POV-Ray : Newsgroups : povray.binaries.images : Spiral Server Time
2 Jun 2024 10:51:47 EDT (-0400)
  Spiral (Message 21 to 26 of 26)
Subject: Re: Spiral
Date: 11 Feb 2022 02:36:47
Message: <6206120f$1@news.povray.org>
Op 10/02/2022 om 19:31 schreef Kenneth:
>> Not the same, but this reminds me of Kenneth's airbrush technique
>> (2008, iirc). I am unable to find the exact post here.
>> I was thinking this:
> Sorry for not posting here earlier; I was totally absorbed in running camera
> 'normal' experiments.
> Hmm, I don't remember posting those images, although they look like the
> experiments you and I did in my long-ago post (the one that Yadgar referenced).
> Perhaps from a different 'Kenneth'? I searched all of the image posts for 2008
> and didn't see another fellow by that name. TWO users named Kenneth??
> Impossible! :-P
Sorry, a little misunderstanding here. The images were by me; the
technique was yours ;-)
Probably what Yadgar mentioned. Must have been around July 2008...
> Anyway...I really like these spiral experiments. I was thinking about the
> earlier suggestion of somehow using the technique to reproduce a full-color
> photo-- perhaps by making separate spirals of the image's 3 separate color
> channels (with the spirals colored red/green/blue), but having different
> spacings or gaps between the spirals so that they sort of 'blend together' in
> the viewer's eye. I haven't thought this through in detail, though. By using
> different spiral 'frequencies? Maybe it's not possible geometrically.
By using eval_pigment perhaps, or a pigment function, to evaluate the
colour, then using the result to change the colour of the individual
cones in the spiral...?
Subject: Re: Spiral
Date: 11 Feb 2022 02:40:58
Message: <6206130a$1@news.povray.org>
Op 11/02/2022 om 08:20 schreef m@b:
> On 06/02/2022 11:22 pm, David Buck wrote:
>> This makes me wonder if you could get the illusion of a full-color
>> image by having three spirals - one red, one green and one blue - that
>> are separate but which spiral out together.
>> David
> It's quick and dirty, but here it is, 3 spirals, one red, one green and
> one blue:
Yes! Excellent!
I wondered earlier, in my answer to Kenneth here, if it would be
possible to tint differently individual cones in a spiral? That way only
one spiral would be needed, but I guess that is not allowed.
Subject: Re: Spiral
Date: 11 Feb 2022 11:35:00
Message: <web.62068ffac95e65754cef624e6e066e29@news.povray.org>
> > This makes me wonder if you could get the illusion of a full-color image
> > by having three spirals - one red, one green and one blue - that are
> > David
> one blue:
It worked! That is really cool.
I half-thought that the solution might be to simply scale each successive spiral
slightly larger. But instead, it looks like each spiral begins (in the center)
at 120-degree rotations from each other. Great! I imagine that *more* than 3
colors could be used with the same technique, by simply dividing-up the
rotations differently (and making the spirals appropriately thinner, maybe.)
Like, 6 spirals-colors would use 360/6 rotation adjustments.
Subject: Re: Spiral
Date: 11 Feb 2022 20:01:27
Message: <620706e7$1@news.povray.org>
Wow.  I think that works really well.  If you look closely, you just see
red, green and blue but an overall glance gives you subtle shades of
color.  Cool!
David Buck
>> David
> one blue:
Subject: Re: Spiral
Date: 12 Feb 2022 10:40:00
Message: <web.6207d45fc95e65751f9dae3025979125@news.povray.org>
> color.  Cool!
Right, I saw this effect a while ago, and hadn't gotten around to posting it.
Now it seems like it might have some utility to inspire some experimentation.
https://petapixel.com/2019/07/31/this-black-and-white-photo-uses-color-grid-lines-to-trick-your-brain/
Pretty cool effect / illusion.
I wonder if all 3 spirals could be coincident or layered with rgbf pigments.
Also wondering what a single spiral of closely arranged spheres would look like
with full rgb pigmentation of each individual sphere...
Subject: Re: Spiral
Date: 12 Feb 2022 16:56:18
Message: <62082d02@news.povray.org>
Turns out it wasn't so difficult.
The file sizes for these things are tricky.  Quite often, the PNGs are
smaller than the JPEGs, though I can /sometimes/ get the JPEGs smaller
by using compression 75.
Download 'me-pats-cspiral.png' (240 KB)
Preview of image 'me-pats-cspiral.png'
