POV-Ray : Newsgroups : povray.binaries.images : Beam Engine Server Time
18 Nov 2025 04:14:37 EST (-0500)
  Beam Engine (Message 1 to 10 of 23)
Subject: Beam Engine
Date: 11 Jan 2021 21:38:35
Message: <5ffd0bab@news.povray.org>
My first attempt at using radiosity.
Comment welcome.
m@
Download 'beam engine radiosity large 50pc.png' (1145 KB)
Preview of image 'beam engine radiosity large 50pc.png'
Subject: Re: Beam Engine
Date: 12 Jan 2021 15:10:05
Message: <web.5ffe01aff4c22fe26adeaecb0@news.povray.org>
> Comment welcome.
> m@
The beams through media look very crisp and nice. here are a fex remarks in the
order that would matter most first:
There seems to be too much light from inside to have a balance that would reveal
radiosity well. Could the inside lights be dimmed ? maybe even remove with
radiosity. The scene would contrast more
Some of the colors are too saturated. (srgb? assumed_gamma?)
the reflective elements, show too strong a total reflective amounts. You can use
conserve_energy and albedo keywords to solve that.
Date: 12 Jan 2021 16:15:00
Message: <web.5ffe10b6f4c22fe24d4aa4600@news.povray.org>
> Comment welcome.
> m@
A cool scene!
You need area light for the sun. Radiosity seems okay, perhaps a bit bright for
such small window area.
As said by Mr., colors and textures aren't very realistic - colors are extreme
and the surfaces are too clean. The metal finishes use a diffuse value like 0.6,
which is much to high. Good values are 0.05 to 0.2 together with reflection
values like reflection {0.3 metallic} or higher.
Keep up the good work,
Norbert Kern
Date: 12 Jan 2021 20:08:57
Message: <5ffe4829@news.povray.org>
> Comment welcome.
Nice work on the stained glass windows and the script-patterns on the
pillars!
How did you make the spiral things on the lamps?
Hajo
Date: 13 Jan 2021 03:57:50
Message: <5ffeb60e$1@news.povray.org>
m@b wrote on 12/01/2021 03:37:
> Comment welcome.
> m@
A very promising scene!
Paolo
Date: 13 Jan 2021 11:50:45
Message: <5fff24e5$1@news.povray.org>
>> Comment welcome.
> pillars!
I don't know, but it could be a sphere_sweep, probably stretched in one
direction.
Date: 13 Jan 2021 17:46:55
Message: <5fff785f$1@news.povray.org>
> direction.
Quite some times I wished PovRay had a prism or polygon sweep feature.
Some of my PovRay works:
https://www.deviantart.com/antarasol/gallery/42758766/3D
Date: 14 Jan 2021 02:19:17
Message: <7328e96e-cec5-cd6d-510e-144790e8793a@googlemail.com>
>> Comment welcome.
> pillars!
It's a bunch of cylinders:
      #for(Count_1,0,410)
          cylinder{<0,0,-0.1-Count_1/410>,<0,0,0.1+Count_1/410>,0.2
translate<Count_1/80,2,0> rotate<0,0,1.5*Count_1> }
Date: 14 Jan 2021 02:39:55
Message: <ac97c48a-edc6-35d5-4464-17b5193f1187@googlemail.com>
>> Comment welcome.
>> m@
Thanks for the comments.
I have reduced the gamma, gray_threshold and brightness.
The steel-work is now a darker pigment and less reflective.
Getting there slowly, this radiosity thing is complicated :-)
m@
Download 'beam engine radiosity.png' (1239 KB)
Preview of image 'beam engine radiosity.png'
Date: 14 Jan 2021 02:49:51
Message: <30f32358-b8fa-2b34-8060-4fa22f24b440@googlemail.com>
>> Comment welcome.
> pillars!
The Stained glass windows and pillar decorations are lifted from photos
on the internet :-)
e.g <https://venues4hire.org/venue/details/14199/papplewick-pumping-station>
m@
