POV-Ray : Newsgroups : povray.binaries.images : Stock colors and assumed_gamma 1 in POV-Ray 3.6 Server Time
28 Sep 2024 17:52:58 EDT (-0400)
  Stock colors and assumed_gamma 1 in POV-Ray 3.6 (Message 28 to 37 of 77)
Subject: Re: Stock colors and assumed_gamma 1 in POV-Ray 3.6
Date: 17 Oct 2020 16:35:06
Message: <web.5f8b54d476c60ba8a8a81eb0@news.povray.org>
hi,
"Kenneth" <kdw### [at] gmailcom> wrote:
> Our computers/monitors have an intrinsic built-in  'gamma' of generally around
> 2.2. That computer gamma is the curved "CRT gamma line" in the diagram. The
> straight line represents color values fed to the display.
monitors tend to have an OSD where colour "profiles" can be selected; eg I can
choose from 9300K, 6500K, custom, and srgb.  so should I (continue to) go with
'srgb' and use 'assumed_gamma 1' in all my scenes, or...?
regards, jr.
Date: 17 Oct 2020 21:25:00
Message: <web.5f8b978e76c60ba8d98418910@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
I wish I had a monitor like yours, with more sophisticated controls; mine is
currently a cheap LED-backlit LCD 'TV'. It doesn't have choices like 6500K etc,
just the dumb 'consumer' choices like 'sports', 'movies', 'baseball'(!), etc.,
along with manual custom settings.  (I'm researching new monitors at the moment,
looking for something that has spot-on color accuracy re: sRGB. It's turning
into a lengthy search!)
My understanding is that 6500K is the 'standard' color temperature for a
monitor; take a look here...
https://www.eizo.com/library/basics/color_temperature_on_an_LCD_monitor/
I assumed color temperature was a different 'thing' than  'srgb'; it's a
surprise to me that your monitor gives you that particular choice, but I could
be wrong (or  ill-informed at present.) I wish I could be more helpful.
In POV-ray, I presently use assumed_gamma 1.0, the long-recommended value (along
with srgb colors rather than linear rgb.) But one of the new nagging questions
that I currently have is about the use of the newer assumed_gamma srgb, and what
effect *it* may have on a rendered scene. The documentation isn't clear as to
why it's an alternative. Since it is nearly a 2.2 gamma, it is bound to have a
rather profound effect, at least in the render preview. I've never used it
before, but I plan to run some tests.
Date: 17 Oct 2020 22:20:01
Message: <web.5f8ba60476c60ba8d98418910@news.povray.org>
> No worries.
> Copy/paste error.
> Just forgot to delete the "1.055 * " preceding the pow() formula.
> I also think that 0.04045 should be replaced by the true value of
> 0.0031308 * 12.92 = 0.040449936
> [code...]
That is some ingenious coding! I haven't run your SDL code yet, but will do so
ASAP-- just to see the graphing results on MY computer screen ;-) Your coding
skills continue to amaze me.
I'm still assessing the 'totality' of how and what those Wikipedia equations +
POV-ray do as a combo, to get a nice and correct image file. It seems to me that
it follows these steps:
1) We work on a POV-ray scene in an assumed_gamma 1.0 'world', which is a linear
world (except for the use of more-pleasing srgb colors, which are NOT linear, at
least in the visual preview). Everything else in the scene is (or should be)
'linear'--lighting, radiosity effects, etc. (Well, as a simplification).
2) For the rendered output file, the scene is encoded as srgb (assuming that
POV-ray's File_Gamma is set that way.) This essentially 'brightens' the scene by
way of the *actual* RGB-to-SRGB formula, before sending it to the video
card/monitor. (My previous assessment, anyway.)
3) The 2.2-gamma monitor then 're-darkens' the scene, to be what we saw in
POV-ray's preview.
What that means (to my thinking) is that the saved image file's on-screen
appearance, as viewed on the 2.2-gamma monitor, is actually a 'linear image'
again, so to speak-- just like in POV-ray's preview-- the scene's lighting, etc,
etc. EXCEPT for the colors that we used, which were 'srgb darkened' when we
worked on the scene. (I know that when we use such colors, POV-ray actually
works with their 'linear' values internally-- so I guess that, for example, srgb
0.50 becomes 'linear 0.22' behind the scene; that's the only way it makes sense
to me, in order for the saved file to properly show 0.22 later.)
