POV-Ray : Newsgroups : povray.binaries.images : Applying textures to a spherical heightfield section afterwards? Server Time
25 Jun 2026 05:12:06 EDT (-0400)
  Applying textures to a spherical heightfield section afterwards? (Message 11 to 17 of 17)
Subject: Re: Applying textures to a spherical heightfield section afterwards?
Date: 14 Sep 2020 23:45:09
Message: <5f6038c5@news.povray.org>
On 14.09.20 19:38, Bald Eagle wrote:
> =?UTF-8?Q?J=c3=b6rg_=22Yadgar=22_Bleimann?= <yaz### [at] gmxde> wrote:
>> I tried your suggestions, but still get the "out of range" error!
> I can say from long and painful experience that you need more (switchable)
> #debug statements so that you can follow along as the code progresses.
I included debug.inc, invoked Debug_Inc_Stack()... and nothing happened,
no additional messages at all, just that notorious "File
'mesh2/n42e044_5x5.inc' line 96: Parse Error: Texture index out of range
in mesh2.".
To make things easier, I generated a tiny 5x5 mesh2 before:
#default { finish { ambient 0.05 diffuse 1 brilliance 0.25 } }
#declare ApproxLook = <-3295778.3537,4308723.8277,3353808.4183>;
#declare Earth_Slice_n42e044=
mesh2
   vertex_vectors
25
     <2884.8178,-40532.7525,56082.6582>,
     <-9171.5619,-40308.4150,44746.1601>,
     <-21188.6401,-40084.4363,33366.7545>,
     <-32877.9350,-40230.5532,21652.1961>,
     <-44580.6796,-40306.6256,9952.5033>,
     <13057.8787,-23755.4346,45548.1452>,
     <1330.1334,-23909.1988,33947.0299>,
     <-10630.4449,-23708.0951,22585.0805>,
     <-22695.4630,-23321.5223,11326.5482>,
     <-34370.6821,-23387.2495,-329.0233>,
     <23221.9340,-6962.3006,35022.9578>,
     <11316.8721,-6836.8635,23677.4411>,
     <-399.8051,-6905.9531,12137.8952>,
     <-12333.4551,-6640.1561,818.8397>,
     <-24333.2326,-6238.3055,-10436.7932>,
     <33304.7484,9943.2953,24581.8979>,
     <21837.6885,9539.8892,12858.6481>,
     <9658.4610,10127.7787,1866.7320>,
     <-1845.2730,9879.2958,-9816.8170>,
     <-13884.9949,10384.4651,-20958.2292>,
     <43363.8318,26887.7446,14165.4121>,
     <31606.8161,26914.8515,2812.8338>,
     <19694.9660,27199.3287,-8382.2095>,
     <9001.1538,25928.0627,-20815.7556>,
     <-2940.1603,26357.8266,-31979.7411>
	normal_vectors
     25
     <0.5096,-0.6575,-0.5550>,
     <0.5112,-0.6702,-0.5381>,
     <0.4969,-0.6771,-0.5429>,
     <0.5235,-0.6600,-0.5389>,
     <0.5386,-0.6507,-0.5352>,
     <0.5223,-0.6637,-0.5354>,
     <0.5175,-0.6623,-0.5418>,
     <0.5150,-0.6604,-0.5465>,
     <0.5212,-0.6557,-0.5463>,
     <0.5283,-0.6507,-0.5454>,
     <0.5265,-0.6504,-0.5475>,
     <0.5258,-0.6582,-0.5388>,
     <0.5125,-0.6571,-0.5527>,
     <0.5174,-0.6584,-0.5466>,
     <0.5010,-0.6580,-0.5621>,
     <0.5376,-0.6595,-0.5254>,
     <0.5256,-0.6511,-0.5475>,
     <0.5208,-0.6458,-0.5582>,
     <0.5231,-0.6730,-0.5229>,
     <0.4809,-0.6849,-0.5474>,
     <0.5475,-0.6387,-0.5406>,
     <0.5205,-0.6327,-0.5733>,
     <0.5518,-0.6599,-0.5099>,
     <0.5125,-0.6946,-0.5048>,
     <-0.5136,-0.6801,0.5232>
   uv_vectors
     25
<0.000000,0.000000>,
<0.250000,0.000000>,
<0.500000,0.000000>,
<0.750000,0.000000>,
<1.000000,0.000000>,
<0.000000,0.250000>,
<0.250000,0.250000>,
<0.500000,0.250000>,
<0.750000,0.250000>,
<1.000000,0.250000>,
<0.000000,0.500000>,
<0.250000,0.500000>,
<0.500000,0.500000>,
<0.750000,0.500000>,
<1.000000,0.500000>,
<0.000000,0.750000>,
