POV-Ray : Newsgroups : povray.binaries.images : Exploring Medieval windows Server Time
15 May 2024 15:55:03 EDT (-0400)
  Exploring Medieval windows (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Exploring Medieval windows
Date: 11 Mar 2019 17:32:19
Message: <5c86d3e3$1@news.povray.org>
Am 11.03.2019 um 08:30 schrieb Thomas de Groot:
> On 10-3-2019 20:57, MichaelJF wrote:
>> Am 08.03.2019 um 08:28 schrieb Thomas de Groot:
>>> On 7-3-2019 16:02, ingo wrote:
>>>> in news:5c80dc5f@news.povray.org Thomas de Groot wrote:
>>>>> I came across some examples of Medieval windows made with the "cives"
>>>>> technique ("fenêtre à cives")
>>>> OMG, "Buzenscheiben", I've had to recreate and colourise those many
>>>> times
>>>> for printing on self adhesive window films.
>>> LOL Indeed, that is where those are mostly found nowadays.
>>> To all: What are those windows called in other languages?
>> In German, it is Butzenglas, Batzenscheibe, Nabelscheibe or
>> Ochsenauge. I modelled it some years ago with wings 3d, but never
>> posted the code (mesh) and the macros to produce windows from it. If
>> someone is interested, I will clean up the code a little bit and post it.
> Interesting! I modelled the glass in Silo and am currently writing
> macros for the different types of windows. I certainly shall continue
> till completion, but I would be curious to compare eventually. So, yes,
> please?
Hello Thomas,
I was on an occupational journey and had to congratulate my father to
his eighty-first birthday today, living at the same location at Essen,
Germany. I hope I can post the code tomorrow. It is just a mesh and some
macros to put the tiles into a window with rounded frames and a frame
all around them to have a window.
Best regards
Michael
Date: 12 Mar 2019 06:03:59
Message: <5c87840f@news.povray.org>
>>>>> times
>>> it.
>> yes, please?
> Hello Thomas,
That is ok, Michael. Happy Birthday to your father! I hope he is in good
health.
Date: 12 Mar 2019 19:05:21
Message: <5c883b31$1@news.povray.org>
Am 12.03.2019 um 11:03 schrieb Thomas de Groot:
>>>>>>> "cives"
>>>>>> many times
>>>> post it.
>>> yes, please?
>> Hello Thomas,
>> some macros to put the tiles into a window with rounded frames and a
>> frame all around them to have a window.
> health.
Hello Thomas,
you will find the macros now in p.b.s-f. I haven't used them in
closeups, so the textures could need improvement.
As to my father: He was very happy about my unheralded visit and I would
be happy to have his health condition if I ever reach his age.
Best regards
Michael
Date: 13 Mar 2019 07:47:44
Message: <5c88ede0$1@news.povray.org>
This is #2.
Basic frame texture and some small issues (code needs cleaning up).
Date: 13 Mar 2019 07:49:13
Message: <5c88ee39@news.povray.org>
This is #2.
Download 'cive medieval_test_#2.png' (344 KB)
Preview of image 'cive medieval_test_#2.png'
Date: 13 Mar 2019 14:47:16
Message: <5c895034$1@news.povray.org>
Am 13.03.2019 um 12:49 schrieb Thomas de Groot:
> This is #2.
Hello Thomas,
congratulations, you crafted this very well. It's very to close to my
macros and showing, that I overlooked a small issue. But with sane
definitions of the width of the wooden frame no one will notice my fault;)
Best regards
Michael
Date: 14 Mar 2019 03:43:09
Message: <5c8a060d$1@news.povray.org>
>> This is #2.
> Hello Thomas,
Thank you indeed, Michael. I have not yet looked at your code but will
do that soon. However, your test image is very explicit and shows the
good work already.
The small issue I was talking about is the thin line of light visible
between the glass/lead and the window frame. It could be the window
being a tiny bit too small but I guess it is light "leaking" at angles.
Something similar is shown at the angle between floor and wall. I dimly
remember this phenomenon was discussed many years ago and I do not
remember the way to correct that, except, I believe, by using stochastic
anti-aliasing. I shall test that in any case.
Date: 14 Mar 2019 08:28:54
Message: <5c8a4906$1@news.povray.org>
As I supposed indeed, stochastic antialiasing (with no_cache) solves the
issue.
Date: 15 Mar 2019 04:36:02
Message: <5c8b63f2@news.povray.org>
>> angles. Something similar is shown at the angle between floor and
>> wall. I dimly remember this phenomenon was discussed many years ago
>> and I do not remember the way to correct that, except, I believe, by
>> using stochastic anti-aliasing. I shall test that in any case.
> issue.
The downside of this is that combining stochastic aa with photons, will
dramatically decrease render speed. A rough calculation for the image
above, with a crude setting of aa (+a0.1) and with photons enabled,
shows that it will take at least 24 hours to render. :-(
Date: 15 Mar 2019 07:54:12
Message: <5c8b9264$1@news.povray.org>
>> the issue.
Not precise enough I am afraid. I need to give you more relevant info:
+ The issue mentioned above was solved using UberPOV, without photons,
and with no_cache on in the radiosity block. Command line: +w640 +h640
+am3 +a0.01 +ac0.995 +r3 +bm2 +bs8 +wt6. Radiosity's count was lowered
to 10. Render time seemed acceptably "low" (I didn't render a complete
image).
+ The same settings using UberPOV, this time with photons on, the render
time soared up to the estimate of 24 hours+.
+ Using the latest version of 3.8, and with identical settings for +am3
on the command line (no_cache is /not/ available in this version), both
with or without photons available, the render time was "low" i.e.
acceptable for a test and within the hour. However, the issue mentioned
above was *not* solved. I tried to increase dramatically the count value
in the radiosity block but to no avail where the issue was concerned.
I would like some expert's view on the matter please.
