POV-Ray : Newsgroups : povray.binaries.images : Borked diacritical marks Server Time
7 Jul 2026 05:00:30 EDT (-0400)
  Borked diacritical marks (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Borked diacritical marks
Date: 31 Jan 2023 11:36:31
Message: <63d9438f$1@news.povray.org>
Le 2023-01-30 à 20:17, Kenneth a écrit :
> "Bald Eagle" <cre### [at] netscapenet> wrote:
>> "Kenneth" <kdw### [at] gmailcom> wrote:
>   (sorry, I hit the 'send message' button too early by mistake)
>>> Doing another test, I've discovered that the web-portal 'editor' for writing
>>> posts is where the problem lies-- it wipes out the sentence before sending it,
>>> when the "Preview Message" button is pressed.
>> The line may either still be there, and only visible in the newsreader (like
>> Thunderbird), or you have to post it with a newsreader, and then it works.
> I was wondering the same thing. I would imagine that I would have to use a
> newsreader to *send* it, since the line disappears on my end before it's
> actually sent.
> A test:
> The following sentence has a special character in one of the words. If you can
> see it in Thunderbird, that would be useful to know. I will not see it using the
> web portal, once it is posted:
> This sentence uses the word exposé.
Everything show up correctly. Viewed in Thunderbird.
Date: 31 Jan 2023 13:10:00
Message: <web.63d958a3b78816609b4924336e066e29@news.povray.org>
Alain Martel <kua### [at] videotronca> wrote:
> > A test:
> > The following sentence has a special character in one of the words...
Thanks! It seems that the problem is only with the newsgroups' web-portal and
message editor.
Date: 3 Apr 2023 08:33:16
Message: <642ac78c$1@news.povray.org>
On 1/22/23 11:57, Cousin Ricky wrote:
> After looking at tx2378's problem ("bad display of utf8 code u00ed
> letter i-accute in times new roman" in p.programming) and becoming
> increasingly confused by what POV-Ray is doing, I rendered a suite of
> Latin-1 accented characters with various fonts.  The results are
> bafflingly inconsistent:
In a thread about povr/v4.0's cmap{} code changes, Bald Eagle asked me
if I'd dug into this issue. I'd not - though I had some guesses as to
what might be wrong.
Well, I'm going to take a run at this issue. Due cmap{} I got some light
exposure to several unix/linux font utilities. Plus I'll be busy with
real life over the next couple months and this work the right sort to
fit here and there as time allows.
I created a test case(a) to see if I could turn up some similar issues
with linux Ubuntu shipped fonts. The first I tried in FreeMono.ttf fails
wonderfully! Plenty of issues when Rendered in POV-Ray(povr). :-)
Aside: I can see already there are two tables in the working DejaVuSans
not in the FreeMono. I have no idea at the moment if that affects anything.
Bill P.
(a) - Yep. The acute lower case i (í) was wrong.
Download 'accentedvowelsstory.png' (32 KB)
Preview of image 'accentedvowelsstory.png'
Date: 3 Apr 2023 21:51:03
Message: <642b8287$1@news.povray.org>
On 4/3/23 08:33, William F Pokorny wrote:
> Bald Eagle asked me if I'd dug into this issue. I'd not - though I had
> some guesses as to what might be wrong.
One of those guesses was that the marks were all present, but not
correctly placed. Meaning they were getting cut off by the automatic
bounding for each character.
Attached is a render turning off all automatic bounding(a) in the povr
fork with -mb - which confirms this is indeed happening.
Bill P.
(a) - The -mb option here fully works only in povr where the v3.6 and
prior '-mb' behavior was restored.
You can use -mb in official v3.7, v3.8 and v4.0 releases, but it no
longer turns off the very last level of bounding around an object.
Download 'accentedvowels_bndsoff.png' (39 KB)
Preview of image 'accentedvowels_bndsoff.png'
Date: 5 Apr 2023 04:38:21
Message: <642d337d$1@news.povray.org>
Update. Found and fixed two issues in the povr fork.
The first accounted for most of the problems where characters were made
up of multiple sub-glyphs. It goes as far back as I checked - to v3.0
source.
It's been the case that x & y offsets for the sub-glyphs, when of
non-word (aka byte) size, have been read as uint_8 and not int8_t
(signed char).