<0.250000,0.750000>,
<0.500000,0.750000>,
<0.750000,0.750000>,
<1.000000,0.750000>,
<0.000000,1.000000>,
<0.250000,1.000000>,
<0.500000,1.000000>,
<0.750000,1.000000>,
<1.000000,1.000000>
   face_indices
          32
     <0,1,5>,0,
     <1,6,5>,0,
     <1,2,6>,1,
     <2,7,6>,1,
     <2,3,7>,2,
     <3,8,7>,2,
     <3,4,8>,3,
     <4,9,8>,3,
     <5,6,10>,4,
     <6,11,10>,4,
     <6,7,11>,5,
     <7,12,11>,5,
     <7,8,12>,6,
     <8,13,12>,6,
     <8,9,13>,7,
     <9,14,13>,7,
     <10,11,15>,8,
     <11,16,15>,8,
     <11,12,16>,9,
     <12,17,16>,9,
     <12,13,17>,10,
     <13,18,17>,10,
     <13,14,18>,11,
     <14,19,18>,11,
     <15,16,20>,12,
     <16,21,20>,12,
     <16,17,21>,13,
     <17,22,21>,13,
     <17,18,22>,14,
     <18,23,22>,14,
     <18,19,23>,15,
     <19,24,23>,15
   texture
     uv_mapping pigment { P_BlueMarble_Section_n42e044 }
   double_illuminate
   translate ApproxLook
...but why line 96? What have the uv_vectors to do with the face
indices? WHY?!?
See you in Khyberspace!
Yadgar
Date: 14 Sep 2020 23:59:23
Message: <5f603c1b@news.povray.org>
> indices? WHY?!?
Check your syntax.
https://www.povray.org/documentation/view/3.6.1/293/
face_indices, as you use it, is providing a texture_index (either 0, 1
or 3 can be provided).
It is a waste when uv_indices is provided.
Especially as you do not have a texture_list section.
> Yadgar
Date: 15 Sep 2020 00:18:12
Message: <5f604084$1@news.povray.org>
Hi(gh)!
But I have no uv_indices, just uv_vectors!
Yadgar
Date: 15 Sep 2020 07:00:01
Message: <web.5f609e1857afda211f9dae300@news.povray.org>
http://wiki.povray.org/content/Reference:Mesh2
My guess is that you may be missing a section of data.
Perhaps POV-Ray creates uv-index data where it is missing, (<0, 0>?) and that
doesn't jive with whatever it needs to do.   Or it's just a bad/misleading
error.
Make a 2x2 or 3x3 mesh, or make an inc file to store your test mesh(es) in.
(just to keep the amount of text in the main pov file down.)
Then you can write a scene with various permutations and choose them with
#switch.
That way you never delete the mistakes, you don't repeat failed experiments, and
when something doesn't work, you can //comment that section with "Doesn't work"
and copy-paste the exact error into the comments as well.
It's easier than having 32 different pov files and trying to meaningfully name /
differentiate them all.
That way it's a record of what you tried and what you haven't yet, that can act
as a reference for you - and others if you post it.
Date: 15 Sep 2020 13:40:00
Message: <web.5f60fadb57afda216e3057d70@news.povray.org>
> error.
Bill,
I have a suspicion that Yadgar does not read my replies, so I'll reply to you
instead.
Yadgar's problem is likely, like Jerome Grimbert explained, the unnecessary (?)
texture indices in his face_indices block. (I believe that Jerome Grimbert meant
to write "uv_vectors" when he wrote "uv_indices".)
POV-Ray complains, rightfully but not very comprehensible, when it reaches the
index to the first texture; because there is no texture_list block before the
face_indices block (as shown on the documentation page Jerome Grimbert linked
to).
What I find interesting though, is that it IS possible to combine UV-mapping and
a texture list: One can place several UV-mappable textures in the texture list
and then refer to each of them in the face_indices block thereafter.
