POV-Ray : Newsgroups : povray.binaries.images : Fluorapophyllite-(K) Server Time
2 Jun 2024 19:24:29 EDT (-0400)
  Fluorapophyllite-(K) (Message 11 to 20 of 52)
Subject: Re: Fluorapophyllite-(K)
Date: 27 Oct 2021 02:45:36
Message: <6178f590@news.povray.org>
Op 27/10/2021 om 01:09 schreef Samuel B.:
>> Continuing Sam's investigations on crystal shapes and materials, and
>> using KrystalShaper as the primary crystal builder.
>> This is a crystal of apophyllite. The coloured variety is
>> Fluorapophyllite-(K).
> Hey Thomas, it looks good!
Thanks Sam! It turned out rather well indeed. It is a bit out of the way
in terms of colours, but I liked the wikipedia example too much to let
it pass.
> I agree with Bald Eagle that a cleaner render would be nice, but of course that
> would drive up the render time, should you wish to increase the number of
> samples. I mean, you're using scattering media + caustics, and we all know how
> that goes.
I was indeed fully aware of the grainy render, and - at this stage - it
was on purpose for experimentation's sake, as otherwise I would loose
way to much time waiting for the render to finish before starting the
next try. As always, a project starts rendering fast and gradually slows
down along the way when better settings and more stuff are added.
> How long did this take to render? The file name says 004d, so I really hope it
> wasn't 4 days ':/
Oh no! That is the version number ;-) This render was pretty fast: less
than an hour iirc.
> I'd like to discover a cheap and realistic way to add internal fractures to
> mineral renders. Apophyllite is one of those minerals prone to being found in a
> fractured state. I have two ideas in mind, but both are rather expensive: 1)
> height fields intersecting not only each other, but also the crystal shape
> (which is itself an intersection); or 2) isosurfaces. Both can be very, very
> slow. Sometimes I wish media had an ior block.
Ah... yes indeed. I have not considered your first method, but
considered the isosurface one. However, I also cringe at the implied
render time.
Another thing I would like to do is model more asymmetric crystals, like
they occur in nature. The KrystalShaper models are too perfect for our
grubby little hands. :-) Maybe by carefully manipulating the set of
planes in the intersection, or working directly on a mesh2 model
converted back to .obj for instance, and load it up in our favourite
modeller...
> Is there an online POV-Ray render farm anywhere? :P
That would be nice.
> Apophyllite is one of those minerals I'd love to find. Since it occurs in basalt
> vesicles, one might think it'd be everywhere, but finding any mineral-bearing
> cavities is already a challenge...
Yes, you will need a bit of luck I guess.
Date: 27 Oct 2021 05:44:06
Message: <61791f66$1@news.povray.org>
Am 27.10.2021 um 08:45 schrieb Thomas de Groot:
> modeller...
IIRC you're using Silo, but I have no idea if Silo can handle this kind
of plane intersections. Blender can load the WRL data. But as I noticed
these intersecting planes I wondered about the photons. Usually infinite
objects are not recommended as photon targets.
Best regards
Michael
Date: 27 Oct 2021 08:26:50
Message: <6179458a$1@news.povray.org>
Op 27-10-2021 om 11:44 schreef MichaelJF:
Correct. I use Silo, which is why I mentioned an .obj version of the wrl
data by Poseray. Silo does not accept wrl data.
In the meantime, I have done a mesh2 version of the wrl data through
Poseray and that works fine. I had forgotten about the possible trouble
of infinite objects when using photons, so I shall use the mesh2
exclusively with them. Thanks for the reminder indeed.
Date: 27 Oct 2021 09:44:02
Message: <617957a2@news.povray.org>
Crystal replaced by a mesh2 version. Less grainy by not using
stochastic. Render time about 27 minutes. Collected photons, about 1 GB.
Additional scene developments pending.
Download 'krystalshaper_apophyllite_004f.jpg' (54 KB)
Preview of image 'krystalshaper_apophyllite_004f.jpg'
Date: 27 Oct 2021 16:45:00
Message: <web.6179ba1e4f1e127b9d2128f16e741498@news.povray.org>
It's looking better and a little less noisy now. It also seems a bit more
bluish. Looking online, this mineral has a range of hues spanning between
colorless, pale yellow, and pale/bluish green. All seem to be valid.
>> wasn't 4 days ':/
> than an hour iirc.
Thank goodness, lol. That makes more sense.
> render time.
Both methods are going to be slow, yeah. And care must be taken when choosing
the fracture planes for a given mineral. Apophyllite appears to exhibit basal
cleavage, so its fractures tend to be horizontal more often than not.
And then there are clouds... Similar to fractures, the clouds you see in
minerals are often reflective/refractive gas or liquid pockets, and so they
might not easily be replicated with scattering media. (It seems to me that there
was an experimental version of POV-Ray a long time ago which allowed one to
specify the reflectivity of participating media. I wonder what happened to
that?)
> modeller...
