POV-Ray : Newsgroups : povray.binaries.images : Involute spur gear Server Time
23 Mar 2026 17:55:51 EDT (-0400)
  Involute spur gear (Message 1 to 10 of 33)
Subject: Involute spur gear
Date: 16 Dec 2018 22:54:17
Message: <5c171de9@news.povray.org>
I would like to make something with gears, but not sure what.
Three of the gears I've cut from sheet metal (thirteen in total) and
some I've modeled.
Comments welcome:
Stephen S
Download 'gears.png' (578 KB) Download 'gear_test0000.png' (33 KB)
Preview of image 'gears.png'
Preview of image 'gear_test0000.png'
Subject: Re: Involute spur gear
Date: 17 Dec 2018 02:25:35
Message: <5c174f6f$1@news.povray.org>
> some I've modeled.
> Comments welcome:
> Stephen S
An Aztec Calendar is what I would attempt.
Date: 17 Dec 2018 02:28:29
Message: <5c17501d$1@news.povray.org>
Is that in the real world you want to do it?
> some I've modelled.
What restrictions do you have in the physical world? Could you make the
gears fine enough to make a clock?
My first thought is an orrery, which could be a clock as well.
https://www.instructables.com/id/Orrery-a-Mechanical-Solar-System-Model-From-Plywoo/
Would you want it to be practical or decorative?
I can see why you are asking for comments. Ideas are not easy to come by.
Great project.
> Comments welcome:
> Stephen S
Regards
Date: 17 Dec 2018 06:41:53
Message: <5c178b81$1@news.povray.org>
Add to list for research ...
Stephen S
Date: 17 Dec 2018 06:47:12
Message: <5c178cc0$1@news.povray.org>
Yes
...Clock gears would be to fine, or the project would have to be to big.
The industrial equipment being used is more for power than detail. Drop
off material I have to work with is under 1 foot square each.
Stephen S
Date: 17 Dec 2018 06:56:23
Message: <5c178ee7$1@news.povray.org>
I had some site info a while back about a gear construct of the
calendar, but somehow the site disappeared or was renamed. I shall look
further...
Date: 17 Dec 2018 08:28:21
Message: <5c17a475$1@news.povray.org>
> Yes
>> the gears fine enough to make a clock?
> ....Clock gears would be to fine, or the project would have to be to big.
Are you sure?
https://www.youtube.com/watch?v=V1lHo8lGhWg
The centrepiece for any workshop
You are talking to someone who thinks a 0 ba spanner is a bit on the
hefty side.
I can't stop thinking about clocks now.
Regards
Date: 17 Dec 2018 09:15:00
Message: <web.5c17af1c540b848f48892b50@news.povray.org>
hi,
> some I've modeled.
(and, you wrote, you have access to further cut offs)
> Comments welcome:
I've always liked mobiles and such, so I'll suggest some kind of "kinetic art"
sculpture/structure/arrangement.
regards, jr.
Date: 17 Dec 2018 10:30:40
Message: <XnsA9BBA7F6DCCF4seed7@news.povray.org>
http://americanhistory.si.edu/collections/search/object/nmah_998869
ingo
Date: 17 Dec 2018 10:34:27
Message: <XnsA9BBA89B98EDBseed7@news.povray.org>
> ingo
http://americanhistory.si.edu/collections/search/object/nmah_861150
search the site for patent model,
ingo