I suspcet that this may be useful if one has several image map tiles that are to
be UV-mapped to different regions of the mesh.
Here's a complete scene that renders without problems if one provides an image
for the UV-mapping:
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7 =======
global_settings { assumed_gamma 1.0 }
default {
        finish {
            diffuse 0
            ambient color Black
            emission color White
#declare Earth_Slice_n42e044 =
    mesh2 {
        vertex_vectors {
            25
            <  2884.8178, -40532.7525,  56082.6582>,
            < -9171.5619, -40308.4150,  44746.1601>,
            <-21188.6401, -40084.4363,  33366.7545>,
            <-32877.9350, -40230.5532,  21652.1961>,
            <-44580.6796, -40306.6256,   9952.5033>,
            < 13057.8787, -23755.4346,  45548.1452>,
            <  1330.1334, -23909.1988,  33947.0299>,
            <-10630.4449, -23708.0951,  22585.0805>,
            <-22695.4630, -23321.5223,  11326.5482>,
            <-34370.6821, -23387.2495,   -329.0233>,
            < 23221.9340,  -6962.3006,  35022.9578>,
            < 11316.8721,  -6836.8635,  23677.4411>,
            <  -399.8051,  -6905.9531,  12137.8952>,
            <-12333.4551,  -6640.1561,    818.8397>,
            <-24333.2326,  -6238.3055, -10436.7932>,
            < 33304.7484,   9943.2953,  24581.8979>,
            < 21837.6885,   9539.8892,  12858.6481>,
            <  9658.4610,  10127.7787,   1866.7320>,
            < -1845.2730,   9879.2958,  -9816.8170>,
            <-13884.9949,  10384.4651, -20958.2292>,
            < 43363.8318,  26887.7446,  14165.4121>,
            < 31606.8161,  26914.8515,   2812.8338>,
            < 19694.9660,  27199.3287,  -8382.2095>,
            <  9001.1538,  25928.0627, -20815.7556>,
            < -2940.1603,  26357.8266, -31979.7411>
        normal_vectors {
            25
            < 0.5096, -0.6575, -0.5550>,
            < 0.5112, -0.6702, -0.5381>,
            < 0.4969, -0.6771, -0.5429>,
            < 0.5235, -0.6600, -0.5389>,
            < 0.5386, -0.6507, -0.5352>,
            < 0.5223, -0.6637, -0.5354>,
            < 0.5175, -0.6623, -0.5418>,
            < 0.5150, -0.6604, -0.5465>,
            < 0.5212, -0.6557, -0.5463>,
            < 0.5283, -0.6507, -0.5454>,
            < 0.5265, -0.6504, -0.5475>,
            < 0.5258, -0.6582, -0.5388>,
            < 0.5125, -0.6571, -0.5527>,
            < 0.5174, -0.6584, -0.5466>,
            < 0.5010, -0.6580, -0.5621>,
            < 0.5376, -0.6595, -0.5254>,
            < 0.5256, -0.6511, -0.5475>,
            < 0.5208, -0.6458, -0.5582>,
            < 0.5231, -0.6730, -0.5229>,
            < 0.4809, -0.6849, -0.5474>,
            < 0.5475, -0.6387, -0.5406>,
            < 0.5205, -0.6327, -0.5733>,
            < 0.5518, -0.6599, -0.5099>,
            < 0.5125, -0.6946, -0.5048>,
            <-0.5136, -0.6801,  0.5232>
        uv_vectors {
            25
            <0.000000, 0.000000>,
            <0.250000, 0.000000>,
            <0.500000, 0.000000>,
            <0.750000, 0.000000>,
            <1.000000, 0.000000>,
            <0.000000, 0.250000>,
            <0.250000, 0.250000>,
            <0.500000, 0.250000>,
            <0.750000, 0.250000>,
            <1.000000, 0.250000>,
            <0.000000, 0.500000>,
            <0.250000, 0.500000>,
            <0.500000, 0.500000>,
            <0.750000, 0.500000>,
            <1.000000, 0.500000>,
            <0.000000, 0.750000>,
            <0.250000, 0.750000>,
            <0.500000, 0.750000>,
            <0.750000, 0.750000>,
            <1.000000, 0.750000>,
            <0.000000, 1.000000>,
            <0.250000, 1.000000>,
            <0.500000, 1.000000>,
            <0.750000, 1.000000>,
