Hi(gh)!
To generate gold-textured carved inscriptions in marble, I need tapering
font characters... and (besides turning them into heightfields and
rotating them afterwards by 180 degrees before subtracting them from the
marble plate) they only way to achieve this is converting them into
prism objects and adding the taper_sweep modifier... how could I do this?
See you in Khyberspace!
Yadgar
VBI BENE, IBI BACTRIA!
Le 2026-02-08 à 11:16, Jörg "Yadgar" Bleimann a écrit :
> Hi(gh)!
> Yadgar
Try the Bevelled_Text macro from shapes.inc.
#macro Bevelled_Text(Font, String, Cuts, BevelAng, BevelDepth, Depth,
Offset, UseMerge)
BevelAng is in radians.
UseMerge need to be 0.
Cuts determine the smoothness.
Use that macro with scale -1*z to place the bevel on the back of the text.
I avoid Bevelled_Text() because it's prone to artifacts on the inside
corners of glyphs. Have you seen my beveled text isosurface tutorial?
If you prefer height fields, I'm sure the technique can be adapted for
those.
https://github.com/CousinRicky/IsoBevelTut
