![](/i/fill.gif) |
I wanted to see how close Radiosity could get to pure ambient occlusion.
I found out that it's very close, and that there are only some minor
differences. The bottom line is that radiosity (using one bounce and a
white background) is about the same as regular AO.
For this experiment, an object with lots of nooks and crevices was
helpful, and that's where my inverted quintrino came to the rescue. The
only adjustment I did to the image was an inverse gamma correction.
You can see the results on my webpage by following link below. You can
drag the slider back and forth, or click "AO" or "RADIOSITY" at the top
and it will slide across automatically. Or you can click anywhere in the
image and the dividing line will slide to that location.
https://scorpius.github.io/compare.htm
![](/i/fill.gif) |
![](/i/fill.gif) |
Well, radiosity > ambient occlusion.
Here's why : Ambient occlusion only takes into account the proximity of
the occluding object. It can't give you the effect of a flame
illuminating it's surrounding, the effect of a mirror nor that of a
crystal sphere projecting other objects onto a near surface. Also, it
neglect the effect of a strongly coloured object have on it's surrounding.
Radiosity do take into account the reflectivity, emission capacity,
colour and transparency of the objects, and can take into account more
than one bounce.
So, one bounce radiosity where all objects are white will get you
essentially the same result as using ambient occlusion.
Ambient occlusion is essentially a subset of radiosity.
![](/i/fill.gif) |