Personally, before going that far, I'd just change the distance values of each
crystal face in KrystalShaper, and not even mess with any other program save
POV-Ray. KS is great like that; you can make entirely new minerals if you wish.
And there's always doing what I did: copy the HKL+distance data to POV-readable
arrays. Then you could take it a step further and add some randomization before
the HKL+D data is used to make the intersection.
Besides the symmetry, another thing I noticed about the crystal libraries in KS
is that the secondary and tertiary faces (modifications) tend to be somewhat
exaggerated. My alum render, for instance, was not what you'd consider a typical
specimen; you'd usually only see eight main faces in real life. And the
apophyllite model is the same way: in nature you usually only see cuboids
truncated with a steep pyramid. (The bevel between pyramid faces is atypical.)
None of this is a bad thing, of course, and it helps to show us just how a
mineral can form secondary & tertiary faces.
Sam
Date: 28 Oct 2021 02:46:09
Message: <617a4731$1@news.povray.org>
Op 27/10/2021 om 22:44 schreef Samuel B.:
Yes, in between renders I added a bit more blue.
>>> wasn't 4 days ':/
>> than an hour iirc.
Yes, it is rather fast.
In my latest experiment, I cranked photon spacing down to 0.001 (for the
examples shown here, this was 0.004) but then POV-Ray stopped along the
parsing way, with an 'out of memory' message. Even 0.004 might be
overkill for all I know; I shall need to investigate.
>> render time.
Correct. This needs a good knowledge of crystallography indeed. I am a
layman on this really...
> that?)
Inclusions, yes. Scattering media is a poor substitute. There are the
little foreign grains that got included, and the fluid inclusions. Those
are really interesting!
[Aside] in a very distant past, my wife did a study on fluid inclusions
in quartz crystals from Greece. She could, by cooling the crystals in
liquid nitrogen and then slow heating, determine the original
temperature of the liquid in which the crystal grew. Original pressure
was somehow derived from other factors. I forgot. [/Aside]
But, those fluid inclusions are difficult to model. I was thinking about
clouds of bubbles in liquid (there are a couple of scene files drifting
around in the pov world; I think I have a couple of those somewhere)
using a gaussian distribution scheme...
>> modeller...
Yes, I think you are right there.
Yes, I have been wondering about that. Not being an expert, I have been
hesitating between the different models proposed.
Date: 28 Oct 2021 10:38:45
Message: <617ab5f5@news.povray.org>
Op 27-10-2021 om 22:44 schreef Samuel B.:
>>> wasn't 4 days ':/
>> than an hour iirc.
Strange. Somehow, I must have changed something, but now renders take a
much longer time, more in the range of several hours (and photons jumped
to 3Gb). I do not remember what is different. :-/
Date: 28 Oct 2021 11:27:11
Message: <617ac14f$1@news.povray.org>
Op 28-10-2021 om 16:38 schreef Thomas de Groot:
Found the culprit! :-)
I had changed 'union' to 'merge' in the mesh2 object. In this particular
case of well-behaving crystal faces, that is unnecessary. The render
speed difference is dramatic indeed.
Date: 28 Oct 2021 20:10:00
Message: <web.617b3ad54f1e127bcb705ca46e741498@news.povray.org>
> >> render time.
> > (...) care must be taken when choosing the fracture planes for a given mineral
It doesn't really take any in-depth knowledge. Just a bit of time reading and
browsing through images of minerals. (Which might be too time-consuming,
depending...)
> > might not easily be replicated with scattering media. (...)
Yeah, there are many fascinating inclusions that can occur in minerals. I
remember seeing a photo of some white crystals occasionally found in obsidian.
IIRC, they formed in groups of four tetrahedral crystals meeting at their
corners. Pretty much like the first iteration of a Sierpinski tetrahedron. If I
come across the image again, I'll post it. (Image search isn't turning up
anything relevant, and I originally found it in a book.)
Crazy! I haven't a clue how those environmental factors could possibly be sussed
out. That's hacking, as far as I'm concerned... Physical hacking, not digital,
which is even cooler. She sounds like an awesome woman :)
Inclusions are pretty much the main impediment to making better mineral renders.
And inclusions take on many forms. Not all exhibit crystalline features when
viewed with the naked eye (e.g. light reflecting at certain angles only). Some
do, though. I had (or still have) a Herkimer 'diamond' that apparently has an
inclusion in the shape if a tiny quartz crystal. The bubble really looks like a
tiny, doubly-terminated quartz crystal. I'll have to take a photo of that.
> > exaggerated. (...)
Eh, nothing is written in stone. (Haha, except stones.) But there are always
outliers to these things. Depending on the conditions in which a chemical is
grown, modifications may become more or less prominent. You never know.
Sam
Date: 29 Oct 2021 06:50:00
Message: <web.617bd1d34f1e127b1f9dae3025979125@news.povray.org>
> out.
I would imagine that it might have something to do with the phase diagram of the
material.  Freeze the material so that it's solid, and then do a melting-point
test by the usual slow heating.  Maybe there's some specialized
pressure-temperature nomograph that's been developed for this type of thing...
