POV-Ray : Newsgroups : povray.binaries.images : Unexpected double_illuminate tradeoffs Server Time
24 Jun 2026 22:21:41 EDT (-0400)
  Unexpected double_illuminate tradeoffs (Message 22 to 31 of 41)
Subject: Re: Unexpected double_illuminate tradeoffs
Date: 4 Aug 2018 07:37:24
Message: <5b658ff4$1@news.povray.org>
On 08/04/2018 03:20 AM, Stephen wrote:
> I can hear his voice when I read it. :-)
likewise
> But we should not mock the afflicted.
why not ... it's become a sport in my household
Date: 4 Aug 2018 07:55:56
Message: <5b65944c$1@news.povray.org>
On 08/03/2018 07:09 AM, Thomas de Groot wrote:
> I am sure the potus has something to twitter about that.
Pricks Often Tell Unsubstantiated Stories?
Date: 4 Aug 2018 12:34:38
Message: <5b65d59e$1@news.povray.org>
On 2018-08-04 03:20 AM (-4), Stephen wrote:
> On 04/08/2018 07:52, Thomas de Groot wrote:
>> On 3-8-2018 13:55, Stephen wrote:
>>> Wonderful country, great Queen. They all love me over there. ;-)
>> LOL! (oh dear saints in heaven... I almost pissed my pants...)
> :-D
So can I.  Thanks for that auditory imagery, Stephen.  :-P
When the affliction is comorbid with narcissism, assholitis, and the
Dunning-Kruger affect, I will mock.  Especially when this megalomaniac
who hates dark-skinned people who don't pay lip service to Jesus[1] and
denies that I have a constitutional right to citizenship is making
policy that affects me.
________________
[1] I deliberately phrased it that way, because you know damn well that
the Afflicted One is only pretending to love Jesus.
Date: 4 Aug 2018 13:39:16
Message: <5b65e4c4$1@news.povray.org>
> likewise
A boon to comedians. :)
I am quoting the late Frankie Howard. "Mock not the afflicted." was one
of his catchphrases.
And he was certainly "afflicted". ;)
Regards
Date: 4 Aug 2018 13:52:42
Message: <5b65e7ea$1@news.povray.org>
>> :-D
Not a problem, cuz. :)
Now, if you want an earworm. ;)
Try this from the 80's. Sophia George
https://youtu.be/nDKb4O-l02U?t=22
Ooo! it has a name. :)
> I will mock.
Afflicted might be referring to the people who are afflicted by him,
yes, yes?
It is too easy really. But see my reply to Jim.
Well, he is not making it a secret. At least you can say that of him. :)
> ________________
Not Jesus the Mexican welder I met in NM? And yes his wife's name was
Mary and he had a sunscreen on his car that said; "Mary and Jesus".
Regards
Date: 4 Aug 2018 16:30:01
Message: <web.5b660bd341922aca47873e10@news.povray.org>
> Miles, baby.  Miles.
LOL! Brilliant.
I always *knew* there was a difference between meters and...uh...yards, but I
could never quite put my finger on it...
Gonna save that image and show it to my mathematically-challenged friends:
PROOF that the U.S. system of measurement is BIGGER and BETTER! I'm sure POTUS
would think so.  :-P
Date: 4 Aug 2018 17:10:01
Message: <web.5b6615cc41922aca47873e10@news.povray.org>
> Tradeoffs, tradeoffs, tradeoffs.
> I found the black borders on the smooth triangles unexpectedly
> disturbing.  They do show up on my height field hills under some
> circumstances, but are quite tolerable.  But seeing them cap my trees
> sent me straight to double_illuminate.  Disappointingly, double
> illumination had its own peculiarities near the shadow lines.  And when
> I added surface normals to the trees, it got really weird.
About your low-res smooth_triangle trees: I still think that at least the
edge-normal artifacts can be made to look a bit better.
I've been playing around with a low-res height_field, testing double_illuminate
vs. an inside_texture (a RED color in my example), and I think the latter can be
a more effective solution as a tradeoff. From the tests, it's clear that the
object's edge normals are not picking up any of the SKY color (YELLOW), but
rather, the black unlit 'inside' of the closed mesh. (The docs clearly explain
this 'reversed-normal' situation, of course.) But using the recommended
double_illuminate causes strange visual artifacts to appear on an 'applied'
normal{...}.
About the image:
There are to lights in the scene (one of very low intensity from the right, just
to help show some of the bumps normals on that side of the HF, rather than
completely featureless triangle faces that are in shadow.) That by itself helps
with the other problems a little bit.
Image 1 contains the edge artifacts, although they're difficult to see (your
trees are a better test case.)
Image 2-- using double_illuminate-- shows the changed appearance of the bumps
normal. (See the exact center of the image.)
Image 3 shows the true edge artifacts in all their glory ;-) But it also shows
that, by using an *appropriate* color for the inside_texture, it might be
possible to 'hide the edge artifacts in plain sight' so to speak. For example,
if the sky behind the tree edges is a light blue color, and the trees are olive
green, the inside_texture's pigment could be a 'mottled blend' between the two.
A quick and dirty example:
   pigment{
          bumps
          scale <...to be determined...>
          color_map{
                  [0 <...sky blue...>]
                  [1 <... tree green...>]
           --- some warp{turbulence...}---
   finish{ambient 0 emission .5 diffuse 0}
The basic idea is to give a kind of random blue/green color to the edges of the
trees, in a broken-up way, to help them visually blend in better with the sky
and with their neighbors.
Download 'low_rez_hf_tests.jpg' (288 KB)
Preview of image 'low_rez_hf_tests.jpg'
Date: 4 Aug 2018 18:05:01
Message: <web.5b66222841922aca47873e10@news.povray.org>
> normal{...}.
"Artifacts" is the wrong word, I admit; the effect is probably a natural result
of 'double-illuminating' the applied normal-- which is not the general way that
normals are expected to interact with a *single* light-source direction. A
better way to describe it would be: a more 'complex' interaction.
Date: 5 Aug 2018 02:30:12
Message: <5b669974$1@news.povray.org>
>>> :-D
>> I will mock.
> yes, yes?
>> Especially when this megalomaniac who hates dark-skinned people who
>> don't pay lip service to Jesus[1] and denies that I have a
>> constitutional right to citizenship is making policy that affects me.
>> ________________
>> that the Afflicted One is only pretending to love Jesus.
I am afraid he sincerely(?) believes that. However, his guru was/is a
creepy guy in my view...
Till the end of my days, I shall be amazed by the world I live in.
Date: 5 Aug 2018 02:38:29
Message: <5b669b65$1@news.povray.org>
That's very close to the mark indeed! :-)
[I can't do better]
