POV-Ray : Newsgroups : povray.binaries.images : How does cylindrical warp work? Server Time
28 Sep 2024 01:19:09 EDT (-0400)
  How does cylindrical warp work? (Message 1 to 3 of 3)
Subject: How does cylindrical warp work?
Date: 4 May 2019 00:49:30
Message: <5ccd19da$1@news.povray.org>
OK, so it turns out I don't understand cylindrical warp after all.
A few years ago, I introduced cylindrical textures to CoffeeMug in the
object collection.  Looking back to see how I could adapt the code to
work with cylinders or cones oriented in different directions, I
realized that I had never specified any orientation for the coffee mug!
I went back to RTFM to see how it would be done.
The orientation keyword would seem to do the trick, but the doc says
that the default is <0, 0, 1>.  My coffee mug is vertically oriented,
and my code works without changing the default.
I whipped up a test scene to investigate the orientation keyword.  I
used Parse_String() to make sure that the SDL for each test case exactly
matched the annotation text.  In these scenes, p_Test is defined as
pigment { square scale 1/8 }.
True to the docs, orientation z matches the default, not orientation y.
And somehow, orientation z corresponds to a cylinder with axis y.  I do
not understand why this is; and more importantly, I have no clue how to
get a cylindrical warp to match a cylinder of arbitrary orientation.
How does it work?
Also, I am bemused by the cylinder illustration, which somehow works
with a vertical cylinder and orientation y, and I am befuddled the
spiral at the top; but since the example uses a non-default dist_exp
(whose explanation soars way above my head), I don't know if it's relevant.
Download 'test_cylindrical_warp1.jpg' (37 KB) Download 'test_cylindrical_warp2.jpg' (46 KB) Download 'test_cylindrical_warp3.jpg' (39 KB) Download 'test_cylindrical_warp4.jpg' (48 KB)
Preview of image 'test_cylindrical_warp1.jpg'
Preview of image 'test_cylindrical_warp2.jpg'
Preview of image 'test_cylindrical_warp3.jpg'
Preview of image 'test_cylindrical_warp4.jpg'
Subject: Re: How does cylindrical warp work?
Date: 4 May 2019 08:50:00
Message: <web.5ccd898157a169b04eec112d0@news.povray.org>
Heh, I went through this no so long ago.
http://news.povray.org/povray.bugreports/thread/%3Cweb.5c01b8a81374e197765e06870%40news.povray.org%3E/
I can't imagine having to conceive of the warp, code it, and make it work with
all of the rest of what's going on in POV-Ray without breaking.   :O
Maybe the discussion and my code at the end of the thread will help you puzzle a
bit more of this out.  :)
Date: 4 May 2019 14:33:36
Message: <5ccddb00@news.povray.org>
> [snip]
> get a cylindrical warp to match a cylinder of arbitrary orientation. How
> does it work?
I rendered some permutations of the example in the reference manual, and
two things are clear.  Most obviously, I should leave dist_exp alone.
The other is that all orientations work with a vertical cylinder.
Extrapolating, it looks to me that the cylindrical warp always assumes a
vertical structure, and that I should start with that assumption in
defining the texture, then reorient it to match the object.
Download 'cylindrical_warp_ref.jpg' (478 KB)
Preview of image 'cylindrical_warp_ref.jpg'