Some of this may be conjecture, of course. I know that Clipka spent a good deal
of time in the past, attempting to explain this pipeline and its many arcane
details. My explanations and understanding may differ from his; he knew a LOT
more about this stuff than I currently do.
Date: 18 Oct 2020 00:28:25
Message: <5f8bc469$1@news.povray.org>
My monitor is set to sRGB with a white point of D65 (6504 K), but I also
have an app that lowers the color temperature to 3500 K at night.  Aside
from the greens appearing more vivid and green shades less easy to tell
apart, I barely notice the change; my eyes adjust, and my sleep is
probably better for it.  Of course, if the app abruptly quits (like when
I accidentally shut it off just now while checking the settings), the
difference is shockingly.  It's like the whole computer turns bright blue!
Prior to my current computer, which has a backlit LCD with an sRGB
preset, I had manually set the gamma curves using clipka's gamma
checking scene and a few test patterns of my own as benchmarks.
As I see it, assumed_gamma srgb is useful for updating legacy scenes
that did not have an assumed_gamma, so they would run without warnings
in POV-Ray 3.7, or at least render predictably in any POV-Ray version.
(assumed_gamma has been available since 3.0, if not earlier, but 3.7 was
the first version to fuss about it.)  With all the tweaks necessary to
get the lighting right in the original scene, inserting assumed_gamma 1
into a legacy scene and slapping srgb on all of the pigments is unlikely
to end well.  Short of a rewrite of the entire scene (which some POVers
have done), it's best to just make explicit in the code the sort of
monitor it was developed under.
At least that's my take as someone who has used assumed_gamma 1 from the
beginning.  Some POVers (I can name a couple) prefer an unrealistic
gamma for artistic reasons.
But assumed_gamma 2.2 (or 1.8 or whatever) would be used for the same
reasons.  I guess assumed_gamma srgb was added for the sake of ungamma'd
scenes that were developed with an sRGB monitor.  Or maybe it's just for
completeness.  I don't know.  Maybe Chris Cason knows?
Date: 18 Oct 2020 04:15:00
Message: <web.5f8bf8da76c60ba8a8a81eb0@news.povray.org>
"hi,
you probably don't.  :-)  the monitor is years old and, by today's standards,
quite small (1280x1024).  (it's a 17" Hewlett Packard, model HP1702.  there's
and thanks for the Eizo link.  apparently, "movies" == 6500K.
> ... I wish I could be more helpful.
you were!  (as was Cousin Ricky's post)
regards, jr.
Date: 18 Oct 2020 09:05:08
Message: <web.5f8c3c7b76c60ba81f9dae300@news.povray.org>
I hadn't ever really understood functions - I'm not sure why - probably some
frustrating syntactical thing - until I worked on my pattern value scenes and
jr's moving media.  W. Pokorny truly helped clarify what was going on, and from
time to time I just find the functions easier to implement than a macro.
You also can't make a pigment pattern with a macro - it _has_ to be done with a
function, so that the global <x,y,z> coordinates are what control the pattern
values.
"Each of the various pattern types available is in fact a mathematical function
that takes any x, y, z location and turns it into a number between 0.0 and 1.0
inclusive. That number is used to specify what mix of colors to use from the
color map."
http://wiki.povray.org/content/Reference:Color_Map
It's a giant headache, but I just keep practicing.  30 error messages later, I
come up with something that works...   :D
We do a lot of speculating here, and what I've found is that (for me, anyway) a
diagram of what's happening really helps me follow the text.  Especially when
there's a way that works correctly and a way that doesn't.
The next step that really cements the concept in my head is to sit down and code
it out.  If I want to show how POV-Ray does something, then I should be able to
scribble out some SDL that actually does what I'm talking about.  Say, take some
sphere with a mid-range color and convert the colors to sRGB for comparison.
Then convert the colors back to RGB and make sure the spheres are exactly the
same color.  Compare any user-defined formulas to the internal conversion done
with the srgb keyword by listing the eval_pigment results of both spheres...
