> I want to have a white mesh2 screen with slowly growing
> black polka dots, which finally overlap until no white is visible
> anymore - but instead they just stop growing as they touch each other!
> Is there a way to keep them growing anyway? Or do I have to use a
> different pigment pattern?
You need to use a different pigment pattern.
"The cylindrical pattern creates a one unit radius cylinder along the Y axis.
..... It starts at 1.0 at the origin and decreases to a minimum value of 0.0 as
it approaches a distance of 1 unit from the Y axis. It remains at 0.0 for all
areas beyond that distance."
https://wiki.povray.org/content/Reference:Cylindrical_Pattern
You probably want to use something like a
pigment { function {}} block, where you use sqrt(x*x+y*y) < Radius.
And then use your clock to change the radius
(that would give you a single growing disk)
To get around that, use sqrt (mod(x,1)*mod(x,1)+mod(y,1)*mod(y,1)) which will
make every disk repeat every unit.
But then you have to center them, using Mike Williams' repeat unit fix.
"Using mod(x,2) will cause the shape to be repeated in the x direction every 2
units. If your original isosurface
created a shape centred at the origin, then there's a problem with the way that
it chooses which bits to repeat.
The left half of the object gets repeated in one direction and the right half of
the object gets repeated in the other
direction. To fix this, we'd like to substitute mod(x,2)+1 where x is negative
and mod(x,2)-1 where x is positive. To
fix both directions at once, for a symmetrical object, we can use abs(x) like
this mod(abs(x),2)-1.
Page 17 of 149
To change the length of the repeat unit we can do this mod(abs(x),Step)-Step/2."
Which should give you:
sqrt ( (mod(abs(x),2)-1) * (mod(abs(x),2)-1) + (mod(abs(y),2)-1) *
(mod(abs(y),2)-1) )
If you just use the function value, you'll probably get a gradient.
You can use the above function to calculate a value by subtracting it from your
radius. Use that as the first argument in a select() statement, and return 1 or
0 to get a hard white to black transition.
Hope that's understandable and helps.
- BE
So, try this:
If you take your clock value and multiply it by sqrt(2), then the black will
reach all the way into the corner of each square, and will give you a fully
black texture.
- BE
#version 3.7;
global_settings{ assumed_gamma 1.0 }
#default {finish {ambient 0 diffuse 1} }
//orthographic
location <0,0,-50> // position & direction of view
look_at <0,0,0>
sky_sphere {pigment {rgb 1}}
light_source {<0, 0, -100> rgb 1}
#declare Dots = function {sqrt ( (mod(abs(x),2)-1) * (mod(abs(x),2)-1) +
(mod(abs(y),2)-1) *
(mod(abs(y),2)-1) )}
#declare Radius = sqrt(2);
plane {z, 0 pigment {function {select (Dots (x, y, z) - Radius, 0, 1)} } }
Subject: Re: Cylindrical pattern animation - how to get the circles/dots overlap
Date: 12 Jun 2026 18:00:18
Message: <6a2c8172$1@news.povray.org>
Hi(gh)!
Am 12.06.26 um 21:29 schrieb Bald Eagle:
Just for better understandig: what do the second and third parameters of
select() represent? Are they just compressed rgb vectors, i. e. black
and white?
See you in Khyberspace!
Yadgar
VBI BENE, IBI BACTRIA!
> and white?
Yes. 0 gets vector-promoted to rgb <0, 0, 0>, and 1 gets vector-promoted to rgb
<1, 1, 1>.
Date: 13 Jun 2026 07:40:02
Message: <6a2d4192$1@news.povray.org>
Hi(gh)!
Am 13.06.26 um 03:03 schrieb Bald Eagle:
>> and white?
> <1, 1, 1>
Are you sure? If I replace them with actual color vectors, I get the
error message "Parse Error: Expected 'operand', color
keyword 'rgb' found instead"! How can I use real colors instead?
Yadgar
Absolutely.
You are trying to shove a keyword and a vector into a scalar-only function that
gets parsed by the function VM.
Use a pigment_map. or a color_map.
In that case, you can even get rid of the select() statement.
The _maps do exactly that: they map the output values of your function to
colors, pigments, textures, normals, or materials.
color_map {
[ 0.0 rgb <0, 0, 0>]
[ 0.5 rgb <0, 0, 0>]
[ 0.5 rgb <1 ,1 ,1>]
[ 1.0 rgb <1 ,1 ,1>]
Double entries at 0.5 give a hard transition.
Now any value below 0.5 will be black, and any value above 0.5 will be white.
- BE
Date: 13 Jun 2026 09:31:32
Message: <6a2d5bb4$1@news.povray.org>
Hi(gh)!
Am 13.06.26 um 13:57 schrieb Bald Eagle:
> color_map {
I tried this, but now I get rings rather than growing solid black dots,
as you can see in the attachment (clock=20)!
Yadgar
Download 'baldeagle_test.png' (20 KB)
Preview of image 'baldeagle_test.png'
Scratch that. Keep the select () statement.
You'll get solid dots with select.
- BE
Date: 13 Jun 2026 12:32:01
Message: <6a2d8601@news.povray.org>
Am 13.06.26 um 17:25 schrieb Bald Eagle:
...but then, again, no other colors than black and white?
No.
The original function that uses select () outputs either 0 or 1.
You feed the result into a color_map, which allows you to use rgb colors.
- BE
