POV-Ray : Newsgroups : povray.binaries.images : Adding black_hole types 2 thru 7 to code branch. Server Time
13 Jul 2025 00:39:10 EDT (-0400)
  Adding black_hole types 2 thru 7 to code branch. (Message 1 to 3 of 3)
Subject: Adding black_hole types 2 thru 7 to code branch.
Date: 1 Jun 2019 08:17:17
Message: <5cf26ccd$1@news.povray.org>
In addition to type 1 which fixes / clamps the inward black_hole, added
types 2,3 and 4 which are like type 1 except limiting results to x, y,
and z coordinate movements, respectively.
New types 5,6 and 7 represent new whirlpool warps around the localized
spherical coordinates x, y and z axes. The inverse keyword reverses the
normal direction of rotation. Setting strength 1.0 means a rotation of
2*pi or a full rotation at the origin - which is a lot. Strengths of 0.5
perhaps a better starting, half rotation at the local origin.
See branch:
https://github.com/wfpokorny/povray/tree/feature/newBlack_holeTypes
Bill P.
Download 'additionalwarps.png' (363 KB)
Preview of image 'additionalwarps.png'
Subject: Re: Adding black_hole types 2 thru 7 to code branch.
Date: 1 Jun 2019 10:30:01
Message: <web.5cf28b23748032b44eec112d0@news.povray.org>
NICE, Bill.
This hearkens back to
http://news.povray.org/povray.binaries.images/thread/%3C5b492942%40news.povray.org%3E/?mtop=423470
I had made it reasonably far in converting the existing black hole warp source
to SDL and fooling with that, and I think even got some twist in there as well.
I don't know that I ever posted any of those renders.  Probably RL derailed
that.
It's great to read through the source and see how it's all very logically and
methodically laid out.  It would be great to see a few SDL-only scenes that use
"the same coding" to modify a grid of spheres or a square image-map (using
eval_pigment)
Then maybe people would be inspired to play with their own warp patterns and
then they could be adapted to cpp if some really good ones get developed.
(Sometimes it's a bit hard to grasp the context of a small portion of the code,
and some of the cpp stuff still gives me trouble.)
Download 'spiraltornado.png' (800 KB)
Preview of image 'spiraltornado.png'
Date: 2 Jun 2019 06:32:18
Message: <5cf3a5b2$1@news.povray.org>
> NICE, Bill.
Yes, I vaguely recall folks working on ideas in that thread and it's a
reason I went after the whirlpool (I see the typo whirpool now in my
image...) options. I initially was after only the x,y,z only filters.
Often true. Occasionally...(1) ;-)
(1) - Especially my own code/writing read some significant time later!
> eval_pigment)
Same here.
There have been proposals - and there was a patch by someone? - a few
years back to add warp { function {}... } capability to the warp
feature. I'd never put the enhancement too near the top of my list as
you can modify patterns today with functions in that fashion, though,
less directly. Functions can define patterns directly too.
Thinking about it now though wondering if warp { black_hole function
{}... } might not be helpful. In addition to built in repeat / random
placement capabilities, what's useful with the black_hole warp is it
localizes the manipulations. Strong at the spherical origin fading to
nothing at the black hole's radius/surface of influence.
Hmm. Perhaps things like "warp { black_hole pattern { } }" or "warp {
black_hole turbulence { } }" even better... Worth more thinking.
Aside: I wondered as I created the x,y,z filters, if some general
mechanism filtering all black_hole (or warp{}) results to
+x,-x,+y,-y,+z,-z might not be the best way to go. But, would need to
modify a good bit more source code and add SDL syntax to play there.
Bill P.