It's really only when I start doing the above that I really start to understand
the concepts, the limitations, and the problems.  And of course, there's some
unexpected bug that's been lurking in there...   ;)
It's really a slow and painful thing to do, but the parser is like the military
school, and I'm the remedial student.  And I just keep running the gauntlet
until I get it right, or at least I get something that runs with no errors.  ;)
So, my "coding skill" is really just the result of 8 years of parser (and
clipka) enforced aversion therapy.  :D
Maybe reading some of these discussions will help.
http://wiki.povray.org/content/User:Clipka/Gamma
http://www.povray.org/documentation/view/3.8.0/260/
http://wiki.povray.org/content/HowTo:Migrate_old_scenes_to_work_with_the_new_gamma_system
http://news.povray.org/581b1660%40news.povray.org
http://news.povray.org/povray.binaries.images/thread/%3C585abdb8%40news.povray.org%3E/
Date: 18 Oct 2020 12:50:00
Message: <web.5f8c712376c60ba8d98418910@news.povray.org>
> jr's moving media.  W. Pokorny truly helped clarify what was going on...
Yeah, functions are still somewhat of a mysterious 'black box' for me; I'm
probably where you were 8 years ago! But I try to s*l*o*w*l*y keep learning
(ouch).
> until I get it right...
Ha, a perfect analogy. LOL!
Funny!
THANKS for the "gamma/Clipka" link-- I don't think I've ever seen that specific
explanation in the wiki(!)
Date: 18 Oct 2020 13:25:01
Message: <web.5f8c791676c60ba8d98418910@news.povray.org>
> > But one of [my] new nagging questions...is about the use of the newer
> > assumed_gamma srgb, and whateffect *it* may have on a rendered scene.
> > The documentation isn't clear as to why it's an alternative. Since it
> > is nearly a 2.2 gamma, it is bound to have a rather profound effect,
[Ricky wrote:]
> ...With all the tweaks necessary to
> At least that's my take...
Yep, that was the conclusion I was coming to as well: using assumed_gamma srgb
along with linear RGB colors in the scene, as in the 'old days'-- to get the
previous image results we expected when some of us used assumed_gamma 2.2 then
(against the recommendation of assumed_gamma 1.0). Admittedly, I was one of
those folks :-O
Thanks for the concurring opinion; I see now that I don't necessarily need to
re-write some of my old and complex scenes, IF I want to reproduce them in
v3.7xx/3.xx *as they were* in the v3.6 days. But I also see that they DO need
updating for my current assumed_gamma 1.0 use (at least updated with sgrb
colors, if not lighting tweaks etc) if I want them to look as realistic as they
*should*.
I agree. (I have no real clue or memory as to whether my old PC computers and
monitors worked in 'gamma 2.2' space as opposed to 'gamma srgb' space. That was
before I even understood what it was all about. I think is was just 'plain' 2.2
then, but who knows.)
Date: 18 Oct 2020 14:35:00
Message: <web.5f8c8a0b76c60ba8d98418910@news.povray.org>
I just came across a discussion by Clipka (in answer to a question by Mike
Horwath in 2015) about LIGHT use in v3.7xx-3.8xx, when using assumed_gamma 1.0:
"Should we use rgb or srgb colors in light sources?"
http://news.povray.org/povray.binaries.images/attachment/%3Cweb.5dc98ba0982994b4e0c1802f0%40news.povray.org%3E/clipkas%
20gamma%20tutorial.pdf
It is definitely worth reading, as it covers other gamma-related color topics as
well.
Date: 18 Oct 2020 15:20:04
Message: <web.5f8c93eb76c60ba8d98418910@news.povray.org>
s%
> well.
[Bald Eagle wrote earlier:]
> The other issue that was brought up (somewhere, by someone) is trying to use
> sRGB values in a color map - because the color_map will interpolate linearly,
> whereas the sRGB color space is nonlinear.
Here's a link from 2010(!) that Warp posted, which I think was the initial
'seed' for the Clipka/Horwath discussion-- although it was specifically about
color-map interpolation post-v3.6xx. I made few comments there as well, but
that was at a time when I was rather dogmatic about using assumed_gamma 2.2 in a
scene. Sorry! :-O
Between Clipka and Warp with their differing viewpoints, it was a battle of epic
proportions! ;-)
http://news.povray.org/povray.beta-test/thread/%3C4d0e666b@news.povray.org%3E/
