POV-Ray : Newsgroups : povray.binaries.images : Time for a guessing game Server Time
14 Jul 2026 12:40:36 EDT (-0400)
  Time for a guessing game (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: Time for a guessing game
Date: 28 Feb 2003 19:37:42
Message: <3e6000d6@news.povray.org>
"Greg Edwards" <edw### [at] hotmailcomremovethis> wrote in message
news:78v### [at] 40tudenet...
> Can you guess how many dispersion_samples I used in this image?
    42
~Steve~
Date: 28 Feb 2003 20:39:46
Message: <1grdicm36y68f$.wds94yymlktt.dlg@40tude.net>
>     42
> ~Steve~
Heheh, that's what it looks like, but lower. ^_^
Date: 1 Mar 2003 02:14:19
Message: <3e605dcb@news.povray.org>
3e6000d6@news.povray.org...
>     42
> ~Steve~
I'd like to test Deep Thought as a render computer ( for long renders?)
Slartibartfast
Date: 1 Mar 2003 09:54:47
Message: <2lrjhg0z9ncd$.l5faea8dg60m$.dlg@40tude.net>
>>     42
>> ~Steve~
> Slartibartfast
Actually, this scene only took a few minutes to render IIRC. That's the
beauty of this work. ^_^
Date: 1 Mar 2003 17:58:40
Message: <3e613b20@news.povray.org>
5?
Date: 1 Mar 2003 18:03:44
Message: <3tec8ezq7hn7$.dnmhd3adhb82.dlg@40tude.net>
On Sat, 1 Mar 2003 22:57:52 -0000, Andrew Coppin wrote:
> 5?
Hehehe, a *very* good guess, but... lower! ^_^
Date: 1 Mar 2003 18:58:24
Message: <s3frgqtavmme.21jpi99wuveb$.dlg@40tude.net>
The correct answer is:
2
In case the impossibility didn't hit you yet, I made a patch for POV-Ray
which adds a new speed and quality feature to POV's dispersion. It's
ever-so-creatively called dispersion jitter. Here's the interior{}
statement I used:
interior
  ior 1.5
  #if (!Photons)
  caustics 1
  dispersion 1.1
  dispersion_samples 2
  dispersion_jitter 1
I believe the concept of jittering the dispersion samples and my
implementation are physically realistic and my implementation is compatible
with photon mapping (see attached image). I plan to make this patch
(currently a Windows binary) available as soon as possible.
I've attached a higher quality image with dispersion_samples 5 and photons
and radiosity enabled. This image took a little over 5 hours to render @
960x720 +a0.1 +r4 IIRC with a P3 871 under the noticeably slower VC++
compile.
Download 'disp-jitter-test.jpg' (62 KB)
Preview of image 'disp-jitter-test.jpg'
Date: 2 Mar 2003 07:57:31
Message: <3e61ffbb@news.povray.org>
So... it only does 2 (random) colours per pixel, and AA blurs it so much it
looks clear again?
Andrew.
Date: 2 Mar 2003 14:17:42
Message: <925wml345bfy.95wjmt7ch2ic.dlg@40tude.net>
> looks clear again?
> Andrew.
The first image I posted had only dispersion_samples 2 and lots of AA to
clear things up but the patch can handle any number of dispersion_samples
and dispersion_jitter can be set to any float value but if it's out of the
0 to 1 range, a warning will be issued and the problem corrected. You can
also specify dispersion_jitter on which will set it to 1. The result is
similar to the jitter effect of area lights. Any number of samples can be
used but using many samples will just allow you to use less AA to get good
results. The second image used dispersion_samples 5.
Date: 2 Mar 2003 14:43:29
Message: <3e625ee1@news.povray.org>
Fair enough...
Man, there are so many POV-Ray patches out there, anyone would think it's
*easy* to recompile the thing! <8-0>
Andrew.
