POV-Ray : Newsgroups : povray.binaries.images : hilbert2d utility Server Time
28 Apr 2024 19:00:05 EDT (-0400)
  hilbert2d utility (Message 33 to 42 of 42)
Subject: Re: hilbert2d utility
Date: 26 May 2018 03:15:29
Message: <5b090991@news.povray.org>
On 26/05/2018 07:37, Thomas de Groot wrote:
> On 25-5-2018 22:53, Stephen wrote:
>> On 25/05/2018 21:35, Bald Eagle wrote:
>>> This actually suggests that since a Hilbert curve is a continuous
>>> function that
>>> can fill 2D (3d?)
>> That's how jr hooked me, with a 3D Hilbert curve. ;-)
>> You might be able to twist his arm. ☺
> Which reminds me: how do you run this utility?
In a *nix environment. I installed Cygwin so it runs in a DOS box. If
you want it to run the included example. You will need to have
pvengine.exe in your path.
Regards
Date: 26 May 2018 04:37:03
Message: <5b091caf$1@news.povray.org>
Once you have done that. Put hilbert2d.c and makefile in a directory
then type make [enter]. This will compile hilbert2d.exe.
Run hilbert2d –n13 –Dobigtest
And it will create an include file and a pov file.
Or drop me a mail and I will give you a copy of the one I compiled.
Regards
Date: 26 May 2018 04:39:40
Message: <5b091d4c$1@news.povray.org>
<sigh>
-n N the program generates Hilbert curves which are always 2ˆN units
long, the length argument provides the value of N, the range is: 2 <= N
<= 24. the default is "6", that is, a length of 64, covering 8x8 units
(unscaled).
Regards
Date: 26 May 2018 07:10:38
Message: <5b0940ae$1@news.povray.org>
Thanks indeed. It has no high priority at the moment. I shall first try
to extend my skills by myself ;-)
Date: 29 May 2018 16:40:00
Message: <web.5b0db9aeff7db64c82a92ab90@news.povray.org>
hi,
"Kenneth" <kdw### [at] gmailcom> wrote:
> Stephen <mca### [at] aolcom> wrote:
> > Hi Kenneth,
> > jr has asked me to ask you, to drop him an email on the subject. As he
> > has lost access to the newsgroups.
> Just tried to contact him, but his email address is showing up here on the web
> interface as
>   jr <cre### [at] gmailcom>
> I'm seeing ### after  cre   and they don't work. Apparently those hash marks are
> substituting for something else. :-(  Maybe it's a web-interface vs. newsreader
> difference?
sorry for lengthy delay, can post again at last.  unfortunately via web
interface, not Thunderbird.  anyhow, will put thoughts to paper before weekend.
regards, jr.
Date: 29 May 2018 16:40:01
Message: <web.5b0dba6aff7db64c82a92ab90@news.povray.org>
hi,
> Just ran across a very interesting video about the Hilbert Curve.
> https://www.youtube.com/watch?v=3s7h2MHQtxc
v natty.  and many more "goodies" on this channel.  thank you.
> This actually suggests that since a Hilbert curve is a continuous function that
> can fill 2D (3d?)  that it can be implemented as a pigment pattern.
> Perhaps others with more free time can imagine other interesting uses.  :)
how does/would distance relate to colour?
regards, jr.
Date: 29 May 2018 21:35:01
Message: <web.5b0dff97ff7db64c10874a080@news.povray.org>
No prob.   There's lots of cool stuff out there, and SO much to learn!
3.6.1.1.2 Color Map
Most of the color patterns do not use abrupt color changes of just two or three
colors like those in the brick, checker or hexagon patterns. They instead use
smooth transitions of many colors that gradually change from one point to the
next. The colors are defined in a pigment modifier called a color_map that
describes how the pattern blends from one color to the next. New in version
3.7.1 non-linear color map interpolation support has been added.
:D   :P
I suppose if the Hilbert curve is a "curve" that is continuous function and can
go from a value to a 2D coordinate, then perhaps there is the inverse of the
function that can go from 2D coordinates to the 0-1 values in a color map.
It might take some finagling to get it to work in a practical sense, but I guess
I'm envisioning a pseudo-Hilbert curve function, where you can specify a number
for the "order" or whatever the proper term is, or there's a function for the
"real" Hilbert curve, and you'd "just" fill a unit square with it.
I was guessing you were much more well versed in the topic and would have some
idea as to how to implement it.
Date: 30 May 2018 05:30:00
Message: <web.5b0e6dfcff7db64c82a92ab90@news.povray.org>
hi,
> 3.6.1.1.2 Color Map
I thought (think) of a colour map as 1D, so not sure how that relates ("maps")
to 2D, however..
there is. example code on https://en.wikipedia.org/wiki/Hilbert_curve.
interestingly, the animated gif in the top right of that page is "coloured in".
is that similar to what you're thinking of?
heh.  I wouldn't know maths if it came and bit me.  the 'hilbert2d' utility is
just a "wrapper" around the code taken from that wiki page.
the output of the 'xy2d()' code could be scaled to the 0..1 range.  would that
do the trick?
regards, jr.
Date: 30 May 2018 06:45:00
Message: <web.5b0e8080ff7db64c10874a080@news.povray.org>
> to 2D, however..
That what the Hilbert curve does, right?   Maps 1D input to 2D output?
Sure - but the way to think about a pigment_pattern is as an equation - for any
<x, y, z> plugged in, you should get some 0-1 out.  Then POV-Ray takes that
value and further processes it with a color map, texture map, material map,
normal, heightfield height, etc.
> do the trick?
That's literally all there is to it.
If you can find code for the 3D version, then that would provide a full
space-filling function.
Date: 30 May 2018 11:15:00
Message: <web.5b0ebf1bff7db64c82a92ab90@news.povray.org>
hi,
> > do the trick?
it should be relatively straightforward to convert the 2D code to idiomatic C++*
and make it available as an intrinsic function which, given the length of a
curve + xy coords, spits out an index.  one for the developers, I think.
* an educated guess, I do not "speak" C++.
there's an archive on the interweb, from ca 1999, which provides some 3D code.
if I find an unmodified copy I will post it here.
regards, jr.
