POV-Ray : Newsgroups : povray.binaries.images : Fresnel reflection { 0 } vs. Lambertian Server Time
17 Dec 2025 20:23:08 EST (-0500)
  Fresnel reflection { 0 } vs. Lambertian (Message 1 to 3 of 3)
Subject: Fresnel reflection { 0 } vs. Lambertian
Date: 27 Mar 2020 20:52:53
Message: <5e7e9fe5$1@news.povray.org>
I was modeling a floor with varying levels of glossiness, and just as a
sanity check, I compared a floor of Fresnel reflection 0 to a floor with
no Fresnel reflection.  To my surprise, the former was darker than the
latter.  Is this correct?  It seems to me that they should look the same.
The first attached image has only diffuse reflection.  The second has
finish level Fresnel with reflection { 0 }.  The last, for sake of
completeness, has full gloss with finish level Fresnel and reflection {
1 }.  These images were rendered with radiosity, but rendering with
ambient yields similar results.
(I haven't seen clipka lately.  Wasn't he working on this?)
------------[BEGIN CODE]------------
// +KFF3
#version 3.8;
#ifndef (Rad) #declare Rad = off; #end
#include "screen.inc"
global_settings
{ assumed_gamma 1
   #if (Rad)
     #declare Pixel = 1 / max (image_width, image_height);
     radiosity
     { count 200
       error_bound 0.5
       pretrace_start 32 * Pixel
       pretrace_end 2 * Pixel
       recursion_limit 2
#default { finish { ambient 0.1 diffuse 1.0 emission 0 } }
Set_Camera (<0, 2, -5>, <0, 1, 0>, 30 * image_width / image_height)
//--------------------- ENVIRONMENT ------------------------
#declare RBULB = 0.1;
#declare DIST = 5;
#declare Surface = pow (DIST / RBULB, 2);
light_source
{ <0, 2.5, 5>, rgb (1 + Surface) / 2
   fade_power 2 fade_distance RBULB
   spotlight point_at <0, 1, 0> radius 45 falloff 90
   looks_like
   { sphere
     { 0, RBULB
       pigment { rgb 1 }
       finish { ambient 0 diffuse 0 emission Surface }
       no_radiosity
box
{ -1, 1 scale <6, 8, 6>
   hollow
   pigment { rgb 0.6 }
//----- things to reflect -------
#declare Sculpture = union
{ cylinder { 0, 1.5 * y, 0.5 }
   sphere { 1.5 * y, 0.5 }
object { Sculpture pigment { blue 0.5 } translate <0.6, 0, 5.5> }
object { Sculpture pigment { green 0.5 } translate <1.8, 0, 5.5> }
object { Sculpture pigment { red 0.5 } translate <3.0, 0, 5.5> }
//---------------------- GLOSS TEST ------------------------
plane
{ y, 0
   pigment { checker rgb 0.03 rgb 0.6 }
   #switch (frame_number)
     #case (2)
       #declare s_Case = "fresnel reflection { 0 }"
       finish
       { fresnel
         reflection { 0 }
         conserve_energy
       interior { ior 1.5 }
       #break
     #case (3)
       #declare s_Case = "fresnel reflection { 1 }"
       finish
       { fresnel
         reflection { 1 }
         conserve_energy
       #break
     #else
       #declare s_Case = "no specular reflection"
//---------------------- ANNOTATION ------------------------
Screen_Object
( union
   { text { ttf "cyrvetic" s_Case 0.001, 0 translate y }
     text
     { ttf "cyrvetic"
       concat ("Radiosity is ", #if (Rad) "on." #else "off." #end)
       0.001, 0
     pigment { rgb 0.7 }
     finish { ambient 0 diffuse 0 emission 1 }
     scale 0.065
   <0, 0.8>, <0.02, 0.02>, yes, 1
-------------[END CODE]-------------
Download 'glossy_floor-pbi-rad1.jpg' (16 KB) Download 'glossy_floor-pbi-rad2.jpg' (15 KB) Download 'glossy_floor-pbi-rad3.jpg' (16 KB)
Preview of image 'glossy_floor-pbi-rad1.jpg'
Preview of image 'glossy_floor-pbi-rad2.jpg'
Preview of image 'glossy_floor-pbi-rad3.jpg'
Subject: Re: Fresnel reflection { 0 } vs. Lambertian
Date: 6 May 2020 12:16:24
Message: <5eb2e2d8$1@news.povray.org>
> plane
> { y, 0
>      #case (2)
>        finish
>        { fresnel
>          reflection { 0 }
>          conserve_energy
>        #break
>      #case (3)
>        finish
>        { fresnel
>          reflection { 1 }
>          conserve_energy
>        #break
>      #else
>    #end
Saw this post months back. But, I wasn't really following or involved in
this work so I let it go.
Given nobody has stepped in to answer, I decided to look at the parser
code quickly today ahead of lunch.
My read of the parser code.
It looks like the parser defaults the finish fresnel to 1.0 if no float
specified so you are turning it on in both cases despite not passing a
non-zero float - and you have the required ior.
When the reflection block precedes the finish block's fresnel, the
fresnel keyword in the reflection block is turned on. Otherwise it is
only on if you specify fresnel in the reflection block yourself.
 From this, I don't think you are getting fresnel 'reflections' in any
case.
Fresnel is on always though, so it's still doing whatever it does to the
other finish components - which I suspect explains the darker result.
The idea of the finish level fresnel wasn't much about the reflection
block as far as I knew, but about the behavior with respect to other
finish elements when you know the (surface) IOR.
Disclaimer. This is me complaining about the first base umpires call
from the top row of the upper most deck (back in the day when we went to
sporting events...). That said, does this interpretation makes sense
given what you see? I've not run anything - just a quick look at the
parser code...
Bill P.
Date: 23 Jun 2020 23:34:56
Message: <5ef2c9e0$1@news.povray.org>
> case.
This was exactly the situation.  Giving fresnel an argument solved the
problem.  Thanks!
