POV-Ray : Newsgroups : povray.binaries.images : Spiral Warps? Server Time
16 Feb 2026 19:11:33 EST (-0500)
  Spiral Warps? (Message 1 to 10 of 27)
Subject: Spiral Warps?
Date: 13 Jul 2018 18:35:46
Message: <5b492942@news.povray.org>
Hi(gh)!
Following a thread on Jupiter images on p.o-t, I started to model some
basic gas giant textures based on this (non-POV-Ray) tutorial:
https://www.seedofandromeda.com/blogs/49-procedural-gas-giant-rendering-with-gpu-noise
with color suggestions gleaned from here:
http://visions2200.com/Articles/ExtrasolarSpeculations.html (the chapter
"Color, Albedo and Temperature), I made a "cold Jovian" gas giant as
attached below...
...but how do I get realistic storm systems? The ones at "Seed of
Andromeda" do not look very convincing, they would have to drag in
clouds in a spiralling rather than a straight way (like with the
black_hole warp of POV-Ray). Is there some trick to achieve a "spiral warp"?
See you in Khyberspace!
Yadgar
Download 'cold_jovian_gas_giant.png' (534 KB)
Preview of image 'cold_jovian_gas_giant.png'
Subject: Re: Spiral Warps?
Date: 14 Jul 2018 02:46:39
Message: <5b499c4f$1@news.povray.org>
> warp"?
Just thinking aloud, not verified (yet) is it possible to add 'rotate
<....>' to a black hole warp within the warp block?
Date: 14 Jul 2018 05:34:00
Message: <5b49c388$1@news.povray.org>
Hi(gh)!
Probably not, I tried scaling (to get more elongated warps), but got an
error message! And, rotating would change only the orientation of the
warp, not its internal structure...
Yadgar
Date: 14 Jul 2018 07:09:34
Message: <5b49d9ee$1@news.povray.org>
On 14-7-2018 11:34, Jörg "Yadgar" Bleimann wrote:
> Hi(gh)!
yes... You are right; I was thinking along another line though which
involved an imaginary rotation/deformation of the pattern. No there of
course.
This is a problem. One would need something like the cylindrical warp
applied to the individual black holes... oh hell! I don't know how to
solve this... :-(
Date: 14 Jul 2018 15:15:00
Message: <web.5b4a4ab0aab4365c458c7afe0@news.povray.org>
I don't have anything to suggest in terms of adapting or implementing this, but
I was just looking around and found this.
http://news.povray.org/povray.binaries.images/message/%3C4cd5e4f2%40news.povray.org%3E/#%3C4cd5e4f2%40news.povray.org%3
E
Not sure if that's of any use at all....
Date: 15 Jul 2018 02:30:27
Message: <5b4aea03$1@news.povray.org>
> E
The problem is: how would you apply this to a black hole warp? I
mentioned the cylindrical warp, but with spiral1 or spiral2 the problem
would be the same. I have no idea at the moment.
Date: 15 Jul 2018 17:50:00
Message: <web.5b4bc065aab4365c458c7afe0@news.povray.org>
Right.   Just throwing ideas out to spark some brainstorming.
I'm assuming that at some point, someone will go "AHA!"
See "Black Hole" and "Tornado"
http://www.bugman123.com/Renderings/index.html
and let us not forget:
http://www.f-lohmueller.de/pov_tut/backgrnd/p_wat4.htm
Date: 16 Jul 2018 02:58:34
Message: <5b4c421a$1@news.povray.org>
Yes, there are some pretty good whirlpool examples around in POV
space... :-)
It is always what there is not that we want most urgently! ;-)
Date: 16 Jul 2018 03:08:16
Message: <5b4c4460@news.povray.org>
Hi(gh)!
...but I need (for the time being - later on I would model real cloud
layers with media) a kind of pattern modifier, not a 3D object!
Yadgar
Date: 17 Jul 2018 06:55:01
Message: <web.5b4dcad1aab4365ca47873e10@news.povray.org>
One idea would be to use POV-Ray's BOXED pattern-- with a pigment_map composed
of *multiple* (averaged?) SPIRAL patterns inside it, each with some appropriate
colors and warp{turbulence...}-- as a way to apply separate 'decals' to various
places on the already-textured planet surface. (The 'outside' of the BOXED
pattern(s) could fade to transparency, so as not to look like the storms are
simply stuck on.) The idea is certainly not as 'realistic' as true fluid
dynamics, but it might work.
