POV-Ray : Newsgroups : povray.binaries.images : Spiral Warps? Server Time
24 Jun 2026 19:56:32 EDT (-0400)
  Spiral Warps? (Message 18 to 27 of 27)
Subject: Re: Spiral Warps?
Date: 22 Jul 2018 17:10:01
Message: <web.5b54f1acaab4365c458c7afe0@news.povray.org>
Here's a real first stab at doing the right thing:
Download 'spiralwarp.png' (263 KB)
Preview of image 'spiralwarp.png'
Date: 22 Jul 2018 18:50:01
Message: <web.5b550926aab4365c458c7afe0@news.povray.org>
And I think this captures the essence of it.
Whee!
Download 'spiralwarp.png' (62 KB)
Date: 23 Jul 2018 02:40:26
Message: <5b55785a@news.povray.org>
> Whee!
But.... concentric shells... those are /not/ storm patterns, are they? :-/
Date: 23 Jul 2018 06:35:01
Message: <web.5b55aeeeaab4365c458c7afe0@news.povray.org>
Not exactly - but they are a type of vortex that's generated from fluid dynamics
equations ... so I would imagine they appear somewhere.
Still working on getting an actual bona-fide spiral shape, but I was happy that
with the weekend rapidly slipping away, I was able to get most of the key pieces
to the method strung together.
Never ever ever ever ever ever ever ever give up.
Hopefully I'll get the code cleaned up and I'll discover some good (x,y)
equations to do exactly what I want - both with control of the internal shape of
the warp, as well as the smooth blending of the edges of the perturbation with
the rest of the scene.
Date: 23 Jul 2018 06:44:15
Message: <5b55b17f$1@news.povray.org>
I am watching with interest.
Date: 23 Jul 2018 07:15:52
Message: <5b55b8e8@news.povray.org>
>>> they? :-/
>> fluid dynamics
>> happy that
>> key pieces
>> internal shape of
>> perturbation with
So am I.
Regards
Date: 24 Jul 2018 21:05:00
Message: <web.5b57cc68aab4365c458c7afe0@news.povray.org>
In this next philosophical installment, I will address an aspect of this which I
had suspected, and speculate on the manner of successfully implementing a
desired pattern.
An equation may be expressed or visualized as a point, line, curve, or surface -
but a warp in the shape of that equation - I do not believe - can be obtained by
perturbing a pattern by that equation.
Instead, the pattern needs to be perturbed by the equation in reverse.  Or as
Mike Williams and POV-Ray, and Matrix Algebra would put it - as the inverse.
http://www.econym.demon.co.uk/isotut/substitute.htm
Shear
It's a bit more dificult to produce a particular shear transformation, because
the values that we need to use in the variable substitution need to be the
inverse of those normally used to generate the shear. We could calculate the
inverse of the transformation matrix by hand, but it is possible to get POV-Ray
to do it for us.
We first create a shear transformation, then declare a transformation function
using its inverse.
#include "transforms.inc"
#declare TR=Shear_Trans(<-0.5,0.5,0.5>,<1.1,0,-0.3>,<-0.3,0.5,0>)
#declare TRFI = function {transform {TR inverse}}
Now we can apply that transformation function to the unit vectors which gives us
the values we need for the substitution. However, we can't use vectors from
inside an isosurface function, so we have to extract the x, y and z values of
each of those vectors outside the isosurface.
#declare A=TRFI(1,0,0);
#declare B=TRFI(0,1,0);
#declare C=TRFI(0,0,1);
#declare Ax=A.x;#declare Bx=B.x;#declare Cx=C.x;
#declare Ay=A.y;#declare By=B.y;#declare Cy=C.y;
#declare Az=A.z;#declare Bz=B.z;#declare Cz=C.z;
We can now use these scalar values in the variable substitution.
function { F(Ax*x+Bx*y+Cx*z, Ay*x+By*y+Cy*z, Az*x+Bz*y+Cz*z) }
The image on the left shows two boxes. One of them is sheared by variable
substitution and the other is sheared with the equivalent conventional shear
transform.
The same method can be used for combinations of shear, rotation and scale
operations. It doesn't seem to work for transformations that involve
translation, but we already know how to do that.
https://www.mathsisfun.com/algebra/matrix-inverse.html
So, I have a few ideas as to the type of spiral / vortex that might be
interesting, however the specific type that I think might be currently sought
after is based on the Kelvin-Helmholtz instability.
https://nylander.wordpress.com/category/physics/fluids/
http://bugman123.com/FluidMotion/KelvinHelmholtz1.m1v
https://en.wikipedia.org/wiki/Kelvin%E2%80%93Helmholtz_instability
Understanding the concepts behind visualizing a vector field I think is
important here, as is bridging the gaps and filling in the missing steps of math
texts that leave you hanging.
Let's say we're talking about some time-dependent fluid dynamics equations that
describe the genesis of a cyclone.  Well, thinking about how that would _look_,
the points - the colors and textures and brightnesses of the pixels would move
along as the clock of the animation incremented.
I think the key to implementing a warp is doing exactly the opposite. The point
at time (t) needs to "inherit" the characteristics of the point in the equation
at t=0.
So, for the time being, I'll probably be (slowly) coding up inverse transforms,
trying out various spiral equations (entries welcome) and seeing if I can come
up with some sort of fairly functional Warp Lab / Playground.
If anyone has any experience in using Mathematica or Matlab, converting some of
the code on Nylander's page would be a nice boost forward.
If there are any computer graphics texts or sites explaining how to construct a
WARP in a texture - that would be some good reading as well.
Date: 27 Jul 2018 07:07:53
Message: <5b5afd09@news.povray.org>
> Whee!
Have you looked at this page?
http://bugman123.com/FluidMotion/index.html
That seems to be what is needed...
Date: 1 Aug 2018 12:35:00
Message: <web.5b61e089aab4365cc437ac910@news.povray.org>
http://thevirtualheart.org/GPU/2dkmodelF.html
view-source:http://thevirtualheart.org/GPU/2dkmodelF.html
http://thevirtualheart.org/GPU/WebGL_GPU_spiral_waves_heart.html
Date: 2 Aug 2018 03:04:13
Message: <5b62aced$1@news.povray.org>
Hmmm yes. Getting closer although I still miss a genuine coriolis effect.
