20:47
Message: <Xns93D9C4C0070E4raf256com@204.213.191.226>
hua### [at] post3teledk news:3f3e6313$1@news.povray.org
nope, not exacly ;)
> up in pretty flares on a sunny day. In real life, THAT is so
> beautiful!
it's the next thing I'm planning to write now
I thing current method should work with i.e. glass
it is a postprocessing, a C++ program :)
btw - next version (now with small lanse-flares like in 35mm camera,
visible as small circles) I think animation with moving camera would be
very itneresting.
Currently it takes about 1 min to add flares/glows by my addon, and about 1
h to render image (due to complicated blob, and radiosity).
Download 'metal_flare_2.jpg' (100 KB)
Preview of image 'metal_flare_2.jpg'
Date: 17 Aug 2003 07:42:02
Message: <3f3f6a0a@news.povray.org>
Oooh! That's much better.  :o)  Then I guess, you are sampling the image to
find bright spots (hopefully a 16bit image or more) and add the flares
accordingly. Are you going to deal with soft-glows as well?  I think they're
an important part of the show... MegaPOV 0.7 had postprocessing features;
among them softglow. Two days ago I found a way to make softglows via SDL on
the entire image - and without a double pass. I was inspired by a russian
poster (his image "really hot thing"). But the solution is still unnecessary
slow.
Will you send the patch to the MegaPOV team once finished?
Hugo
Date: 17 Aug 2003 11:10:51
Message: <Xns93DAAEC52A6F3raf256com@204.213.191.226>
hua### [at] post3teledk news:3f3f6a0a@news.povray.org
> image to find bright spots (hopefully a 16bit image or more) and add
still - no ;o) this will give wrong results in some cases i.e. white paper
isn't "sparky" but gray metall (silver) - is.
But yes, my algorithm is quite simillar.
> the flares accordingly. Are you going to deal with soft-glows as well?
What are thoes?  Any examples of images with and without it?
It's a separate program right now I'll thing of it's license later, but
probably it would have freeware version.
Subject: Re: Softglow example
Date: 17 Aug 2003 14:56:06
Message: <3f3fcfc6@news.povray.org>
Tim Nikias recently wrote something in SDL that makes a softglow on specular
highlights. The code I wrote is another approch to obtain the same effect,
but they are all inefficient compared to postprocessing in C++. MegaPOV0.7
had such a solution on an experimental basis along with motion_blur and
faked focal_blur. I'm not sure wether these features have been dropped.
The softglow is a blurred copy of the image, added to the original image,
using a "lighten" combination. Bright spots (with a brightness above 1) will
be mostly affected. Well, provided the format hasn't already been cropped to
24 bit (8 bit luminance).
The reason for having softglows is to simulate a camera or a human eye, that
catches a strong light and spread it around the lens. The same effect
results in flares. In addition, sometimes a photographer uses a blurring
lens for glamour shots; weddings or portraits.
I've searched on google but couldn't find great examples. So here's just the
docs from the implementation in MegaPOV:
http://astronomy.swin.edu.au/~pbourke/geomformats/megapovplus/#PP_Soft_Glow
And a small example:
http://users.skynet.be/bs936509/povfr1/concept1/povfr-gs-pp.htm
Hugo
Date: 17 Aug 2003 17:15:49
Message: <Xns93DAECA591399raf256com@204.213.191.226>
hua### [at] post3teledk news:3f3fcfc6@news.povray.org
hm FUT waring was information, that I set FollowUpTo  to  .general, and
that Yours response would be posted to  povray.general group (the response
is there already, check)