The unsigned values are used with a point offset method not supported in
our code at all. The x & y int8_t (signed char) method is - and it's
what all font's I checked use. The sometimes correct - and sometimes
completely wild results - come more from not handling he twos complement
representation correctly for the read values than having read bad values.
The second issue hits here and there and it is bounding. The bounding
was sometimes too tight for the resulting, flattened point loop
representation of the font.
I don't see a hard problem, say in not looking at all the points or
something. I believe, rather it's that the curve sometimes bulges
outside the least enclosing rectangles of point lists representing the
contours making up the character.
I sized up the bounding x,y size a little and fixed all but the edge of
one case. That one case looks to me like it needs 'too much' expansion.
Leaving it to look at in more detail later.
There is one definite issue is that the umlaut accented characters are
not rendered correctly in the FreeSerif.ttf font. No idea what is going
on there - those characters look OK to me for that font in other utilities.
Test images attached.
Bill P.
Download 'povrfontfixes.png' (265 KB)
Preview of image 'povrfontfixes.png'
Date: 5 Apr 2023 06:35:00
Message: <web.642d4e9ab78816601f9dae3025979125@news.povray.org>
Nice catch.  That certainly accounts for the wild placement, whereas bounding
was just an incidental problem.
Now that you've stuck your head deep into the glyph-handling code, how difficult
would you say it would be to write code in SDL that would take a font file and
create splines and/or prisms?
Or make the internal conversion exposed to SDL so that the result could be
written to a file?
Nice work   :)
- BW
Date: 6 Apr 2023 01:55:39
Message: <642e5edb@news.povray.org>
That is what text{} does - more or less. You just don't see the result
is a union of a bunch of prisms (one per character) - where 'nested'
splines making up a character have been flattened.
> written to a file?
I thought about capturing the result too, and as a complete code hack,
not too bad to do.
Really supporting such a thing in SDL, much harder for sure. I doubt
worth it, but not thought much about performance differences, for example.
There are a large number of font tools out there which can do things
like dump particular glyphs. It's probably not too hard to create
something base on one of those too utilities too.
> Nice work   😄
Thanks.
Oh, I sorted that FreeSerif.ttf umlaut issue - 'twas me having left some
hacked code in place.
I've been playing with other fonts and symbols as a way to test a bit
more. Looking good thus. You do realize somewhat quickly there are
gazillions of free-ish fonts out there, but most cover only a small
number of Unicode character space. Anyhow. Attached another example
image - of some symbols this time.
One thing not working (and not expected to) is anything outside the
Basic Multilingual Plane (BMP). I pushed there a little - and it's all
crash, boom, bang at the moment.
Bill P.
Download 'miscsymbols3.png' (308 KB)
Preview of image 'miscsymbols3.png'
Date: 6 Apr 2023 14:17:45
Message: <642f0cc9$1@news.povray.org>
Any chance of pulling these changes into POV-Ray 3.8?
Date: 6 Apr 2023 14:40:00
Message: <web.642f10d7b78816601f9dae3025979125@news.povray.org>
> > written to a file?
> not too bad to do.
I was sort of thinking about this as an infrequently used tool to export the
splines/prisms to an include file.
Currently, Cousin Ricky and I have resorted to using spreadsheets to convert
font files to splines.  If the extant source code could be easily "fixed" to
remove any C/C++ tricky coding stuff, then I'm sure the rest of us could take it
from there and convert the rest of the C/C++ syntax to SDL to make a nice
include file that could take a font filename as an argument and write out a
series of objects as splines and prisms.
I also look at things like that as a great instructional/learning tool for
people to understand how things happen under the hood, and maybe enough dots get
connected where we have people want to step up to do development work.
(Also, IIRC, since the STL file format is virtually a clone of POV-Ray's
mesh/triangle syntax, it would be fantastic if that geometry could be read from
the file directly without conversion.  Even if it were an experimental feature
that didn't do everything perfectly, it would still be a start, and a handy tool
for importing those kinds of meshes into scenes.)
- BW
Date: 6 Apr 2023 17:09:32
Message: <642f350c$1@news.povray.org>
In this case I think my code changes could be pulled directly into the
v3.8 code base, but it's not something I tried or tested.
See:
http://news.povray.org/povray.beta-test/message/%3C642f33e8%241%40news.povray.org%3E/
or
Message: <642f33e8$1@news.povray.org>
Bill P.