            <1.000000, 1.000000>
        face_indices {
            32
            < 0,  1,  5>,
            < 1,  6,  5>,
            < 1,  2,  6>,
            < 2,  7,  6>,
            < 2,  3,  7>,
            < 3,  8,  7>,
            < 3,  4,  8>,
            < 4,  9,  8>,
            < 5,  6, 10>,
            < 6, 11, 10>,
            < 6,  7, 11>,
            < 7, 12, 11>,
            < 7,  8, 12>,
            < 8, 13, 12>,
            < 8,  9, 13>,
            < 9, 14, 13>,
            <10, 11, 15>,
            <11, 16, 15>,
            <11, 12, 16>,
            <12, 17, 16>,
            <12, 13, 17>,
            <13, 18, 17>,
            <13, 14, 18>,
            <14, 19, 18>,
            <15, 16, 20>,
            <16, 21, 20>,
            <16, 17, 21>,
            <17, 22, 21>,
            <17, 18, 22>,
            <18, 23, 22>,
            <18, 19, 23>,
            <19, 24, 23>
#declare pApproxLook = <-3295778.3537, 4308723.8277, 3353808.4183>;
object {
    Earth_Slice_n42e044
        uv_mapping
            image_map {
                png "AnImage.png"
                gamma srgb
                map_type 0
                interpolate 2
                once
    double_illuminate
    translate pApproxLook
#declare pMin = min_extent(Earth_Slice_n42e044);
#declare pMax = max_extent(Earth_Slice_n42e044);
#declare pCtr = (pMin + pMax)/2;
    location 10000*<0, 10, 8>
    look_at <0, 0, 0>
    translate pCtr + pApproxLook
background { color Gray30 }
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 15 Sep 2020 13:55:01
Message: <web.5f60ffb757afda216e3057d70@news.povray.org>
> to).
So Bill, It seems that you guessed right...
Tor Olav
http://subcube.com
Date: 15 Sep 2020 20:17:46
Message: <5f6159aa$1@news.povray.org>
Hi(gh)!
Why shouldn't I? Of course I read any reply!
> to).
> for the UV-mapping:
> default {
>      texture {
>          finish {
>              diffuse 0
>              ambient color Black
>      mesh2 {
>          vertex_vectors {
>              25
>          normal_vectors {
>              25
>          uv_vectors {
>              25
>          face_indices {
>              32
>              < 0,  1,  5>,
>              < 1,  6,  5>,
>              < 1,  2,  6>,
>              < 2,  7,  6>,
>              < 2,  3,  7>,> so I'll reply to you
> instead.
>              < 3,  8,  7>,
>              < 3,  4,  8>,
>              < 4,  9,  8>,
>              < 5,  6, 10>,
>              < 6, 11, 10>,
>              < 6,  7, 11>,
>              < 7, 12, 11>,
>              < 7,  8, 12>,
>              < 8, 13, 12>,
>              < 8,  9, 13>,
>              < 9, 14, 13>,
>              <10, 11, 15>,
>              <11, 16, 15>,
>              <11, 12, 16>,
>              <12, 17, 16>,
>              <12, 13, 17>,
>              <13, 18, 17>,
>              <13, 14, 18>,
>              <14, 19, 18>,
>              <15, 16, 20>,
>              <16, 21, 20>,
>              <16, 17, 21>,
>              <17, 22, 21>,
>              <17, 18, 22>,
>              <18, 23, 22>,
>              <18, 19, 23>,
>              <19, 24, 23>
> object {
>      Earth_Slice_n42e044
>      texture {
>          uv_mapping
>          pigment {
>              image_map {
>                  png "AnImage.png"
>                  gamma srgb
>                  map_type 0
>                  interpolate 2
>                  once
>      double_illuminate
> #declare pMax = max_extent(Ear> so I'll reply to you
> instead.
th_Slice_n42e044);
> camera {
>      look_at <0, 0, 0>
> Tor Olav
> http://subcube.com
Yep, that's the ticket! I left out texture index in the face_indices
block, and, whoopeee!, the whole thing runs perfectly! Thank you, Tor!
I'll include you in my credits list!
Yadgar
